jezmck
Error when using PHP to run Shell script to play whitenoise
Tue Mar 08, 2016 8:16 pm
I have the following PHP:
if (...) {
  $path = '/home/pi/noise.sh';
  echo `sh $path 2>&1`;
and bash script:
#!/bin/bash
len=${1-00:00:05}
play --single-threaded -t sl - synth $len whitenoise band -n 1200 200 tremolo 20 .1 < /dev/zero
and these two give me the rather saddening
ALSA lib confmisc.c:768:(parse_card) cannot find card '0'
ALSA lib conf.c:4241:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
ALSA lib confmisc.c:392:(snd_func_concat) error evaluating strings
ALSA lib conf.c:4241:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
ALSA lib confmisc.c:1251:(snd_func_refer) error evaluating name
ALSA lib conf.c:4241:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:4720:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM default
play FAIL sox: Sorry, there is no default audio device configured
when run via a browser.
Running the bash script directly works fine.
The apache server runs as www-data.
Changing the permissions make no difference.
I've run raspi-config to (re-?) set the default audio to the 3.5mm jack.
I'm all out of ideas now!
Any help much appreciated.
jezmck
Re: Error when using PHP to run Shell script to play whiteno
Tue Mar 08, 2016 8:21 pm
I should have waited a little longer before posting!
I'll leave the answer I found here for anyone else though.
http://sox.10957.n7.nabble.com/Execute- ... p1078.html
sudo usermod -a -G audio www-data
sudo apachectl restart
