rdb9879
Mouse and Keyboard non responsive after boot
Sat May 14, 2016 1:32 am
Just got my first raspberry pi 3 (or any raspberry pi for that matter) so please forgive me if I'm dumb. I did the initial setup using NOOBS lite (the full NOOBS download gave an error saying the compressed file was corrupt)... During the OS install, my mouse and keyboard both worked fine as I had to type in my WIFI password and I could see the mouse move.
When raspbian boots, I see the raspberry pi logo and the menus on the top taskbar, the mouse cursor is in the middle of the screen but it doesn't move at all and the keyboard also seems unresponsive to any presses.
I tried plugging in a different mouse (wireless USB dongle), with no luck. I tried booting with just the mouse installed, then just the keyboard installed, but I can't seem to get any response.
I'm using a USB-power wall wart that I use to charge my phone, spec'd for 2 amps. When I'm in the boot menu, I can hit the num-lock and caps-lock on my keyboard and the appropriate LEDs turn on, but when the desktop is showing, I can't get the LEDs to appear. I tried unplugging and replugging the usb connections and booted multiple times.
Finally, I'm using an HDMI to DVI cable to connect to the monitor, which is the best I could do.
Any advice?
Rive
Re: Mouse and Keyboard non responsive after boot
Sat May 14, 2016 4:09 am
Get a better power supply, and download Jessie full?
DNPNWO
rdb9879
Sat May 14, 2016 2:05 pm
Why would I need a better power supply if it's sped'd for 2A output and the mouse and keyboard was working working fine during boot?
I seemed to have solved this myself by simply going into "recovery" mode during boot and reinstalling the entire raspbian OS. Then, everything worked fine!
Ffjohn
Sun May 15, 2016 3:31 am
I have this same problem, boot loader/noobs everything works fine, once X starts I have no keyboard or mouse. Tried all combinations of 2.5A power supplies 2 keyboards and 3 mice with no changes. I also tried running recovery mode and this did not fix the problem. Anyone out there have any other ideas? The boot sequence scrolls to fast to read compleatly but I did see a "failed to load...." Something to do with the kernel. I'm downloading a fresh copy from RPi website right now in case the preloaded copy was corrupt. Any other ideas?
Ffjohn
Mon May 16, 2016 4:10 am
DLed fresh copy of NOOBS. Solved the problem.
