mdmlv
Re: STICKY: Bluetooth not working after update - need info
Fri Feb 15, 2019 8:36 am
I just downloaded and installed "2018-11-13-raspbian-stretch-full" on a new Pi 3 B+. I am getting an error: "GDBus.Error:org.bluez.Error. Resource temporarily unavailable. Try again later." Further attempts after rebooting produced the same result. The Bluetooth earphones are recognized by the Pi and the error occurs after I use the audio menu to select the the earphones and the connection attempt fails. I am trying to used the included VLC media player with the earphones. VLC media player works fine with the analog output jack driving headphones. It seems that a number of first-time-posters start off on this thread and I have joined their ranks. Any information would be appreciated, since "temporarily unavailable" and "try again later" do not seem to indicate that I am lacking a specific driver or package.
jokhchan
Wed Mar 13, 2019 12:36 pm
Yes, I got the same problem. Help please.
jokhchan
Wed Mar 13, 2019 1:04 pm
I found the Bluetooth on another Pi installed with older version of Raspbian works fine. Only the Pi installed with the latest version of Raspbian dose not work.
pmower
Wed Mar 13, 2019 6:46 pm
I had this same issue and resolved it with the following due to the pulseaudio-module-bluetooth package not being installed.
sudo apt install pulseaudio-module-bluetooth
pulseaudio -k
pulseaudio --start
If the issue is not due to the missing package, the problem in this case is that PulseAudio is not catching up. A common solution to this problem is to restart PulseAudio. Note that it is perfectly fine to run bluetoothctl as root while PulseAudio runs as user. After restarting PulseAudio, retry to connect. It is not necessary to repeat the pairing.
jokhchan
Thu Mar 14, 2019 12:02 am
Tried as suggested above, but still not work.
jokhchan
Thu Mar 14, 2019 2:10 pm
Today, I re-install the latest version of Raspbian on my Pi 3B. After installation, I performed:
1. $ sudo apt-get update
2. $ sudo apt-get upgrade
3. copy some songs to the pi
4. pair a Bluetooth headphone
5. select the headphone from the volume control on top right hand of the panel
6. $ sudo apt install pulseaudio-module-Bluetooth
7. $ pulseaudio -k
8. $ pulseaudio --start
9. $ cvlc song.m4a
Now I can hear the song from the headphone on-and-off.
But everytime I reboot, I need to perform $ pulseaudio --start again.
Anyone please help me to fix the problem.
jokhchan
Thu Mar 14, 2019 2:51 pm
Funny thing happen, even I connect and select the Bluetooth headphone successfully, the sound still goes to the 3.5mm jack. The Bluetooth headphone has no more sound no matter what I did.
JPICentral
Location: Next to the Mojave Desert at 100+ Degree Fahrenheit
Sat May 18, 2019 11:00 pm
as requested, did bluetoothctl and it gave me the MAC and the Name of the expected bluetooth devices attached including the mouse with the problem (did not know how to copy and pste without mouse help). Did the -a option whose response was registered. This command seems to want more input though man only gives two options and no input on the commands expected. Could only delete the window. How is one supposed to use a command whose features are not included in man?
I did the update today 20190518. I have two back up sd cards with the update done on 20190504 -- I am not in the UK. When I get some down time I will switch to the 20190504 cause a Pi without a mouse is mighty difficult to use!
If I can be of any help just ask. I am traveling mouseless and internet access may present obstacles -- I will do whatever I can.
xtal256
Sun Jun 02, 2019 8:33 am
Not sure if best to post here or start a new thread, but I'm also having bluetooth problems.
Basically, I bought a Pi 3 and used the image from an older Pi 2 (so there was no bluetooth on it). Now, although though the new Pi supports bluetooth, I'm having some trouble getting it working on my image ("Raspbian GNU/Linux 9 (stretch)", upgraded from jessie).
On startup, bluetooth is not enabled:
$ service bluetooth status
● bluetooth.service - Bluetooth service
   Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
   Active: inactive (dead)
     Docs: man:bluetoothd(8)
$ service hciuart status
● hciuart.service
   Loaded: masked (/dev/null; bad)
I can start the bluetooth service:
$ sudo modprobe btusb
$ sudo systemctl start bluetooth
   Active: active (running) since Sun 2019-06-02 18:26:20 AEST; 15s ago
 Main PID: 1958 (bluetoothd)
   Status: "Running"
   CGroup: /system.slice/bluetooth.service
           └─1958 /usr/lib/bluetooth/bluetoothd
Jun 02 18:26:20 Raspberry-Pi systemd[1]: Starting Bluetooth service...
Jun 02 18:26:20 Raspberry-Pi bluetoothd[1958]: Bluetooth daemon 5.43
Jun 02 18:26:20 Raspberry-Pi systemd[1]: Started Bluetooth service.
Jun 02 18:26:20 Raspberry-Pi bluetoothd[1958]: Starting SDP server
Jun 02 18:26:20 Raspberry-Pi bluetoothd[1958]: Bluetooth management interface 1.14 initialized
But when I try to start hciuart it says:
Failed to start hciuart.service: Unit hciuart.service is masked.
And bluetoothctl says "No default controller available" when I try to do anything with it.
I have read many other posts by people who have problems with bluetooth, and they all seem slightly different to mine. I might find answers somewhere in this 7 page thread, but I'd much appreciate it if someone could point me in the right direction.
thanks
Douglas6
Sun Jun 02, 2019 1:47 pm
Yes, you should have started a new thread. This one yearns to be locked.
You can try unmasking the hciuart service:
sudo systemctl unmask hciuart
Or you could try uninstalling bluetooth and pi-bluetooth and re-installing. But the best bet is to flash a new version of Raspbian Stretch.
xtal256
Tue Jun 04, 2019 1:07 am
Thanks.
I did that, and it said "Removed /etc/systemd/system/hciuart.service". Now the service cannot be found.
How do I re-install this service?
jokhchan
Fri Jul 19, 2019 11:39 am
After a few months try and fail, I think I need to give up. Before that, I try to go through some replies/advises one more time from this forum, luckily I found the information from the following link, I tell myself I'll try it with my last effort, if it fail, I'll totally give up on this topic and use audio cable to connect my Bluetooth dongle.
I refer to the following link to solve the problem
http://youness.net/raspberry-pi/how-to- ... berry-pi-3
In order to eliminate those I've done before to solve the problem, I install the OS (NOOBS_v3_2_0) from scratch and do the followings after installation:
3. $ sudo apt-get autoremove
4. $ sudo reboot
5. Copy some songs to the pi
6. $ sudo apt-get install pulseaudio pulseaudio-module-bluetooth
7. $ dpkg -l pulseaudio pulseaudio-module-bluetooth
8. Connect the bluetooth speaker
9. $ sudo killall bluealsa
10. $ pulseaudio --start
11 Play songs with the bluetooth speaker, it works fine.
12. I've try to reboot the pi and play the Bluetooth speaker for a few times, it still works fine. I think I've solved the problem.
Although I can use my Bluetooth speaker now, but I still not understand what is the reason, please tell me why it happen if you know. Thanks.
xjust
Tue Aug 06, 2019 3:42 pm
hello
bluetooth should work on raspberry pi 4 default installation of raspbian buster ?
i think i might have a defective board if so..
● hciuart.service loaded failed failed Configure Bluetooth Modems connected by UART
tristone
Sat Aug 17, 2019 6:52 pm
Hi.
Yes it works out of the box. I had the same issue and spent countless hours trying to make it work.
Then I got replacement board and it started to wok in about a minute
