Audio not playing via Pulseaudio
Posted: Mon May 16, 2016 4:58 pm
by Taron
I have a problem with playing sound on my raspberry pi 2 via pulseaudio.
I installed pulseaudio together with pulseaudio-module-bluetooth, pulseaudio-module-x11 and pavucontrol following instructions from this instructables project (http://www.instructables.com/id/Raspber ... /?ALLSTEPS).
However I seem to have a problem with Pulseaudio as I cannot get any sound playing via pulseaudio and the 3.5 mm jack.
When I call pulseaudio I get the following message
[email protected] ~ $ pulseaudio
W: [pulseaudio] server-lookup.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
W: [pulseaudio] main.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
E: [pulseaudio] bluez4-util.c: org.bluez.Manager.GetProperties() failed: org.freedesktop.DBus.Error.UnknownMethod: Method "GetProperties" with signature "" on interface "org.bluez.Manager" doesn't exist
Also pavucontrol does not work
[email protected] ~ $ pavucontrol
Unable to init server: Verbindung ist gescheitert:Verbindungsaufbau abgelehnt
I have already tried to reinstall pulseaudio by purging it and reinstalling via apt-get but this did not help.
I hope anyone can help me to get pulseaudio up and running on my RPI as I want to use it as a Bluetooth Sink for multiple devices.
Re: Audio not playing via Pulseaudio
Posted: Mon May 16, 2016 5:51 pm
by Douglas6
That Instructable is quite out-of-date. I'm not sure what you've done, or what the specified scripts have done, but the error indicates you're trying to run outdated BlueZ 4 code. Frankly, I would re-image the card and follow this tutorial: https://github.com/davidedg/NAS-mod-con ... Audio5.txt
Posted: Mon May 16, 2016 6:59 pm
by Taron
Maybe I should have been more specific.
I did not follow the instructable completely as Pulseaudio and Bluez are available in the raspian repositories now.
Basically what I did was to install a couple of packages via apt-get install:
- espeak
- mplayer
- pulseaudio
- pulseaudio-module-bluetooth
- pulseaudio-module-x11
- pavucontrol
- bluez
Then I ran the following script which :
#!/bin/bash
read -p "Bluetooth device name: " BT_NAME
function tst {
    echo "===> Executing: $*"
    if ! $*; then
        echo "Exiting scrip due to error from: $*"
        exit 1
    fi
tst cd `dirname $0`
tst sudo cp init.d/pulseaudio /etc/init.d
tst sudo chmod +x /etc/init.d/pulseaudio
tst sudo update-rc.d pulseaudio defaults
tst sudo cp init.d/bluetooth /etc/init.d
tst sudo chmod +x /etc/init.d/bluetooth
tst sudo update-rc.d bluetooth defaults
tst sudo cp init.d/bluetooth-agent /etc/init.d
tst sudo chmod +x /etc/init.d/bluetooth-agent
tst sudo update-rc.d bluetooth-agent defaults
tst sudo cp usr_local_bin/bluez-udev /usr/local/bin
tst sudo chmod 755 /usr/local/bin/bluez-udev
tst sudo cp usr_local_bin/simple-agent.autotrust /usr/local/bin
tst sudo chmod 755 /usr/local/bin/simple-agent.autotrust
tst sudo cp usr_local_bin/say.sh /usr/local/bin
tst sudo chmod 755 /usr/local/bin/say.sh
tst sudo cp usr_local_bin/bluezutils.py /usr/local/bin
if [ -f /etc/udev/rules.d/99-input.rules ]; then
sudo patch /etc/udev/rules.d/99-input.rules << EOT
*** 1 ****
--- 1,2 ----
  SUBSYSTEM=="input", GROUP="input", MODE="0660"
+ KERNEL=="input[0-9]*", RUN+="/usr/local/bin/bluez-udev"
EOT
else
tst sudo touch /etc/udev/rules.d/99-input.rules
tst sudo chmod 666 /etc/udev/rules.d/99-input.rules
sudo cat  << EOT > /etc/udev/rules.d/99-input.rules
EOT
fi
tst sudo chmod 644 /etc/udev/rules.d/99-input.rules
sudo patch /etc/bluetooth/main.conf << EOT
*** 7,8 ****
--- 7,9 ----
  #Name = %h-%d
+ Name = ${BT_NAME}
*** 11,12 ****
--- 12,14 ----
  #Class = 0x000100
+ Class = 0x20041C
*** 15,17 ****
  # 0 = disable timer, i.e. stay discoverable forever
! #DiscoverableTimeout = 0
--- 17,19 ----
