ma_guinea
wifi issue
Thu Aug 16, 2012 11:01 am
I have a Negear WN111v2 wifi dongle which i am managing through the network-manager add on. I can access the add-on and can see the wireless networks and also input the wpa2 passcode however it doesnt seem to actually connect to the network. When i click on the network nothing happens and when i click status it says disconnected. Any ideas?
bredman
Re: wifi issue
Thu Aug 16, 2012 11:05 am
This normally shows that the device has enough power to receive but not enough to transmit.
Are you using a powered USB hub?
ma_guinea
Re: wifi issue
Thu Aug 16, 2012 11:42 am
I am not, as whenever I used the powered 7 port hub I have, nothing on it works. The hub is supposedly powered by a 5v 2A supply though :s
mahjongg
Re: wifi issue
Thu Aug 16, 2012 11:46 am
"supposedly"may be the key word here, many of these 7-port hubs come with Chinese power supplies of abominable quality, and what it says on their labels is often simply a lie.
The PI should work with a powered hub, not that there are no issues with using it, but for most people it works fine, and yes, without the power from a hub many wifi adapters are unlikely to work.
ma_guinea
Re: wifi issue
Thu Aug 16, 2012 11:47 am
I'll have to find another hub i suppose then. Thanks guys!
SiL3nT
Re: wifi issue
Thu Aug 16, 2012 2:05 pm
I had a similar problem with mine when i first started, the solution was to change my router from WPA/WPA2 Personal to Mixed WPA/WPA2 and it finally connected.
