coding
Some recent update must have killed my vsftpd
Tue Apr 05, 2016 8:40 am
Some recent apt-get update, which I automatically run every day, must have killed my vsftpd. The server is closed and won't start anymore. I don't know how to troubleshoot this. I did not change anything, and my (working-until-now) /etc/vsftpd.conf is still there.
sudo service vsftpd status
● vsftpd.service - vsftpd FTP server
   Loaded: loaded (/lib/systemd/system/vsftpd.service; enabled)
   Active: failed (Result: exit-code) since Tue 2016-04-05 10:33:47 CEST; 4min 46s ago
  Process: 1950 ExecStart=/usr/sbin/vsftpd /etc/vsftpd.conf (code=exited, status=2)
  Process: 1947 ExecStartPre=/bin/mkdir -p /var/run/vsftpd/empty (code=exited, status=0/SUCCESS)
 Main PID: 1950 (code=exited, status=2)
Apr 05 10:33:47 raspberrypi systemd[1]: Started vsftpd FTP server.
Apr 05 10:33:47 raspberrypi systemd[1]: vsftpd.service: main process exited, cod...NTApr 05 10:33:47 raspberrypi systemd[1]: Unit vsftpd.service entered failed state.
Hint: Some lines were ellipsized, use -l to show in full.
What should be my next steps in troubleshooting?
Re: Some recent update must have killed my vsftpd
Tue Apr 05, 2016 9:57 am
Start by using systemctl -l status vsftpd.service to see the wider (not truncated) messages which may give you a clue as to what code it failed with.
coding
Tue Apr 05, 2016 11:39 am
   Active: failed (Result: exit-code) since Tue 2016-04-05 10:33:47 CEST; 2h 57min ago
I also found this line with sudo journalctl:
systemd[1]: vsftpd.service: main process exited, code=exited, status=2/INVALIDARGUMENT
ls -l /etc/vsftpd.conf
-rw-r--r-- 1 root root 254 Jan  1 12:30 /etc/vsftpd.conf
The vsftpd executable was changed on Apr 2:
ls -l /usr/sbin/vsftpd
-rwxr-xr-x 1 root root 129604 Apr  2 19:41 /usr/sbin/vsftpd
Tue Apr 05, 2016 8:31 pm
Is there anything in /var/log/syslog?
Have you checked the syntax of everything in your config file?
coding
Wed Apr 06, 2016 7:19 am
Same message in /etc/var/syslog:
Apr  6 08:56:40 raspberrypi systemd[1]: Starting vsftpd FTP server...
Apr  6 08:56:40 raspberrypi systemd[1]: Started vsftpd FTP server.
Apr  6 08:56:40 raspberrypi systemd[1]: vsftpd.service: main process exited, code=exited, status=2/INVALIDARGUMENT
Apr  6 08:56:40 raspberrypi systemd[1]: Unit vsftpd.service entered failed state.
I now found this page, where someone else had a similar error: http://askubuntu.com/questions/683413/v ... ile-exists
He was told to have "listen=YES" in his /etc/vsftpd.conf
That answer has -1 reputation. However, for me it works.
I never had to use that option before. I checked the manual at http://vsftpd.beasts.org/vsftpd_conf.html. There it says the default is "listen=YES". I assume, now that I have to explicitly put it into /etc/vsftpd.conf, that for some reason YES is not the default anymore.
I wish we could confirm this. When suddenly a server stops like this, I am worried about the system's security.
