Page 1 of 2
Bluetooth on latest Raspian version is just not working.
Posted: Sat May 14, 2016 3:28 am
by Jw321123
I'm new to Linux, btw, and on the latest version of Raspian.
My Raspberry Pi 3 can connect briefly to my Macbook Air 2013, but once I accept the connection on the Raspberry Pi, I get this error:
"GDBus.Error:org.bluez.Error.Failed: No such file or directory. Try to connect manually."
(The Raspberry Pi appears on my macbook, but the macbook which is discoverible does not appear on my raspberry pi)
I also tried connecting from the terminal, that didn't work either.
Here are the bluetooth-related packages I have, am I missing any or are they interfering with each other?
(p.s. this was done with a package search in Synaptic
-Bluez
-Bluez-firmware
-firmware-atheros
-firmware-reaktek
-libbluetooth3
-libcwiid1
-libmm-glib0
-modemmanager
-obex-data-server
-pi-bluetooth
-pulseaudio-module-bluetooth
Hopefully I do not have a faulty Raspberry Pi, i'm praying
Re: Bluetooth on latest Raspian version is just not working.
Posted: Sat May 14, 2016 5:45 pm
by Jw321123
BUMP:
I think I can justify this because well..... no one responded
Posted: Sat May 14, 2016 5:50 pm
by jbeale
I don't know much about Bluetooth but what are you trying to do? According to the most recent blog post about bluetooth, it can connect to most any BT device, but it cannot do anything useful unless it is a HID model (like mouse or keyboard) or Audio device (headphones or speakers). What type of device is your Mac Air?
Posted: Sat May 14, 2016 5:59 pm
by Dis93
I sorta agree with jbeale.. I can network with my Mac, my PC via standard networking... Bluetooth is slow and limited.. for connecting to phones, or connecting a kb or mouse, or maybe a BT speakers it's fine.. otherwise why bother?
Posted: Sat May 14, 2016 6:17 pm
by Jw321123
My Macbook Air 2013 is 11-inch and 128GB. Of course, it also has bluetooth.
The BT Speaker that I am trying to connect to is the MIni Jambox from Jawbone. That works fine with other devices, too.
I'm trying to transfer and receive files to my Macbook Air, and I am trying to pump some jams to my Bluetooth speaker.
EDIT: I also tried connecting to a Microsoft Arc Mouse SE (a bluetooth mouse), it said it "Paired successfully, but this device has no services which can be used with the Raspberry Pi"
Posted: Sat May 14, 2016 6:32 pm
by Rive
had this same kind of error after upgrade
"GDBus.Error:org.bluez.Error.Failed:..."
Resolved it by restoring 4.1 and then doing dist-upgrade again. Works fine now.
see:
viewtopic.php?p=973744#p973744
Also, you should be aware there is a major performance bug in the new release that affects the uart (which is what the bluetooth uses). The Pi has computational degradation to the tune of approx 1 billion operations per second.
viewtopic.php?p=974088#p974088
Posted: Sat May 14, 2016 6:40 pm
by Dis93
I bumped my kernel to 4.4.10, Rive.
I have to agree with OP, BT seems funky. I've left it scanning for 30 minutes, it did see my two phones, it can't now. It has picked up various devices my neighbours have, and my Mac but can't connect like OPs. Can't see my phones half a metre away ( that's about 1.6 foot away for those in the USA)
Posted: Sat May 14, 2016 6:41 pm
by Jw321123
Again, i'm new to Linux so.... I don't get that at all. Can you explain in further detail? Sorry
Posted: Sat May 14, 2016 8:15 pm
by Rive
Jw321123 wrote:Again, i'm new to Linux so.... I don't get that at all. Can you explain in further detail? Sorry
What specifically would you like elaboration on?
Posted: Sat May 14, 2016 8:19 pm
by spl23
There's no point connecting to a MacBook Air with the latest Jessie release - as I said in the blog post, we support UI devices (mice, keyboards etc) and speakers and headsets. Your Mac is none of those, so while you can pair with it, you won't be able to establish a connection to it, as the Pi has no client services which can make use of anything the MacBook has to offer.
In future we might add the ability to share a network connection over Bluetooth, but it's quite a lot of work to enable that on the Pi, so we haven't had a chance to do it yet!
The Arc Mouse SE is a BTLE device, which is a newer version of the Bluetooth protocol, and software support for that is shaky, to say the least; the BlueZ stack treats BTLE devices completely differently from traditional BT devices. Until we get a better handle on BTLE, you're very unlikely to be able to use that mouse with your Pi. (Note that this isn't a Pi-specific problem - my Mac mini can't connect to BTLE devices either...)
Posted: Sat May 14, 2016 8:30 pm
by Douglas6
@spl23, you could look into adding support for OBEX and Serial Port Profile. I believe blueman has limited file transfer support.
