I see a coloured splash screen and can also see the console booting up for 1 sec
but after that it goes back to coloured splash screen and boot up after and after again
kernal image : 2012-07-15-wheezy-raspbian.zip
I use a Sandisk Sd card 4 GB class 4
I have connected it to a sont led tv thru HDMI
Re: RPi restarts continously help...
I am using a iphone charger for this
its rated at 1A
its rated at 1A
- mahjongg
- Forum Moderator
It may be "rated 1A", but this behaviour is typical for a supply that cannot provide enough power, the moment it is asked to do so the output voltage collapses, and reset the PI.
It could be that the "USB power cable" is too long, and/or too thin, and causes too much energy loss.
Try another power supply.
i tried it with laptop usbmahjongg wrote:It may be "rated 1A", but this behaviour is typical for a supply that cannot provide enough power, the moment it is asked to do so the output voltage collapses, and reset the PI.
i am using a 1 feet cable
i ll try using a power adapter
I think laptops only supply 0.5 amps per USB port. You could try one of those Y cables which are sometimes used to power usb drives from two usb ports.
Best to try from a powered USB hub if you can get your hands on one.
Noob is not derogatory the noob is just the lower end of the noob--geek spectrum being a noob is just your first step towards being an uber-geek
If you find a solution please post it in the wiki the forum dies too quick
The problem was my usb cable
i changed the cable it worked
As good as it gets.
