fsamir
Operation not possible due to RF-kill
Thu Apr 28, 2016 1:17 am
Hi all,
after a fresh install of RASPBIAN jessie light on a RPI 3 (with embedded wifi) I get the error below, when I try to start the wireless netwrok(sudo ip link set wlan0 up):
RTNETLINK answers: Operation not possible due to RF-kill
I can bypass the issue by running:
rfkill list all
sudo rfkill unblock all
However, when I reboot , wifi will be soft blocked again.
How can I make it persistent, so wifi is powered up at boot?
Thanks,
Franklin
ab1jx
Re: Operation not possible due to RF-kill
Thu Apr 28, 2016 4:00 am
I didn't touch RF-kill, I just use an /etc/network/interfaces file. I use an open WiFi network and a static IP ethernet network. You can leave out the last few lines for eth0 if you don't use them. Most people need WPA and a password, check the man page for the syntax and you'll need to do something in /etc/wpa_supplicant I think. But this file gets both networks working on every boot, no wi_cd or network manager. Oh, set your WiFi ESSID in here where mine says Moto_lte.
# new interfaces file 4/23/2016
source /etc/network/interfaces.d/*
auto lo
iface lo inet loopback
auto wlan0
iface wlan0 inet dhcp
  wireless-essid Moto_lte
  allow-hotplug wlan0
auto eth0
iface eth0 inet static
  address 192.168.0.16
  netmask 255.255.255.0
  network 192.168.0.0
  broadcast 192.168.0.255
fsamir
Mon May 23, 2016 12:04 pm
I forgot to mention, I already had wpa_supplicant configured as the suggestion above.
This very same config works on a RPI2(wheezy), but in the RPI 3(jessie) it seems wifi boot in some sort of powersave mode.
Any other ideas?
DirkS
Mon May 23, 2016 1:43 pm
fsamir wrote:I forgot to mention, I already had wpa_supplicant configured as the suggestion above.
Any other ideas?
Use
sudo aot-get update
sudo apt-get dist-upgrade
This should get you the latest driver versions that have a fix / workaround for the power saving problems of earlier versions
AndersUk
Tue Jan 29, 2019 6:21 pm
Yep, I’ve strayed into this quagmire as well.
On Raspbian Stretch I tried out:
#turn off radio power
iwconfig wlan0 txpower off
# turn off wifi interface
ifconfig wlan0 disable
Now the WiFi is off every time I reboot. Following the above:
rfkill list all
Brings the WiFi up, but until next reboot.
I’ve tried putting the above rfkill commands in rc.local, but have failed to bring it back up at boot.
Any suggestions? Thanks
gjwoz
Mon Apr 27, 2020 5:02 am
Hi, I'm a bit new to this but encountered the same issue when I attemped to use the raspberry pi imager. Instead use etcher to load Raspian on your sd card.
https://magpi.raspberrypi.org/articles/pi-sd-etcher
Good luck
rew
Mon Jul 20, 2020 1:15 pm
OK guys for the future (probably me searching for this problem again in a year or so)....
The boot scripts softblock the wlan when you haven't entered your country in
raspi-config -> localisation options -> Change WLAN Country
I would REALLY like to know what file this changes, as I wasted a lot of time trying to bring up a raspberry pi that was supposed to be doing wlan. I imaged the SD card, edited /boot/ssh and /etc/wpa_supplicant/wpa_supplicant.conf expecting the pi to boot and join my network....
Check out our raspberry pi addons: https://www.bitwizard.nl/shop/
trejan
Mon Jul 20, 2020 1:22 pm
It isn't altering any files directly. It is running rfkill to unblock it which then alters the flags in /var/lib/systemd/rfkill
If you copy wpa_supplicant.conf to /boot instead of editing /etc/wpa_supplicant/wpa_supplicant.conf directly then there is a custom startup service that will copy it over for you and also call rfkill to unblock WiFi.
tedder
Mon Oct 05, 2020 2:20 am
I was curious about this, so I investigated. This is done via:
/lib/systemd/system/raspberrypi-net-mods.service
It exists in the current (August 2020) version of Raspbian.
