I have a Rii mini i8 Bluetooth keyboard.
I can pair this OK using blueman-manager, but after a reboot it does not always seem to reconnect on it's own. I have to connect a USB keyboard and go to 'device' in the manager and choose connect.
Sometimes, that doesn't work, and I have to remove and re-add the device.
Even if I do this from the command line (e.g. https://rachaelandtom.info/content/gett ... berry-pi-3) it does no always seem to stick.
Anyone else having issue in general, or has the hardware and it works fine ?
Under OpenElec, the device is fine, though it needs a workaround for a bug in OpenElec itself (which goes back to Pi2 with some other Bluetooth devices as well) - https://github.com/OpenELEC/service.ope ... -191947203
