scollins15
Pi 3 Networking Problems
Fri Apr 08, 2016 9:12 pm
I have had no luck with networking with my new Pi 3's (5 total). Problems I am experiencing is dropped wifi connections and inability to connect via a wired connection.
Pi details:
Official Raspbian Jessie Lite image from the foundations site.
Initially installed wicd-curses, which I thought was causing all kinds of issues as my connection kept dropping. This has now been removed.
uname -a:
Linux trusign-e7b7 4.1.21-v7+ #872 SMP Wed Apr 6 17:34:14 BST 2016 armv7l GNU/Linux
/etc/network/interface:
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
country=US
update_config=1
/etc/dhcpcd.conf
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU.
# Some interface drivers reset when changing the MTU so disabled by default.
#option interface_mtu
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
# A hook script is provided to lookup the hostname if not set by the DHCP
# server, but it should not be run by default.
nohook lookup-hostname
In the files above you will see that there is not a wireless network setup in the wpa_supplicant.conf file as I have aborted that in an effort to try and get networking to work on the eth0 interface.
Any help or explanation would be greatly appreciated.
Scot
dchao99
Re: Pi 3 Networking Problems
Fri Apr 08, 2016 9:38 pm
Are you using the official Pi3 power supply?
And what WiFi channel are you using?
iwlist wlan0 freq
I found my Ri3 doesn't work on channel 11,12,13... And just about working on 1 and 6
scollins15
Sat Apr 09, 2016 1:26 am
dchao99 wrote:Are you using the official Pi3 power supply?
No I am using a 3A power supply. I do not have any peripherals attached to the USB slots and have this same power supply on serveral other Pi's (although not Pi3's) with no issue. I can test the supply with my oscilloscope and see just how much power the PI is using if anyone is interested.
iwlist wlan0 freq
sudo iwlist wlan0 freq
wlan0     11 channels in total; available frequencies :
          Channel 01 : 2.412 GHz
          Channel 02 : 2.417 GHz
          Channel 03 : 2.422 GHz
          Channel 04 : 2.427 GHz
          Channel 05 : 2.432 GHz
          Channel 06 : 2.437 GHz
          Channel 07 : 2.442 GHz
          Channel 08 : 2.447 GHz
          Channel 09 : 2.452 GHz
          Channel 10 : 2.457 GHz
          Channel 11 : 2.462 GHz
          Current Frequency:2.412 GHz (Channel 1)
However I am not currently connecting to the wifi only trying to connect via ethernet cable. Initially when I did temporarily connect to the wireless network I was using Channel 1, however it would drop shortly after connecting.
dgordon42
Sat Apr 09, 2016 2:35 am
There's a line in your /etc/network/interfaces file
scollins15 wrote:iface eth0 inet dhcp
Change it back to
iface eth0 inet manual
This is the default value, and will allow dhcpcd to get a DHCP address from your ethernet router.
Hope this helps,
Dave.
scollins15
Sat Apr 09, 2016 11:59 pm
change to
I made this change and the first reboot I got a 169.*.*.* address. I then removed the /etc/dhcpcd.duid file and rebooted again and did not get an IP address.
Are there other files to look at or modify with the new raspberrypi-net-mods package and Jessie that need to be setup for this to work?
Are there manual commands I can run on the command line to see output and determine the issue? How about system logs that would give guidance or indications? Thanks again for the help.
dgordon42
Sun Apr 10, 2016 6:30 am
The wired ethernet should just work on the Pi without changing any configuration files, which is why I suggested changing back to "iface eth0 inet manual". That is the default setting.
Your Pi should, by default, get a DHCP IP address from the DHCP server in your router. If your Pi is getting an address in the 169.255.*.* range, then this is not happening. I would start by checking that you have a good connection & cable between your Pi and your router, and that your router has DHCP enabled.
Dave.
scarf
Tue Apr 12, 2016 6:18 am
im also having similar issues with a fresh Raspbian installation. when i connect to either a wifi or wired network, the Pi will get a local IP address, and i can access local computers for example, but unable to resolve hostnames or connect to internet sites (even by IP address). all config files are default and my /etc/network/interfaces has "iface eth0 inet manual"
dgordon42
Tue Apr 12, 2016 8:49 am
@scarf,
What make and model of router are you using?
Can you post the output of:
cat /etc/resolv.conf
route -n
Thanks,
Dave.
scarf
Tue Apr 12, 2016 7:17 pm
i have the model 3... what i had to do was edit /etc/resolvconf.conf and set "name_servers=192.168.1.1" (my router) then i had to edit /etc/network/interfaces and change the eth0 setup to:
auto eth0
seems to be working consistently now
krazykyran
Tue Aug 23, 2016 2:50 am
scarf wrote:i have the model 3... what i had to do was edit /etc/resolvconf.conf and set "name_servers=192.168.1.1" (my router) then i had to edit /etc/network/interfaces and change the eth0 setup to:
auto eth0
This worked for me too.
Question: what if you wanted 2 "name_servers" to be in your resolv.conf list permanently?
I tried putting both name_servers=x.x.x.x in /etc/resolvconf.conf, but it only recognises the second one (seems like it overwrites the first entry). Then i changed the second entry to be "name_servers_append=y.y.y.y" and now i have 2, but is this the right way?
Cheers, K.
