This are the details of two subsequent crashes:
Detailed Error Report:
GUI log
[GUI] - shutting down any old audio servers...
[GUI] - booting live coding server
[GUI] - using default editor colours
[GUI] - starting UDP OSC Server on port 4558...
[GUI] - UDP OSC Server ready and listening
[GUI] - waiting for server to connect...
[GUI] - server failed to start with this error message:
> Failed to open server port 4557, is scsynth already running?
[GUI] - critical error!
[GUI] - server connection established
[GUI] - loading workspaces
Server Errors
Received Exception!
Address already in use - bind(2) for "127.0.0.1" port 4557
["/opt/sonic-pi/app/server/sonicpi/lib/sonicpi/osc/udp_server.rb:30:in `bind'", "/opt/sonic-pi/app/server/sonicpi/lib/sonicpi/osc/udp_server.rb:30:in `initialize'", "/opt/sonic-pi/app/gui/qt/../../../app/server/bin/sonic-pi-server.rb:68:in `new'", "/opt/sonic-pi/app/gui/qt/../../../app/server/bin/sonic-pi-server.rb:68:in `<main>'"]
GUI log
Server Errors
jackd: geen proces gevonden
scsynth: geen proces gevonden
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
ALSA: Cannot open PCM device alsa_pcm for capture. Falling back to playback-only mode
ALSA: got smaller periods 2 than 3 for playback
ALSA: cannot configure playback channel
Cannot initialize driver
JackServer::Open failed with -1
Server Output
Using protocol: udp
jackdmp 1.9.10
Copyright 2001-2005 Paul Davis and others.
Copyright 2004-2014 Grame.
jackdmp comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK server starting in realtime mode with priority 10
self-connect-mode is "Don't restrict self connect requests"
audio_reservation_init
Acquire audio card Audio0
creating alsa driver ... hw:0|hw:0|2048|3|44100|0|0|nomon|swmeter|-|32bit
configuring for 44100Hz, period = 2048 frames (46.4 ms), buffer = 3 periods
ALSA: final selected sample format for playback: 16bit little-endian
