Now I see what I have got myself into!
http://elinux.org/RPi_Noob_Guides_for_W ... 16-18_beta
"Issues with new image
I'm posting this as a heads up I just downloaded the torrent of 201-07-15-wheezy-raspbian off of a torrent checksum ok and it appears to install to SD.
On a clean first time boot it appears not to detect the live (yes it is switched on) HDMI it's on and playing via a Blind Login using putty for an ssh connection so the image works and it appears to be good for composite but it appears the HDMI is not playing for the first time out of the SD card.
Once I have run raspi-config off of a putty blind login or composite screen it fires no problem both to command line and to startx if thats chosen from the raspi-config but oly on re-boot HDMI is still not live after a shutdown.
The earlier version was working and I do know my way round this as can be seen from the noob writeups contained in the links on this page.
Obviously I will have to do some more testing but I thought this had to be worth a heads up on the off chance it's not something I'm doing.
Ok done an additional test confirmation the composite fires up just as it did for the earlier version going directly to the raspi-config menu but it appears to be only playing on the composite output not hdmi unless you reboot or engage the startx desktop option in raspi-config.
The previous version went to composite if you did not have HDMI plugged in.
Note it works once you have chosen the Desktop option but if you can't see a command line screen you can't view the raspi-config script to activate it.
I've found something else once you have run raspi-config and done a reboot it plays ok if you reboot however if you shutdown it won't restart to HDMI.
But it re-starts and if you blind login using putty and sudo reboot it then starts with a live HDMI screen (go figure) it also still has the microscopic font. "
This definately is not something for a newbie!!!
I tried editing the config.txt file and booting in the safe mode, but that didn't work either.
As for the blind login, I have 3 PC, 3 NAS, 3 printers, 2 iPads, 2 iPhone, 3 Switches and 2 Wirelss Access Points. Does anybody want to try guessing the IP address?
The only thing I think of is go back to the 2012-06-18 beta and see if it works, or I could wait 6 months and maybe there will be a stable Raspbian OS.
