Tried it on Pi 2 and 3 with different distributions, Raspbian Jessie, Raspian Wheezy, OpenElec 6. Starting the X-Server or hello_video.bin on the Raspi also gives no Image and I could not see any meaningful log messages.
Definining a custom video mode and then using it also does not seem to make a difference. Tried 1920x1080 60Hz and also 1080x1920 60Hz. What's strange is, that when I don't have HDMI connected, I get the DMT mode 87 displayed in tvservice output, with the display connected it's not there anymore.
The display seems to be a bit weird in that it is a 1080x1920 display, on my Thinpkad X220 with Intel graphics I had to change it to landscape mode in Linux and Windows but apart from that it works fine.
Here is the output from tvservice and edid-parser on the Raspberry:
pi@raspberrypi:~$ tvservice -m CEA
Group CEA has 9 modes:
(prefer) mode 1: 640x480 @ 60Hz 4:3, clock:25MHz progressive
mode 2: 720x480 @ 60Hz 4:3, clock:27MHz progressive
mode 3: 720x480 @ 60Hz 16:9, clock:27MHz progressive
mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
mode 6: 720x480 @ 60Hz 4:3, clock:27MHz x2 interlaced
mode 7: 720x480 @ 60Hz 16:9, clock:27MHz x2 interlaced
mode 17: 720x576 @ 50Hz 4:3, clock:27MHz progressive
mode 18: 720x576 @ 50Hz 16:9, clock:27MHz progressive
mode 19: 1280x720 @ 50Hz 16:9, clock:74MHz progressive
pi@raspberrypi:~$ tvservice -m DMT
Group DMT has 1 modes:
mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
pi@raspberrypi:~$ tvservice -s
state 0x120006 [DVI CEA (1) RGB lim 4:3], 640x480 @ 60.00Hz, progressive
pi@raspberrypi:~$ /opt/vc/bin/tvservice -d edid.dat; /opt/vc/bin/edidparser edid.dat
Written 256 bytes to edid.dat
Enabling fuzzy format match...
Parsing edid.dat...
HDMI:EDID version 1.3, 1 extensions, unknown aspect ratio
HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
HDMI:EDID found monitor name descriptor tag 0xfc
HDMI:EDID monitor name is TopfoisonLCD
HDMI:EDID found monitor range descriptor tag 0xfd
HDMI:EDID monitor range offsets: V min=0, V max=0, H min=0, H max=0
HDMI:EDID monitor range: vertical is 29-61 Hz, horizontal is 15-180 kHz, max pixel clock is 290 MHz
HDMI:EDID monitor range does not support GTF
HDMI:EDID failed to find a matching detail format for 1080x1920p hfp:118 hs:4 hbp:118 vfp:4 vs:4 vbp:3 pixel clock:152 MHz
HDMI:EDID calculated refresh rate is 60 Hz
HDMI:EDID guessing the format to be 1080x1920p @60 Hz
HDMI:EDID found unknown detail timing format: 1080x1920p hfp:118 hs:4 hbp:118 vfp:4 vs:4 vbp:3 pixel clock:152 MHz
HDMI:EDID failed to find a matching detail format for 1080x1920p hfp:118 hs:4 hbp:118 vfp:4 vs:4 vbp:3 pixel clock:76 MHz
HDMI:EDID calculated refresh rate is 30 Hz
HDMI:EDID guessing the format to be 1080x1920p @30 Hz
HDMI:EDID found unknown detail timing format: 1080x1920p hfp:118 hs:4 hbp:118 vfp:4 vs:4 vbp:3 pixel clock:76 MHz
HDMI:EDID established timing I/II bytes are 00 00 00
HDMI:EDID standard timings block x 8: 0x0101 0101 0101 0101 0101 0101 0101 0101
HDMI:EDID parsing v3 CEA extension 0
HDMI:EDID monitor support - underscan IT formats:no, basic audio:no, yuv444:no, yuv422:no, #native DTD:4
HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz
HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 2, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 7, 1440x480i @ 60Hz
HDMI:EDID found CEA format: code 6, 1440x480i @ 60Hz
HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16 bits
HDMI:EDID found HDMI VSDB length 5
HDMI:EDID HDMI VSDB has physical address 1.0.0.0
HDMI:EDID HDMI VSDB has no extension fields
HDMI:EDID adding mandatory support for DMT (4) 640x480p @ 60Hz
HDMI:EDID adding mandatory support for CEA (17) 720x576p @ 50Hz
HDMI:EDID adding mandatory support for CEA (18) 720x576p @ 50Hz
HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
HDMI:EDID no known preferred format has been set
HDMI:EDID filtering preferred group has been changed from Invalid to CEA
HDMI:EDID best score mode initialised to CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 0)
HDMI:EDID best score mode is now CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 61864)
HDMI:EDID best score mode is now CEA (2) 720x480p @ 60 Hz with pixel clock 27 MHz (score 66472)
