gcc ARM options
Posted: Mon Mar 07, 2016 7:51 pm
by hal9K
i am trying to use the command
gcc -mcpu=native -march=native -Q --help=target
on my RasPi 3 with gcc version 4.9.2 (Raspbian 4.9.2-10) and the following message appears:
*** Error in `gcc': double free or corruption (top): 0x01099c18 ***
As far as I know these compiler flags should be supported (gcc >= 4.7). Is this a bug or a feature?
Thanks a lot for your help.
Regards, Timo
Re: gcc ARM options
Posted: Mon Mar 07, 2016 10:05 pm
by Paeryn
Looking at the ARM detection code in GCC on github there seems to be a bug. It opens /proc/cpuinfo to read the processor information and closes it after trying to match with known processors. At this point it should set the file pointer to NULL but it doesn't. If it doesn't find a match (for some reason the a53 and a57 aren't listed for aarch32) then it goes to the not_found part which tries to close the file, since the pointer wasn't set to NULL when it was previously closed it attempts a second closing, this is what's causing the error. So at a guess whilst GCC knows about the A53, the native detection code doesn't and the bug rears it's head.
Hmm, looks like a patch was submitted on 10th Feb 2014 to add a53 and a57 to the detection list, but it's not there...
Edit: Bug report posted to gcc bugzilla.
Re: gcc ARM options
Posted: Tue Mar 08, 2016 6:49 am
by hal9K
Thank you very much for your detailed explanation and for posting a bug report.
Re: gcc ARM options
Posted: Mon Mar 21, 2016 6:08 pm
by dgencare
Is there any workaround until the fix is available?
Re: gcc ARM options
Posted: Mon Mar 21, 2016 6:35 pm
by Paeryn
Only to specify the cpu/arch directly and not use native. The code that gcc uses to determine what native means doesn't recognise the a53 and any cpu it doesn't recognise causes the crash on ARM platforms (rather than the intended ignoring of the switch).
Re: gcc ARM options
Posted: Mon Mar 21, 2016 6:55 pm
by jahboater
The usual options for the Pi3 are:-
-mcpu=cortex-a53 -mfpu=neon-vfpv4
Re: gcc ARM options
Posted: Mon Mar 21, 2016 8:25 pm
by jamesh
Cool - I always wondered why I got that double free warning. I now set the processor type directly.
Re: gcc ARM options
Posted: Thu Sep 22, 2016 10:12 am
by ibic
Hmm, this is quite annoying and I think the fix for this bug:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=70132
has not been merged to debian yet.
Re: gcc ARM options
Posted: Thu Sep 22, 2016 3:09 pm
by swampdog
Fwiw, it is a bit wierd. Same (nfs jessie) with same gcc. One works. One bombs.
This works (strace snippet)..
access("/usr/lib/gcc/arm-linux-gnueabihf/specs", R_OK) = -1 ENOENT (No such file or directory)
open("/proc/cpuinfo", O_RDONLY|O_LARGEFILE) = 3
fstat64(3, {st_mode=S_IFREG|0444, st_size=0, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x76f4e000
read(3, "processor\t: 0\nmodel name\t: ARMv7"..., 1024) = 1024
close(3)                                = 0
munmap(0x76f4e000, 4096)                = 0
close(3)                                = 0
access("/usr/lib/gcc/arm-linux-gnueabihf/4.9/", X_OK) = 0
This does not..
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x76f10000
close(3)                                = 0
munmap(0x76f10000, 4096)                = 0
open("/dev/tty", O_RDWR|O_NOCTTY|O_NONBLOCK) = 3
writev(3, [{"*** Error in `", 14}, {"gcc", 3}, {"': ", 3}, {"double free or corruption (top)", 31}, {": 0x", 4}, {"01961c18", 8}, {" ***\n", 5}], 7) = 68
rt_sigprocmask(SIG_UNBLOCK, [ABRT], NULL, 8) = 0
gettid()                                = 6700
tgkill(6700, 6700, SIGABRT)             = 0
--- SIGABRT {si_signo=SIGABRT, si_code=SI_TKILL, si_pid=6700, si_uid=1001} ---
+++ killed by SIGABRT +++
The only difference is the hardware (and the mmap address). The working one is an RPI2 whilst the failing one is an RPI3.
Re: gcc ARM options
Posted: Thu Sep 22, 2016 5:33 pm
by Paeryn
swampdog wrote:Fwiw, it is a bit wierd. Same (nfs jessie) with same gcc. One works. One bombs.
<snip>
Are you still trying to use -mcpu=native here? That option doesn't work on the RPi3, at least not until we get a version of gcc with the bug fixed. The code in gcc that checks what native should be replaced with is broken for ARM if the detected processor isn't in it's list of known processors. It tries to close a file that it already closed (/proc/cpuinfo).
The list of processors in the native detection code is not the same as the list of processors that it can compile for. Our version of gcc can happily compile for an A53 if it is told to use that specifically, it's auto-detection code however doesn't know about the A53 (in aarch32 mode).
