bleep42
Official WiFi dongle stopped working after update to 4.4.9
Tue May 17, 2016 12:44 pm
Hi, A long time ago I built a Raspberry Pi laptop.viewtopic.php?f=40&t=67312
It has been working great since then, a few days ago I updated to the latest Jessie build, but the WiFi dongle that I was using WLU6331 (official raspberry pi) stopped working, I have two and neither are working.
However if I plug in another nameless WiFi dongle it works great, I'm using it to send this message.
If I type lsusb with the working WiFi I get.
pi@raspberrypi:~ $ lsusb
Bus 001 Device 006: ID 1d57:fa60 Xenta
Bus 001 Device 005: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 004: ID 067b:2506 Prolific Technology, Inc. Kaser 8gB micro hard drive
Bus 001 Device 007: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
if I do the same with either of the Raspberry Pi dongles I get this.
So the WiFi dongle is not being seen at all?
This was on my old, upgraded Raspbian, I've now got exactly the same result with a fresh install.
The Hardware is a Pi2, the WiFi dongle is connected direct to one of the onboard USB.
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.4.9-v7+ #884 SMP Fri May 6 17:28:59 BST 2016 armv7l GNU/Linux
Any suggestions welcomed.
Regards, Kevin.
ShiftPlusOne
Re: Official WiFi dongle stopped working after update to 4.4
Tue May 17, 2016 1:06 pm
Strange. Seems to be okay here.
Bus 001 Device 006: ID 0a5c:bd1e Broadcom Corp.
Linux serge-testpi 4.4.9-v7+ #884 SMP Fri May 6 17:28:59 BST 2016 armv7l GNU/Linux
bleep42
Tue May 17, 2016 1:50 pm
ShiftPlusOne wrote:Strange. Seems to be okay here.
On the very outside chance that both WiFi dongles had gone duff, I tried one of them on a Pi3 which I have and the lsusb reports it, as yours does as a Broadcom Corp. so the dongle if working. Anything I can try?
Regards Kevin.
bleep42
Tue May 17, 2016 3:00 pm
Ok, looks like I have 2 problems. The first is that the dongle didn't seem to like being used through a 30cm USB cable, it used to be fine (that's life), this is so I can bring the WiFi dongle out side the case, the second is that one of the Official WiFi dongles has died, in fact after a bit of hot swapping of the dongles, both official WiFi dongles seem to have died!. So I'm not very impressed about that. :-(
Regards, Kevin.
