sudo su startx (pi account issue)
Posted: Sun Apr 17, 2016 9:23 pm
by Rive
I have a problem. Simply put, I need to access a root folder in /usr/shared/ and modify contents of said folder.
I used this to gain root user access to the GUI.
sudo su
startx
Fine. Works, make my changes...
exit
Then reboot.
Login screen no longer accepts:
Pi user
Pi password
My understand is that .xauthority is now owned by root, and pi can no longer log in.
My understanding is that if I use a terminal (cntrl +alt+f1-f7), type pi user, pi password, then;
 mv .Xauthority .Xauthority.bak
exit
Login screen will now work for pi, but that my custom pi settings may be wiped?
I went and restored backup image, so now I get a 'do over'.
So how do I do this now? Login as root in GUI make my changes to /usr/shared/ via file manager, exit root, and still have pi user work properly?
Re: sudo su startx (pi account issue)
Posted: Sun Apr 17, 2016 9:28 pm
by kusti8
DON'T RUN X AS ROOT!!!
Simply put, edit whatever file you want in the terminal or start Leafpad and the file manager with gksudo
Posted: Sun Apr 17, 2016 9:29 pm
by Rive
kusti8 wrote:DON'T RUN X AS ROOT!!!
Already tried that (gksudo in file manger) permissions still denied for changes to file (I am not editing text here) I am trying to remove contents ((I am modifying .png image files) of a root folder and move contents from a pi folder to a /usr/shared/ root folder using file manager.
I don't want to use terminal commands to move items I want to use file manager.
Posted: Sun Apr 17, 2016 9:34 pm
by DirkS
Already tried that (gksudo) permissions still denied for changes to file (I am not editing text here) I am trying to remove contents of a folder and move contents from a pi folder to a /usr/shared/ folder.
Did you try
gksu pcmanfm
Using the command line is a lot easier :shock:
Posted: Sun Apr 17, 2016 9:36 pm
by Rive
Did you try
gksu pcmanfm
I'll try that
Posted: Sun Apr 17, 2016 11:56 pm
by Rive
DirkS wrote: Did you try
gksu pcmanfm
Worked like a charm. Thanks
