Snoekkie wrote:At the same time installing the 2016-03-18 release on my 1B+ gives problems after the update and upgrade I even tried to do RPI-upgrade. but this is giving me the same boot problems. Specially mentioned it is always the kernel which is panicing here is where the boot proces stops.
When installing an image without using Noobs you need to expand the filesystem to make use of the full size of the SD card, otherwise you will run out of space very quickly.
Use 'sudo raspi-config' and select the first option, then reboot.
I read on the site from distrowatch raspbian 2016-02-03 was made solely for the 2B also this release has problems with the 1B because of the memory configuration.
That sounds like balderdash & poppycock to me.
Do you have a link to that 'information'?
