CaptSunset
Using the Foundation Display with Pi3B
Mon Mar 07, 2016 4:28 pm
Hi guys-
I'm considering getting my new Pi3B one of the Official Foundation Touchscreens.
But I'm wondering if the back-centered Pi mounting position would interfere with the new onboard wifi & bluetooth, or make frequent connector socket access more of a hassle?
Is there any reason to wait; or is this still the best display for the money I'll see anytime soon?
oh, also; I guess I shouldn't bundle disparate Qs (but guys who start eleventy threads at once bug me) so here's a minor prob:
Twice, while sudo apt-get upgrade - ing the new 1.8 NOOBS, I got this line in the install crawl:
err http://raspberrypi.collabora.com wheezy/rpi armhf packages  403 Forbidden
If it keeps happening, how could I detect what is causing it?
Re: Using the Foundation Display with Pi3B
Mon Mar 07, 2016 4:53 pm
The error message is relating to Raspbian Wheezy you need Raspbian Jessie for the RPi 3B:
https://www.raspberrypi.org/downloads/raspbian
Retired disgracefully.....
piglet
Mon Mar 07, 2016 4:54 pm
I can help on the second. Just remove the collabora file from /etc/apt/sources.list directory.
Feel free to move it somewhere safe rather than deleting it...but you won't need it.
fruit-uk
Mon Mar 07, 2016 5:10 pm
The Pi3 fits the official display exactly as earlier versions do.
Both wireless and bluetooth working well too.
lmoss30
Mon Mar 07, 2016 9:31 pm
hi Fruit,
how did you get the Bluetooth working have tried numerous guides from here, and using blueman but my keyboard wont play ball,
Cheers
Mon Mar 07, 2016 9:40 pm
lmoss30 wrote:hi Fruit,
Cheers
I had issues with Blueman pairing both a Tablet and Smart Phone, in one of the other recent BT posts using CLi Bluetooth to pair was recommended:
https://wiki.archlinux.org/index.php/bl ... ia_the_CLI
There have been several posts if you can find them over the last fortnight on RPi 3B Bluetooth......
fruit-uk
I used
bluetoothctl -a
. This will generate a
[bluetooth]
prompt and may include your agent MAC.
list will show available commands.
From memory you should issue scan which should pick up any local devices then pair <MAC> to pair with device whose MAC address is <MAC>, trust <MAC> to make it a trusted device, finally connect <MAC>, quit.
Hopefully your device will be working.
I and others have had issues with blueman upsetting things so have removed it.
Hope that helps.
lmoss30
Mon Mar 07, 2016 11:17 pm
I will try the -a tomorrow, just out of interest what will that do
Closet I have got so far is the keyboard saying it connected by no keys working,
Do you think keyboard will work as it doesn't have a default pin, it generates one on connect which then has to be entered on the keybaord to pair successfully
fruit-uk
Tue Mar 08, 2016 6:30 am
From the manual
-a, --agent=CAPABILITY Register agent handler
To read the manual type
man bluetoothctl
in a console window
After the pair <MAC> command bluetoothctl will generate a random PIN that you enter on the keyboard
There have been quite a few threads on bluetooth keyboards recently so if you have problems with a specific keyboard try a search