HDMI:EDID CEA mode (3) 720x480p @ 60 Hz with pixel clock 27 MHz has a score of 66472
HDMI:EDID best score mode is now CEA (4) 1280x720p @ 60 Hz with pixel clock 74 MHz (score 135592)
HDMI:EDID DMT mode (4) 640x480p @ 60 Hz with pixel clock 25 MHz has a score of 18432
HDMI:EDID CEA mode (6) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID CEA mode (7) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID CEA mode (17) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 66472
HDMI:EDID CEA mode (18) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 66472
HDMI:EDID CEA mode (19) 1280x720p @ 50 Hz with pixel clock 74 MHz has a score of 117160
HDMI:EDID preferred mode is updated to CEA (4) 1280x720p @ 60 Hz with pixel clock 74250000 Hz
HDMI:EDID has HDMI support and no audio support
edid_parser exited with code 0Here is the output of X.Org on a Debian Jessie Installation on a Thinkpad (where it works without problems after setting it to landscape mode):
[ 3.916] (II) intel(0): EDID for output HDMI3
[ 3.916] (II) intel(0): Manufacturer: TFS Model: 1080 Serial#: 808530224
[ 3.916] (II) intel(0): Year: 2014 Week: 42
[ 3.916] (II) intel(0): EDID Version: 1.3
[ 3.916] (II) intel(0): Digital Display Input
[ 3.916] (II) intel(0): Indeterminate output size
[ 3.916] (II) intel(0): Gamma: 2.20
[ 3.916] (II) intel(0): No DPMS capabilities specified
[ 3.917] (II) intel(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 3.917] (II) intel(0): First detailed timing is preferred mode
[ 3.917] (II) intel(0): redX: 0.638 redY: 0.335 greenX: 0.302 greenY: 0.604
[ 3.917] (II) intel(0): blueX: 0.153 blueY: 0.058 whiteX: 0.307 whiteY: 0.322
[ 3.917] (II) intel(0): Manufacturer's mask: 0
[ 3.917] (II) intel(0): Supported detailed timing:
[ 3.917] (II) intel(0): clock: 152.9 MHz Image Size: 74 x 132 mm
[ 3.917] (II) intel(0): h_active: 1080 h_sync: 1198 h_sync_end 1202 h_blank_end 1320 h_border: 0
[ 3.917] (II) intel(0): v_active: 1920 v_sync: 1924 v_sync_end 1928 v_blanking: 1931 v_border: 0
[ 3.917] (II) intel(0): clock: 76.5 MHz Image Size: 74 x 132 mm
[ 3.917] (II) intel(0): Monitor name: TopfoisonLCD
[ 3.917] (II) intel(0): Ranges: V min: 29 V max: 61 Hz, H min: 15 H max: 180 kHz, PixClock max 295 MHz
[ 3.917] (II) intel(0): Number of EDID sections to follow: 1
[ 3.917] (II) intel(0): EDID (in hex):
[ 3.917] (II) intel(0): 00ffffffffffff0050d3801030313130
[ 3.917] (II) intel(0): 2a180103800000780a777aa3554d9a27
[ 3.917] (II) intel(0): 0e4e5200000001010101010101010101
[ 3.917] (II) intel(0): 010101010101bd3b38f040800b707604
[ 3.917] (II) intel(0): 44004a8400000018de1d38f040800b70
[ 3.917] (II) intel(0): 760444004a8400000018000000fc0054
[ 3.917] (II) intel(0): 6f70666f69736f6e4c43440a000000fd
[ 3.917] (II) intel(0): 001d3d0fb41d000a20202020202001f7
[ 3.917] (II) intel(0): 02031a04470413030207060123090701
[ 3.917] (II) intel(0): 8301000065030c001000bd3b38f04080
[ 3.917] (II) intel(0): 0b70760444004a8400000018bd3b38f0
[ 3.917] (II) intel(0): 40800b70760444004a8400000018bd3b
[ 3.917] (II) intel(0): 38f040800b70760444004a8400000018
[ 3.917] (II) intel(0): bd3b38f040800b70760444004a840000
[ 3.917] (II) intel(0): 00180000000000000000000000000000
[ 3.917] (II) intel(0): 00000000000000000000000000000034
[ 3.917] (II) intel(0): Printing probed modes for output HDMI3
[ 3.918] (II) intel(0): Modeline "1080x1920"x60.0 152.93 1080 1198 1202 1320 1920 1924 1928 1931 -hsync -vsync (115.9 kHz eP)
[ 3.918] (II) intel(0): Modeline "1080x1920"x30.0 76.46 1080 1198 1202 1320 1920 1924 1928 1931 -hsync -vsync (57.9 kHz e)
[ 3.918] (II) intel(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 3.918] (II) intel(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 3.918] (II) intel(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 3.918] (II) intel(0): Modeline "1440x480i"x60.0 27.03 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.8 kHz e)
[ 3.918] (II) intel(0): Modeline "1440x480i"x59.9 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 3.918] (II) intel(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 3.918] (II) intel(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 3.918] (II) intel(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 3.918] (II) intel(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
