owaizshareef
Mounting drives [rpcbind]
Sat May 21, 2016 8:16 pm
hi,
i am building a cluster of pi's,
i am using "sudo service rpcbind start" and "sudo update-rc.d rpcbind enable" , to set mount drives and auto update on reboot. but this commands are not working.
the tutorial i am following is for prior version of rpi-2 i believe.
epoch1970
Re: Mounting drives [rpcbind]
Sun May 22, 2016 11:05 am
Nobody uses NFS these days it seems :)
I just had to install nfs-kernel-server on a Pi 3 and got into the issue where mounts from remote hosts fail until you've restarted nfs-common (and perhaps nfs-kernel-server ?) meaning there is a freaking boot order problem in systemd.
Turns out that 2 years ago a nice guy had it all sorted out but his solution is still not applied to standard installs.
The mailing-list post is spot-on except for the temporary files business "Created my own /etc/tmpfiles.d/rpcbind.conf"; This dir doesn't exist on my Pi. I disregarded this part and it seems to work perfectly fine.
If you want to stay on this forum, this is what I just tried:
1) Boot (raspbian-lite, current) and try to mount an export from another host: no joy.
2) On the Pi, add:
2.a) /etc/systemd/system/nfs-common.services
[Unit]
Description=NFS Common daemons
Wants=remote-fs-pre.target
DefaultDependencies=no
[Service]
Type=oneshot
RemainAfterExit=yes
ExecStart=/etc/init.d/nfs-common start
ExecStop=/etc/init.d/nfs-common stop
[Install]
WantedBy=sysinit.target
2.b) /etc/systemd/system/rpcbind.service
[Unit]
Description=RPC bind portmap service
After=systemd-tmpfiles-setup.service
Before=remote-fs-pre.target
[Service]
ExecStart=/sbin/rpcbind -f -w
KillMode=process
Restart=on-failure
[Install]
Alias=portmap
3) Run "systemctl enable nfs-common" and "systemctl enable rpcbind"
4) Reboot and try to mount an export from another host: works.
broe23
Sun May 22, 2016 4:46 pm
You have to only have the Boot Loader on the SD card, and the OS on the USB pocket drive. It will never work with just using thr SD card.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good.
NZDev
Thu Feb 13, 2020 9:31 pm
2) On the Pi, add:
[Unit]
2.b) /etc/systemd/system/rpcbind.service[code][Unit]
[/quote]
Did not work for me.
Still get: "clnt_create: RPC: Program not registered"
Seems like there is more to this wrt SD card versus USB HDD, possibly this advises needs more detail wrt the Drive setup and the fstab enteries???
