dasfreak
No sound from Pi after trying usual debugging steps
Sat May 07, 2016 11:10 am
I'm not getting any sound from my Pi after trying a number of debug methods. I tried a different sd card running minibian and did manage to get sound working. Once I transferred those settings to retropie I lost sound again.
I'm not entirely sure where to go next in order to get basic sound working. Because it was working on an alternate install I'm trying here before going to the general raspberry pi forums.
Model: Pi3
Retropie: 3.7
Kernel:Linux 4.4.8-v7+ armv7l GNU/Linux
/boot/config.txt
Note I've used the hdmI_mode and hdmi_group numbers from where I got it working using Raspbian using the output from tvservice
dtparam=audio=on
hdmi_group=2
hdmi_mode=9
hdmi_drive=2
modules
$ lsmod | grep snd
snd_bcm2835          20511  0
snd_pcm              75698  1 snd_bcm2835
snd_timer            19160  1 snd_pcm
snd                  51844  3 snd_bcm2835,snd_timer,snd_pcm
Troubleshooting steps
Note not using sudo
  1. Run /opt/vc/src/hello_pi/hello_audio/hello_audio.bin 1
    No sound
  2. Run aplay /usr/share/sounds/alsa/Front_Center.wav
    No sound
  3. Run amixer -c 0 cset numid=3 2
    then sudo aplay /usr/share/sounds/alsa/Front_Center.wav
    No sound
From some research, looking at the TV properties can help.
$ tvservice -d /tmp/tvservice
$ /opt/vc/bin/edidparser /tmp/tvservice
Enabling fuzzy format match...
Parsing /tmp/tvservice...
HDMI:EDID version 1.3, 1 extensions, screen size 160x90 cm
HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
HDMI:EDID found monitor name descriptor tag 0xfc
HDMI:EDID monitor name is LCD_TV
HDMI:EDID found monitor range descriptor tag 0xfd
HDMI:EDID monitor range offsets: V min=0, V max=0, H min=0, H max=0
HDMI:EDID monitor range: vertical is 48-62 Hz, horizontal is 14-68 kHz, max pixel clock is 150 MHz
HDMI:EDID monitor range does not support GTF
HDMI:EDID found preferred DMT detail timing format: 1360x768p @ 60 Hz (39)
HDMI:EDID found DMT detail timing format: 1280x720p @ 60 Hz (85)
HDMI:EDID established timing I/II bytes are 21 08 00
HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
HDMI:EDID standard timings block x 8: 0x3140 4540 6140 8180 0101 0101 0101 0101
HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz (4:3) in standard timing 0
HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz (4:3) in standard timing 1
HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz (4:3) in standard timing 2
HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 3
HDMI:EDID parsing v3 CEA extension 0
HDMI:EDID monitor support - underscan IT formats:no, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:0
HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
HDMI:EDID found CEA detail timing format: 1920x1080i @ 60 Hz (5)
HDMI:EDID found CEA detail timing format: 1280x720p @ 50 Hz (19)
HDMI:EDID found CEA detail timing format: 1920x1080p @ 50 Hz (31)
HDMI:EDID found CEA detail timing format: 1920x1080p @ 60 Hz (16)
HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
HDMI:EDID found CEA format: code 2, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz
HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
HDMI:EDID found CEA format: code 6, 1440x480i @ 60Hz
HDMI:EDID found CEA format: code 7, 1440x480i @ 60Hz
HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz
HDMI:EDID found CEA format: code 17, 720x576p @ 50Hz
HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz
HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
HDMI:EDID found CEA format: code 21, 1440x576i @ 50Hz
HDMI:EDID found CEA format: code 22, 1440x576i @ 50Hz
HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz
HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16|20|24 bits
HDMI:EDID found HDMI VSDB length 6
HDMI:EDID HDMI VSDB has physical address 1.0.0.0
HDMI:EDID HDMI VSDB supports AI:yes, dual link DVI:no
HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:no 30-bit:no DC_yuv444:no
HDMI:EDID HDMI VSDB has no latency information
HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
HDMI:EDID best score mode initialised to DMT (4) 640x480p @ 60 Hz with pixel clock 25 MHz (score 0)
HDMI:EDID best score mode is now CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 43432)
HDMI:EDID best score mode is now CEA (2) 720x480p @ 60 Hz with pixel clock 27 MHz (score 45736)
HDMI:EDID CEA mode (3) 720x480p @ 60 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID best score mode is now CEA (4) 1280x720p @ 60 Hz with pixel clock 74 MHz (score 80296)
HDMI:EDID DMT mode (4) 640x480p @ 60 Hz with pixel clock 25 MHz has a score of 61864
HDMI:EDID best score mode is now CEA (5) 1920x1080i @ 60 Hz with pixel clock 74 MHz (score 3649416)
HDMI:EDID CEA mode (6) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 35368
HDMI:EDID CEA mode (7) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 35368
HDMI:EDID DMT mode (9) 800x600p @ 60 Hz with pixel clock 40 MHz has a score of 82600
HDMI:EDID CEA mode (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz has a score of 2149416
HDMI:EDID DMT mode (16) 1024x768p @ 60 Hz with pixel clock 65 MHz has a score of 119370
HDMI:EDID CEA mode (17) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID CEA mode (18) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID CEA mode (19) 1280x720p @ 50 Hz with pixel clock 74 MHz has a score of 3071080
HDMI:EDID best score mode is now CEA (20) 1920x1080i @ 50 Hz with pixel clock 74 MHz (score 4128680)
HDMI:EDID CEA mode (21) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 35368
HDMI:EDID CEA mode (22) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 35368
HDMI:EDID CEA mode (31) 1920x1080p @ 50 Hz with pixel clock 148 MHz has a score of 2628680
HDMI:EDID DMT mode (35) 1280x1024p @ 60 Hz with pixel clock 108 MHz has a score of 182286
HDMI:EDID best score mode is now DMT (39) 1360x768p @ 60 Hz with pixel clock 85 MHz (score 5188004)
HDMI:EDID DMT mode (85) 1280x720p @ 60 Hz with pixel clock 74 MHz has a score of 4610592
HDMI:EDID preferred mode remained as DMT (39) 1360x768p @ 60 Hz with pixel clock 85 MHz
HDMI:EDID has HDMI support and audio support
edid_parser exited with code 0
dasfreak
Re: No sound from Pi after trying usual debugging steps
Sun May 08, 2016 10:20 am
Sort of solved this. I installed Retropie on top of Raspbian Jessie lite and it resolved all of the sound issues for me.
