I received this starter Raspberry Pi 3 starter pack, and opened it today:
https://www.amazon.co.uk/Create-Raspber ... +kit&psc=1
My first attempt to boot it up went fine, but I decided I wanted to put it in the case before using it any further. I shut it down using the shutdown option in the top left menu, and removed all cables. Next time I tried booting it up after carefully inserting it into the case, nothing came up on the screen. I've tried removing it from the case, and booting it up with another display but still no luck. I had a read of the booting sticky on here, which mentions the significance of the LEDs. I have a solid red LED only, which if I'm not mistaken suggests an issue with reading the SD card.
Is it possible that an official SD with the OS preloaded could have become corrupted after only one use? Where do I go from here? I am a complete beginner to the Raspberry Pi and was very much relying on it working with a straightforward set-up.
Thanks in advance for any advice.