Posted: Sat May 14, 2016 8:42 pm
by spl23
Douglas6 wrote:@spl23, you could look into adding support for OBEX and Serial Port Profile. I believe blueman has limited file transfer support.
It does, but file transfer is not that common on other devices; Apple devices tend not to allow it, for example, although Android tablets do. A huge chunk of code is required on the Pi to enable OBEX - I did look into doing it, but wondered if the demand was there to justify it, which is one of the reasons we launched with the current limited BT functionality. Once we get a handle on what other features are wanted (and by how many people...) we can work out where best to apply our limited amount of programming effort (i.e. me...) to add the bits people want.
Posted: Sat May 14, 2016 8:46 pm
by Rive
BT file transfer is ideal (for Windows and Android- which are the dominant OSes atm). It is a PITA to have to move around an sdcard, or flash drive between devices. I didn't realize the new bt ui is lacking in that regard. That sucks.
Posted: Sat May 14, 2016 8:58 pm
by gkreidl
Rive wrote:A huge chunk of code is required on the Pi to enable OBEX - I did look into doing it, but wondered if the demand was there to justify it, which is one of the reasons we launched with the current limited BT functionality.
You have WiFi and / or ethernet networking. Why do you want to use BT for it?
Posted: Sat May 14, 2016 9:00 pm
by Dis93
+1 This
Posted: Sat May 14, 2016 9:03 pm
by spl23
Rive wrote:I didn't realize the new bt ui is lacking in that regard. That sucks.
In that case, you are very welcome to try writing a C implementation of OBEX over Bluetooth with a GTK UI that we can integrate. My estimate is that it is a couple of thousand lines of code and probably a couple of weeks work, plus testing...
In all seriousness, in an ideal world, we would support anything and everything people want to do on Pi - in the real world, we are a very small software team, and we have to prioritise - if I spend a few weeks on OBEX over BT, that's a few weeks I don't spend on something else.
If people really want OBEX, then they can install blueman and use it from there for the time being - blueman should happily coexist with the inbuilt BT UI.
Posted: Sat May 14, 2016 9:05 pm
by Douglas6
Bluetooth file transfer is not that difficult on the Pi, it just requires some command line finagling.
WiFi is easier.
Posted: Sat May 14, 2016 9:08 pm
by Dis93
Douglas6 wrote:Bluetooth file transfer is not that difficult on the Pi, it just requires some command line finagling.
WiFi is easier.
Lots of internet points for the use of the word finagling.
Also , use wifi.
Posted: Sat May 14, 2016 9:12 pm
by Rive
Not all my devices are setup for LAN sharing (hardware and software firewalls), and not all my devices are even on the same network ( I have multiple physical and virtual interfaces (5 currently), some with ap isolation, on my wireless router...
Most of the mobile and Windows devices (5), are setup for BT connectivity & transfers though, which is way more convenient than configuring router interfaces, firewalls, and Windows sharing privileges.
Posted: Sat May 14, 2016 9:15 pm
by Rive
spl23 wrote:- in the real world, we are a very small software team, and we have to prioritise - if I spend a few weeks on OBEX over BT, that's a few weeks I don't spend on something else.
Yeah, I kinda figured that since someone missed that glaring uart bug in the new raspbian image.
Posted: Sat May 14, 2016 9:20 pm
by spl23
Rive wrote:Yeah, I kinda figured that since you guys missed that glaring uart bug in the new image.
Actually, we didn't miss it - we just didn't discover it until a few days before the release, and made the decision that it wasn't worth delaying the release for. In reality, the number of people who will even notice it is tiny. It is already fixed in the latest kernel and firmware - the usual method for updating kernel will get the fix for anyone who desperately needs it. Which is hardly anyone.
Posted: Sat May 14, 2016 9:21 pm
by Rive
spl23 wrote:Rive wrote:Yeah, I kinda figured that since you guys missed that glaring uart bug in the new image.
Yes you did.
I was the one who reported there was an issue
( that there was performance degradation to the tune of approx 1 billion operations per sec), and had I not, you would have 'missed' it.
nearly an order of magnitude more interrupts per second and context switches per second in 4.4.9 compared to 4.1...unused uart being left with an interrupt asserted but no interrupt handler to clear it...
Posted: Sat May 14, 2016 9:59 pm
by Dis93
Rive wrote:
Yes you did.
Me-ow.
https://www.youtube.com/watch?v=7syJJrsmrts
Posted: Sun May 15, 2016 4:10 pm
by jamesh
Rive wrote:spl23 wrote:- in the real world, we are a very small software team, and we have to prioritise - if I spend a few weeks on OBEX over BT, that's a few weeks I don't spend on something else.
So glaring in fact that thousands of people reported it...oh.....hold on.....
Posted: Thu Sep 29, 2016 2:17 pm
by Fanch
I had the same problem. The OS and software were updated, but not the firmware.
I has been solved after a "sudo rpi-update".
