johnraikonen
[RPi3] Power led control
Sat Mar 12, 2016 2:16 pm
Hi everyone.
I am trying to shut down the power led on the RPi 3 with Jessie. It seems impossible with the old way :
echo 0 > /sys/class/led1/brightness
Indeed, it works with the green led (leds/led0) but the folder led1 doesn't exist anymore.
Did someone found an other way ?
SebTC
Re: [RPi3] Power led control
Sun Mar 13, 2016 9:46 am
I'm also interested in this. Is the PWR led (led1) hardwired or is there an update/solution to turn it off? Guess it can save around 5mA.
smurf
Tue Mar 06, 2018 5:04 pm
Current kernels give you led0 and led1 to play with.
You can "echo none >trigger" and write 0/1 to "brightness", or you can set it to mirror any available GPIO, or …
Have fun.
Note that the green LED has a minimum on time of 0.1 seconds or so; this is so that you can see even very short bursts of activity when it triggers on the MMC controller or the network adapter. The red LED is wired directly.
