sswhitebeard
Tight vncserver error messages
Mon Mar 21, 2016 8:06 am
Good Morning,
I'm new to all this and a novice to boot. I'm trying to work on Pi 2 via my laptop and I followed the instructions given on various forums but to no avail! The messages I get are as follows,
[email protected]:~ $ sudo apt-get install tightvncserver
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
xfonts-base
Suggested packages:
tightvnc-java
The following NEW packages will be installed:
tightvncserver xfonts-base
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 6,736 kB of archives.
After this operation, 9,895 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
WARNING: The following packages cannot be authenticated!
Install these packages without verification? [y/N] y
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main tightvncserver armhf 1.3.9-6.5
Could not resolve 'mirrordirector.raspbian.org'
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main xfonts-base all 1:1.0.3
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... _armhf.deb Could not resolve 'mirrordirector.raspbian.org'
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... .3_all.deb Could not resolve 'mirrordirector.raspbian.org'
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
so I do the update and upgrade but I get the following message,
Err http://archive.raspberrypi.org jessie InRelease
Err http://mirrordirector.raspbian.org jessie InRelease
Err http://archive.raspberrypi.org jessie Release.gpg
Could not resolve 'archive.raspberrypi.org'
Err http://mirrordirector.raspbian.org jessie Release.gpg
W: Failed to fetch http://mirrordirector.raspbian.org/rasp ... essie/InRe lease
W: Failed to fetch http://archive.raspberrypi.org/debian/d ... /InRelease
W: Failed to fetch http://archive.raspberrypi.org/debian/d ... Release.gp g Could not resolve 'archive.raspberrypi.org'
W: Failed to fetch http://mirrordirector.raspbian.org/rasp ... essie/Rele ase.gpg Could not resolve 'mirrordirector.raspbian.org'
W: Some index files failed to download. They have been ignored, or old ones used
I do apologise for all this long winded entry but I wanted all the info I'm getting to be visible. Both my laptop and Pi are connected to my home network.
I could really use some expert advice and help. Thank you :)
sswhitebeard
Re: Tight vncserver error messages
Wed Mar 23, 2016 6:09 pm
Really guys! Not one reply or helpful hint!! What happened to the experts or are they on holiday this year!!
Wed Mar 23, 2016 6:48 pm
sswhitebeard wrote:Really guys! Not one reply or helpful hint!! What happened to the experts or are they on holiday this year!!
Patience Grasshopper ;)
There have been problems with the Raspbian servers today. It seems to have been fixed now, but may take a little while to settle.
sswhitebeard
Sun Mar 27, 2016 4:30 pm
Well. I have sorted this problem out myself, after a lot of headache! So now I move to the next! Which is the vnc viewer recognising the vnc server on the Pi! I'll have a look and see what I can find because waiting here is not good for my health!!
Xanadu88
Tue Aug 30, 2016 8:16 pm
I have de same problem and I will be very please if anyone can give a hint what is goiing on. Many thanks.
31/08: Well never mind. It seem the ethernet was not in the right port of the rooter. :?