Re: gcc ARM options
Posted: Tue Sep 27, 2016 2:58 pm
by swampdog
<snip>
Yes I was still using "-mpu=native" there. The wierdness was that the 'strace' doesn't show the double close. Then again I don't use strace that often.
Re: gcc ARM options
Posted: Tue Sep 27, 2016 3:13 pm
by jahboater
The "=native" stuff works fine with the latest version of GCC (6.2), I use it on all my Pi's.
Re: gcc ARM options
Posted: Tue Sep 27, 2016 4:08 pm
by Paeryn
swampdog wrote:Yes I was still using "-mpu=native" there. The wierdness was that the 'strace' doesn't show the double close. Then again I don't use strace that often.
strace doesn't show close() a second time because close() never gets called the second time, libc knows that the actual stream has been closed so doesn't need to close it again.
The the last thing fclose() does it to free the FILE structure from the pointer passed to it. Calling it again (especially so soon) the chances are the memory pointed to still holds correct data so fclose() can see that the associated file is already closed, but as far as it is concerned the pointer you passed is valid and it attempts to free it again - that's where free() notices that the pointer has already been freed and aborts.
jahboater wrote:The "=native" stuff works fine with the latest version of GCC (6.2), I use it on all my Pi's.
It has been fixed, and it has been back-ported to 4.9, but unless rasbpian updates it we won't have it by default.
Re: gcc ARM options
Posted: Wed Sep 28, 2016 10:40 pm
by swampdog
Ah, right. I've got it now. :-)
Re: gcc ARM options
Posted: Tue Oct 25, 2016 8:44 pm
by numb
I have this problem installing motion. Can you help me? I do not know how to use those options for gcc. Thank you
Re: gcc ARM options
Posted: Tue Oct 25, 2016 9:35 pm
by Paeryn
numb wrote:I have this problem installing motion. Can you help me? I do not know how to use those options for gcc. Thank you
Where ever the compile commands for motion use -mcpu=native you need to replace with -mcpu=cortex-a53 for an RPi3 specific build (resultant code will probably still work on an RPi2 but not RPi1), or take the option out (or change to -mcpu=arm1176jzf-s) and it will build a version compatible with all RPis.
Similarly where -march=native is you change to -march=armv8-a for RPi3 only or -march=armv6 (or just remove -march=native option) to build for all RPis.
Safest is to remove all -mcpu and -march options, the program will run on any RPi then but if you need performance and know it will only run on an RPi3 then use the RPi3 specific versions.
Re: gcc ARM options
Posted: Wed Oct 26, 2016 9:36 am
by debarghaya
This can be resolved by install GCC 6. Follow these steps :-
sudo apt-get update
sudo apt-get upgrade
Next, open /etc/apt/sources.list in your favorite editor and repalce jessie with stretch:
sudo vim /etc/apt/sources.list
Update your package list:
sudo apt-get update
Install GCC 6
sudo apt-get install gcc-6 g++-6
Last step is to revert back from Stretch to Jessie, open /etc/apt/sources.list and replace stretch with jessie, after that do an update to refresh the package list:
sudo apt-get update
The above procedure will keep GCC 4.9 as the default C and C++ compiler for any package that depends on it, if you want to compile a program with GCC 6 you will have to use gcc-6 or g++-6 when invoking the compilers.
In GCC 6 the default C++ standard is now -std=gnu++14, which means that by default any C++ program will be treated as a C++14. For C, the default is std=gnu11 starting from GCC 5.
Re: gcc ARM options
Posted: Wed Oct 26, 2016 9:16 pm
by numb
I did what you suggested changing the Makefile and removing options -march=native -mtune=native in CFLAGS =
Then I get this other error:
track.c:1136:25: error: storage size of ‘control_s’ isn’t known
struct v4l2_control control_s;
track.c:1136:25: warning: unused variable ‘control_s’ [-Wunused-variable]
<builtin>: recipe for target 'track.o' failed
make: *** [track.o] Error 1
Any clue? Did I miss something? Should I do something else? Maybe some option after the ./configure command?
Thank you.
Re: gcc ARM options
Posted: Wed Oct 26, 2016 10:37 pm
by Paeryn
numb wrote:I did what you suggested changing the Makefile and removing options -march=native -mtune=native in CFLAGS =
Thank you.
That looks like you've got an version of the source-code which doesn't work on the RPi, a quick look found one that looks like it doesn't include the needed header file (possibly the struct used to be defined elsewhere) https://github.com/sackmotion/motion, and a fork with track.c modified to include the current header which defines it https://github.com/Motion-Project/motion. This particular issue is nothing to do with this thread though (which is about the native cpu detection in the stock gcc crashing on the RPi3).
Re: gcc ARM options
Posted: Thu Oct 27, 2016 12:33 pm
by numb
thanks again very much.
Sorry but my knowledge of Linux is limited. I cloned the fork with git -clone command. However inside the folder there is no configure or makefile. How can use the fork to install the program? Do I have to merge the two?
Re: gcc ARM options
Posted: Thu Oct 27, 2016 12:40 pm
by numb
Forgive me. Just needed to install autoconf :)))
