bmandudeman
Raspberry Pi 3 Not Displaying Through HDMI Properally
Sun May 08, 2016 3:36 pm
Hello! I am sure that some of you have seen problems like these and have come up with solutions that work. The problem that I am having is that no matter what extra lines of configuration I add, I see the opening splash screen (The color testing square thing) then my monitor says that it is going to sleep. I am running BerryBoot on my Pi, I also have an SD card with OSMC on it that works perfectly with the monitor. Thank you for your help!
Note:
Here are the lines of configuration I have added:
hdmi_force_hotplug=1
config_hdmi_boost=4
hdmi_drive=2
Thanks again.
Rive
Re: Raspberry Pi 3 Not Displaying Through HDMI Properally
Sun May 08, 2016 8:09 pm
Rasbian Jessie?
I have seen that a few times on my DVI-D monitor (usually after I messed with the OpenGL driver and set gpu_mem= too high.
Try this:
open your /config.txt in any text editor, and comment (#) out everything in there, then see if you boot up.
DNPNWO
bmandudeman
Mon May 09, 2016 10:18 pm
Ok, I think I know where I wen't wrong. I set my gpu_mem to 128. I have yet to try and see if it works. Thank you for your support
