ouaibe
Unaccessible URL
Thu Mar 24, 2016 4:21 pm
I'm under raspberrypi 3 with raspbian.
My wifi conection is OK... but some URL are unaccessible ! ssl0.ovh.net for instance and also my own distant cloud server and my mail through Clawsmail !?
An idea ?
Thanks in advance.
DirkS
Re: Unaccessible URL
Fri Mar 25, 2016 2:33 am
Do you get any error messages?
Can you ping *any* URL (e.g. google.com)
Can you ping external IP addresses (e.g. 8.8.8.8)
Can you connect to these sites from another computer in the same LAN as your Pi?
How does your Pi get its IP address (static / dhcp)?
If static can you post the settings you added.
zealousd
Fri Mar 25, 2016 4:37 am
restart your router and get a new IP
Raspberry Pi 3
Ubuntu Mate
Web Server
ouaibe
Sat Mar 26, 2016 8:28 pm
pi@raspberrypi:~ $ ping duckduckgo.com
connect: Network is unreachable
pi@raspberrypi:~ $ ping 8.8.8.8
"Can you connect to these sites from another computer in the same LAN as your Pi?"
> yes
"How does your Pi get its IP address (static / dhcp)?"
DHCP
Sat Mar 26, 2016 11:23 pm
If you can't reach 8.8.8.8 then it's likely that your gateway router isn't correct.
Take a look with ip route on your RPi and route print -4 on Windows.
ouaibe
Sun Mar 27, 2016 3:35 pm
Sorry I absolutely don't use GAFAM tools ... so no windows ;o))
My RaspberryPi with RASPBIAN
ip route
192.168.0.0/24 dev eth0 proto kernel scope link src 192.168.0.93 metric 202
My home computer under DEBIAN
Ethernet connexion
IP route
default via 192.168.0.254 dev eth0  proto static  metric 1024
169.254.0.0/16 dev eth0  scope link  metric 1000
192.168.0.0/24 dev eth0  proto kernel  scope link  src 192.168.0.89
For information I don't have any connexion pb with my RaspberryPi version 1 (the very first) ...
