Re: Connect bluetooth speaker failed
Posted: Thu May 12, 2016 2:44 pm
by Douglas6
Is the device paired and trusted? In bluetoothctl, what does 'info FC:58:FA:40:46:A8' tell you?
Posted: Thu May 12, 2016 3:30 pm
by Douglas6
That looks good to me. You might want to look in /var/log/syslog for any information. Bluetooth can be flaky. I'd keep the speaker close by, and try the connect command several times. You might want to remove the device in bluetoothctl and pair again with it.
No those files have no effect on Bluetooth connections, and don't need to be changed for using a Bluetooth speaker.
[EDIT: You do have PulseAudio and the Bluetooth modules installed?
sudo apt-get install pulseaudio pulseaudio-module-bluetooth
Shouldn't affect connecting, but you'll need them for streaming.]
Posted: Thu May 12, 2016 6:02 pm
by jivex5k
I posted how I got a bluetooth speaker working with pulseaudio and a raspberry pi 3 here:
viewtopic.php?f=28&t=147919
I can't get more than one speaker to connect though.
It's using raspbian jessie though, which has bluez 5 installed. It sounds like you have bluez 4 because the audio.conf file was removed in bluez 5.
Re: (SOLVED)Connect bluetooth speaker failed
Posted: Tue Oct 25, 2016 10:06 pm
by javsim
I have the same problem to connect my headset phones... could you tell me how to uninstall bluez 5 and install bluez 4?
Thanks a lot!!!
