Crtek
Pi Zero USB hub
Thu Mar 24, 2016 2:08 pm
I've bought a pi zero and got it working, the only problem is I can't seem to find a usb hub that would work with it. Obviously I need at least 3 ports (mouse, keyboard and wifi).
I've tried a powered one that has a micro usb connection (for tablets and smartphones) and can be powered externally. I can power the pi through it and a mouse lights up if plugged into the hub. However, the mouse doesn't respond. The hub works on my tablet and smartphone.
I've also tried a cheap regular non-powered hub that worked with my pc, but did not work with the pi. I even tried adding extarnal power to it (online tutorial)...however I would not be writing this if it worked.
I have no idea what the problem is. Maybe it's a missing driver? Maybe my the hubs just aren't compatible. If anyone knows what to do PLEASE help me, I'm at the verge of crying.
P.S. Obviously I don't want to spend more money on the hub than the actual pi, so if anyone knows of a cheap hub that works, that would be amazing.
Re: Pi Zero USB hub
Thu Mar 24, 2016 2:25 pm
You already posted this question.
viewtopic.php?f=91&t=141507
PiGraham
Re: Pi Zero USB hub
Thu Mar 24, 2016 2:27 pm
There are some suggestions in this topic:
viewtopic.php?f=46&t=129519
