Incorrect login or password Pi 3
Posted: Tue May 03, 2016 2:39 am
by Duhjoker
I just booted up my Pi after installing a fresh Raspbian Jessie and I'm having a couple problems.
After doing a sudo raspi-config and rebooting cannot login. I have not changed the password or the login in any way. It first started doing this when it would boot to the desk top and I couldn't log out to to the cli and the password and login kept saying it was incorrect.
Now after running sudo raspi-config and making it boot to the cli I can't get past the password or login to be recognized.
Re: Incorrect login or password Pi 3
Posted: Tue May 03, 2016 3:19 am
by Rive
Are you using special char in password like #? Or is it 'raspberry'? Type the password in the username and see if it is actually entering the correct char.
I noticed mine did that as it kept defaulting back to uk keyboard. I had to end up setting the keyboard default to us.
Posted: Tue May 03, 2016 3:22 am
by Duhjoker
Like i said i didnt change the password or login.
Ive tried raspberry and pi and pi and raspberry
Posted: Tue May 03, 2016 3:28 am
by Rive
Duhjoker wrote:Like i said i didnt change the password or login.
Default is:
pi
raspberry
So...
You expanded the file system after install of the OS?
You did not login as root (sudo su startx) ?
No one else has access to the pi3?
I suggest you restore your backup
Posted: Tue May 03, 2016 3:34 am
by Duhjoker
I just burned the image to the sd card my self 5 minutes before installing it into my Pi 3. The card was on my person the whole time.
I just re-installed it once more. Expanded the file system and yada yada then fed it the wi-fi password and did sudo apt-get and sudo apt-get -y git dialog.
After re-booting now it goes straight to the desktop and freezes. I've used two mice and two keyboards and nothing.
Posted: Tue May 03, 2016 3:39 am
by Rive
Duhjoker wrote:I just burned the image to the sd card my self 5 minutes before installing it into my Pi 3. The card was on my person the whole time.
So everything works fine until you try to install the retropie emulation?
Posted: Tue May 03, 2016 3:40 am
by klricks
After expanding.... "yada yada" above MUST include reboot before attempting any updates.
Posted: Tue May 03, 2016 3:43 am
by Duhjoker
No I wasn't trying to do retro pie those two update commands were with my set up guide that I can't find right now.
Yes I rebooted before the updates. It started freezing after installing the two commands though.
Posted: Tue May 03, 2016 3:48 am
by Rive
Duhjoker wrote:No I wasn't trying to do retro pie those two update commands were with my set up guide that I can't find right now.
Then restore your backup and don't install and see if issue reoccurs
Posted: Tue May 03, 2016 3:50 am
by Duhjoker
I can't do that. It freezes after going to desktop. I have no mouse or keyboard control
Posted: Tue May 03, 2016 3:53 am
by Rive
Duhjoker wrote:I can't do that. It freezes after going to desktop. I have no mouse or keyboard control
So you are unable to physically remove power, remove sdcard, put it into a reader on pc, clean it with something like diskpart 'clean' command, then write the backup image you should have made using something like diskimager?
Posted: Tue May 03, 2016 3:57 am
by Duhjoker
I don't know what's going on!!! Now I can use the mouse and keyboard and the password is working.
Sooooooooo weird I never had this problem on my 2 or zero.
Posted: Tue May 03, 2016 4:23 am
by Duhjoker
Im gonna try to re burn the image again. For some reason it doesnt like any of my mice or keyboard.
Posted: Sun Sep 08, 2019 7:22 pm
by dogoncouch
I just figured out what might be your issue, after having this problem myself repeatedly.
I was setting the password, and THEN changing the keyboard layout. When you go from UK to US keyboard layout, a few special characters move to different parts of the keyboard, like @ and ". I noticed that the initial boot setup for the full GUI versions of raspbian set the keyboard layout before having you set your password, so I tried it in that order and it solved the problem. Hope this helps.
