mquinteiro
DHCP starts after reconnection in a static interface
Fri May 06, 2016 1:57 pm
I have a static eth0 configuration, everything goes right until I unplug the ethernet connector and plug it again, after that dhcp starts over eth0 and my dhcp server gives a new IP to PI2, so I lose the static IP.
I'm using raspbian jessie. Here is my interfaces file (actually I have one pseudo interface and both have the same problem).
[email protected]# cat /etc/network/interfaces
auto lo eth0 eth0:1
iface lo inet loopback
iface eth0 inet static
address 10.5.0.3
netmask 255.255.255.0
iface eth0:1 inet static
address 192.168.100.27
gateway 192.168.100.24
#allow-hotplug wlan0
#iface wlan0 inet manual
#wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
#iface default inet dhcp
Help welcome.
Thanks!
ShiftPlusOne
Re: DHCP starts after reconnection in a static interface
Fri May 06, 2016 4:20 pm
Could you most the output of 'sudo journalctl' after that happens?
Edit: Also, that's not the correct way to set the static IP on the jessie image, but I am curious to see what actually goes wrong when you do it that way.
Fri May 06, 2016 9:05 pm
ShiftPlusOne wrote: Edit: Also, that's not the correct way to set the static IP on the jessie image, but I am curious to see what actually goes wrong when you do it that way.
It's well documented that doing it that way (without disabling dhcpcd) means that each active interface gets two IP addresses, one done with the static stuff in the interfaces file, one done by dhcpcd if there's an active DHCP server on the subnet.
The interfaces file even tells you what to do to avoid that problem.
This is a doctor free zone.
ShiftPlusOne
Fri May 06, 2016 9:37 pm
The original init.d file has this check in it:
        if grep -q "^[[:space:]]*iface[[:space:]]*.*[[:space:]]*inet[[:space:]]*dhcp" \
        $INTERFACES; then
                log_failure_msg "Not running $NAME because $INTERFACES"
                log_failure_msg "defines some interfaces that will use a" \
                        "DHCP client"
                exit 6
        fi
I thought that check existed in dhcpcd itself, but must have remembered wrong.
A similar check for the systemd unit (perhaps as a ExecStartPre=grep...) could be used to prevent dhcpcd from starting when the interfaces file uses static or dhcp for any of the interfaces. That would probably save people some trouble.
Sat May 07, 2016 6:09 am
ShiftPlusOne wrote:The original init.d file has this check in it:
        $INTERFACES; then
                        "DHCP client"
                exit 6
        fi
This sounds like a really good idea! :-)
mquinteiro
Sat May 07, 2016 2:20 pm
DougieLawson wrote:
ShiftPlusOne wrote: It's well documented that doing it that way (without disabling dhcpcd) means that each active interface gets two IP addresses, one done with the static stuff in the interfaces file, one done by dhcpcd if there's an active DHCP server on the subnet.
I don't get two IP's for the interface, interfaces starts with just one static and correct IP.
I haven't hdcpcd.conf , my system is a migration from wheezy. I have remember this "detail" right now, perhaps this is the reason of my headache.
Thanks!
epoch1970
Sat May 07, 2016 2:58 pm
I will show my age and the ravages it brings.
But I have to say dhcpcd (besides its ridiculous name) is an aggravation almost equal to systemd sticking its nose everywhere.
/etc/network/interfaces has worked perfectly well for ages. So why deprecate it?
mquinteiro
Sat May 07, 2016 3:13 pm
epoch1970 wrote:I will show my age and the ravages it brings.
I agree with everything and my age is an old secret too.
FM81
Sat May 07, 2016 3:25 pm
epoch1970 wrote:... But I have to say dhcpcd (besides its ridiculous name) is an aggravation almost equal to systemd sticking its nose everywhere.
Agreeing too ...
[IRONIC MODE]
It's a type of "Modern Times": If something works good, replace it with something new, which didn't work better, makes things more complicated or what ever ...
But everyone will like the NEW and will be happy with it, because it is NEW ...
[/IRONIC MODE]
Greetings, FM_81
A: What does the command 'cat /dev/urandom', can you tell me please?
B: Yeah, that's very simple: It feeds your cat with radioactive material!
mquinteiro
Mon May 09, 2016 1:23 pm
Hi This is what I did.
I have modified /etc/wpa_supplicant/ifupdown.sh
And replaced
# quit if we're called for the loopback
if [ "$IFACE" = lo ]; then
        exit 0
fi
with
        exit 0
fi
if [ "$IFACE" = eth0 ]; then
        exit 0
fi
Now it works ok, I suppose that I could analyze a little bit more and propose a better solution but I'm in a rush.
mquinteiro
[SOLVED] DHCP starts after reconnection in a static interfac
Tue May 10, 2016 9:05 am
I have install a fresh Jessie image and same problem.
I had follow the dhcpcd.conf creating profiles and blablabla but it is buggy. Do exactly the same. At the boot everything works ok, but when you unplug and plug again if fails.
Solution, the one mention before, edit /etc/wpa_supplicant/ifupdown.sh with it everything works even dhcpcd.conf
dicktonyboy
Tue May 10, 2016 1:29 pm
eg stick this in /etc/dhcpcd.conf
interface eth0
static ip_address=192.168.0.181/24
static routers=192.168.0.1
static domain_name_servers=192.168.0.1
and leave /etc/network/interfaces as just
iface eth0 inet manual
This survives any disconnection /reconnection.
(Now all I need to know is how to add multiple ip addresses to eth0)
