rbn
setting up bluetooth audio on Pi3
Wed Mar 09, 2016 10:48 am
I have successfully paired a bluetooth speaker with my Pi3, but I am at a loss how to select it for audio output.
I have found several installs which use bluez-alsa and bluez-utils and set up an entry in alsa which can be selected, but these packages do not seem to be available in the latest raspian distro. (release date 2016-02-26) I did a distro-upgrade on this and installed pi-bluetooth. I also have blueman installed and these let me pair the speaker.
How do I go about getting audio connected to it?
Re: setting up bluetooth audio on Pi3
Wed Mar 09, 2016 11:13 am
rbn wrote:I have successfully paired a bluetooth speaker with my Pi3, but I am at a loss how to select it for audio output.
The installs you are reading are for Bluez 4.9x, Raspbian Jessie has Bluez 5.xx which has many differences:
https://wiki.debian.org/BluetoothUser/a2dp (ignore about changing Repository)
Thinking outside the box is better than burying your head in the sand...