! DiscoverableTimeout = 0
EOT
sudo patch /etc/pulse/daemon.conf << EOT
*** 54,57 ****
  ; resample-method = speex-float-1
! ; enable-remixing = yes
! ; enable-lfe-remixing = no
--- 54,58 ----
! resample-method = speex-fixed-2
! enable-remixing = no
! enable-lfe-remixing = no
*** 78,84 ****
  ; alternate-sample-rate = 48000
! ; default-sample-channels = 2
  ; default-channel-map = front-left,front-right
! ; default-fragments = 4
! ; default-fragment-size-msec = 25
--- 79,85 ----
! default-sample-channels = 2
! default-fragments = 10
! default-fragment-size-msec = 10
EOT
sudo patch /etc/pulse/system.pa << EOT
*** 23,25 ****
  .ifexists module-udev-detect.so
! load-module module-udev-detect
  .else
--- 23,26 ----
! #load-module module-udev-detect
! load-module module-udev-detect tsched=0
  .else
*** 57 ****
--- 58,63 ----
  load-module module-position-event-sounds
+ ### Automatically load driver modules for Bluetooth hardware
+ .ifexists module-bluetooth-discover.so
+     load-module module-bluetooth-discover
+ .endif
EOT
#sudo service bluetooth start &
#sudo service pulseaudio start &
#sudo service bluetooth-agent start &
sleep 5
echo "Done! You should reboot now"
I would like to avoid going trough the hassle of rebuilding my whole Pi-System.
However if no one can offer any alternative solution I will take the bitter pill and go with your suggestion.
Posted: Mon May 16, 2016 7:34 pm
by Douglas6
Yeah, I'm not sure what that script does exactly, but it's messing with udev rules, which it shouldn't, and running a service called 'bluetooth-agent' whatever that is. I couldn't be sure how to clean up after that.
Posted: Mon May 16, 2016 8:23 pm
by Taron
OK, then I will rebuild my PIs system from scratch and try out the tutorial you are suggesting.
I will let you know if it works or if any other problems occur.
In the meantime thanks for your help.
Posted: Mon May 16, 2016 9:11 pm
by spl23
Officially, PulseAudio requires X to be running - a standard install of PulseAudio launches the pulseaudio daemon only when the desktop is launched.
If you want to use Pulse from a command-line without launching the desktop, you will need to start the daemon manually before you attempt to connect a Bluetooth device (type "pulseaudio -D" at the CLI prompt).
I'd suggest you just download the latest Jessie image which we released last week - this contains all necessary libraries for Bluetooth audio, already installed.
Posted: Mon May 16, 2016 9:55 pm
by Douglas6
That guide includes a systemd unit to run PulseAudio system-wide as a service; no need for X. That's my preferred way to do it on the Pi. I hope the new Bluetooth GUI doesn't interfere with that.
Posted: Mon May 23, 2016 2:21 pm
by AlessandroFerri
Hi everyone,
I think the problem is due to the fact that in the Debian Jessie repository, pulseaudio is still build with bluez4 as an option, not with Bluez5 only, and not finding the corresponding library get the issue. I think that this issue should be fixed in the repository.
What do you think about?
Posted: Mon May 23, 2016 2:37 pm
by Douglas6
I'm not sure what issue you are referring to. I can say that I have a Pi2B A2DP receiver running the current Raspbian software, and it works flawlessly, I use it everyday.
Posted: Fri May 27, 2016 3:33 am
by spa46
I am having the same problem right now to run bluetooth audio.
I have been solving number of problems but I am consistently facing alternative problems like you mentioned of pulseaudio and bluez4-util.
It seems that the program of pulseaudio still holds the old bluez4-util and I am looking for alternatives or to get rid of a dependency.
Posted: Fri May 27, 2016 6:45 am
by broe23
Alsa/Pulse has been an issue for a long time. There is finally a proper post for troubleshooting it. https://help.ubuntu.com/community/Sound ... gProcedure
