rp.kosmo
How to open Epiphany (Web) browser incognito from CLI?
Sun Mar 13, 2016 4:18 pm
I have not figured out how to open a session of epiphany browser from command line in "incognito" mode.
With Chrome for example, I can append "--incognito" to the cli command.
I've tried using "--private-instance", but this is not seem to be the same as opening up an incognito mode from the settings tab.
Epiphany version "Web 3.8.2"
Peter Ryan
Re: How to open Epiphany (Web) browser incognito from CLI?
Thu May 19, 2016 5:31 pm
The man page isn't much use is it? I found the answer by opening an incognito window and then using ps -aux in a terminal to see the command used to launch it.
So the answer is... (drum-roll....)
epiphany-browser --incognito-mode --profile ~/.config/epiphany
Hope that helps! :D
1david1
Fri Feb 09, 2018 2:31 pm
Hope that helps! :D
Yes, that is the command to run in Incognito Mode. But what is "Private Instance" mode then? The syntax for that doesnt require a profile so you can just say
epiphany-browser --private-instance
The documentation for Epiphany is sadly lacking.
