undeadzzs wrote:Hello,
I just recently bought a raspberry pi, hooked it up and it worked all find. After I did a apt-get dist-upgrade it turned off and isn't turning on again. (Im using the noobs software)
When you run apt-get, the system doesn't "turn off", so right there I suspect there's a problem. Is your free space sufficient to be doing this sort of thing? When you do a dist-upgrade, it goes for broke and includes a new kernel if available. Since it's lower level, any issue occurring there might be more lethal than elsewhere but it always, you know, depends. I would find another sdcard to test and put R. jessie lite on it, boot up, see what is going on. You can get by with a 2gig for this test. You will need to expand the image before doing much that writes to the disk because there is little free space until you do that.
