Sonic Pi, fatal error on start-up
Posted: Sat Apr 23, 2016 12:01 pm
by Taxicletter
When I open Sonic Pi, it opens with an error. When I close the error, Sonic Pi quits.
This are the details of two subsequent crashes:
Detailed Error Report:
GUI log
[GUI] - shutting down any old audio servers...
[GUI] - booting live coding server
[GUI] - using default editor colours
[GUI] - starting UDP OSC Server on port 4558...
[GUI] - UDP OSC Server ready and listening
[GUI] - waiting for server to connect...
[GUI] - server failed to start with this error message:
      > Failed to open server port 4557, is scsynth already running?
[GUI] - critical error!
[GUI] - server connection established
[GUI] - loading workspaces
Server Errors
Received Exception!
Address already in use - bind(2) for "127.0.0.1" port 4557
["/opt/sonic-pi/app/server/sonicpi/lib/sonicpi/osc/udp_server.rb:30:in `bind'", "/opt/sonic-pi/app/server/sonicpi/lib/sonicpi/osc/udp_server.rb:30:in `initialize'", "/opt/sonic-pi/app/gui/qt/../../../app/server/bin/sonic-pi-server.rb:68:in `new'", "/opt/sonic-pi/app/gui/qt/../../../app/server/bin/sonic-pi-server.rb:68:in `<main>'"]
GUI log
Server Errors
jackd: geen proces gevonden
scsynth: geen proces gevonden
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
ALSA: Cannot open PCM device alsa_pcm for capture. Falling back to playback-only mode
ALSA: got smaller periods 2 than 3 for playback
ALSA: cannot configure playback channel
Cannot initialize driver
JackServer::Open failed with -1
Server Output
Using protocol: udp
jackdmp 1.9.10
Copyright 2001-2005 Paul Davis and others.
Copyright 2004-2014 Grame.
jackdmp comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK server starting in realtime mode with priority 10
self-connect-mode is "Don't restrict self connect requests"
audio_reservation_init
Acquire audio card Audio0
creating alsa driver ... hw:0|hw:0|2048|3|44100|0|0|nomon|swmeter|-|32bit
configuring for 44100Hz, period = 2048 frames (46.4 ms), buffer = 3 periods
ALSA: final selected sample format for playback: 16bit little-endian
Re: Sonic Pi, fatal error on start-up
Posted: Sat Apr 23, 2016 1:32 pm
by dom
Are you using the "rpi-update" 4.4. kernel?
There is an incompatibility with Sonic Pi that is being investigated.
If Sonic Pi is essential, you should revert back to stable kernel.
Posted: Sat Apr 23, 2016 2:36 pm
by Taxicletter
Using 4.4.7-v7+
How do I switch to another version and which version is best?
Posted: Sat Apr 23, 2016 4:40 pm
by dom
This will downgrade to the latest 4.1 kernel
sudo rpi-update 771a503cfc2a1130e2df2a4ddfc45ffa0f592b3f
Posted: Sun Apr 24, 2016 5:56 pm
by Taxicletter
Thank you.
I went to Sam Aarons Github place and learned there that it would be a problem with JACK. Wouldn't it be enough to downgrade the JACK packages? It feels a pitty to go to an older kernel version, I just used sudo BRANCH=next rpi-update to fix a problem with the OpenGL Driver I had.
As I understand it, sudo BRANCH=next rpi-update gives you some kind of beta version. The stable version gives the error. When I go to the 4.1 version, I can't update until I'm sure the new version works fine with Sonic Pi.
