Lordanubis
Static address - still dhcp
Tue Mar 08, 2016 10:46 pm
Dear all,
I did setup the Raspberry Pi 3 to a static address, but it still takes an dhcp address. Why and how can I solve this?
my /etc/network/interfaces looks like
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
# iface eth0 inet manual
iface eth0 inet static
address 10.159.0.200
netmask 255.255.255.0
network 10.159.0.0
broadcast 10.159.0.255
gateway 10.159.0.139
then I did
rm /var/lib/dhcp/*
then reboot
For a subnet network I did have a DHCP server running. At that time it uses one of their supplied address.
For now I did turn that off, so I was sure that there was only my modem/router which act as dhcp server arround.
Anyway, it shouldn't use that at all.
eth0 Link encap:Ethernet HWaddr b8:xx:eb:xx:7c:d1
inet addr:10.159.0.154 Bcast:10.159.0.255 Mask:255.255.255.0
inet6 addr: fe80::xxxxxxxxxx Scope:Link
inet6 addr: 2001:xxxxxxxxx Scope:Global
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:336 errors:0 dropped:0 overruns:0 frame:0
TX packets:138 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:42248 (41.2 KiB) TX bytes:20748 (20.2 KiB)
thank you for any help
knute
Re: Static address - still dhcp
Tue Mar 08, 2016 11:00 pm
This is one of the hardest things about Linux. Stuff tunes along for ever working one way and then they change it up on you.
If you are using Jessie or a late Wheezy then you need to clean all that stuff out of your /etc/interfaces file and read man dhcpcd.conf for how to set it up now.
Lordanubis
Wed Mar 09, 2016 1:49 am
Thank you
It works so far as I can see for the ethernet, but not for wifi. I have to check further.
A question do I need to add a hostname after the hostname keyword?
It is already in two other files.
Wed Mar 09, 2016 10:48 am
With Jessie that stuff isn't done in the /etc/network/interfaces file, it's all done in /etc/dhcpcd.conf
interface wlan0
static ip_address=192.168.3.14/24
static routers=192.168.3.1
static domain_name_servers=192.168.3.1 8.8.8.8
Lordanubis
Thu Mar 10, 2016 10:44 pm
Thank you both, but the wlan I can't get it to work, not as AP not as client.
Is there a specific Raspberian/Rasp pi 3 document to set up an AP?
I did found a Rasp Pi2 document, but didn't work.
