cosmicboy
RPI3 bluetooth Audio Sink not working
Sat Mar 05, 2016 10:12 pm
I have been using a RPI 2 as a bluetooth audio sink successfully for quite some time now.
Today I tried the same setup with my new RPI3, however, the device only appears as a Telephony Service on my Android phone, although device class 0x20041C has been set.
Is it possible that this is due to the bluetooth chip in the RPI 3?
I followed exactly the steps in http://www.instructables.com/id/Enhance ... th-Blueto/
Thanks for any hint.
Marcel
cosmicboy
Re: RPI3 bluetooth Audio Sink not working
Fri Mar 11, 2016 4:05 am
Any ideas?
Douglas6
Fri Mar 11, 2016 2:44 pm
Are you running OSMC or Raspbian? Are you sure you updated 'Class=0x20041C' in both /etc/bluetooth/main.conf and /var/lib/bluetooth/XX:XX:XX:XX:XX:XX/settings?
The latest (beta) version of OSMC has A2DP built in, you might give that a try.
cosmicboy
Fri Mar 11, 2016 8:02 pm
Yes. hciconfig -a shows the class is 0x20041c inderd. For services it lists audio only however.
I am running raspbian jessie
Douglas6
Fri Mar 11, 2016 8:25 pm
A couple of others have succeeded with A2DP on Jessie using a guide mentioned in this post: viewtopic.php?p=923929#p923929
cosmicboy
Sun Mar 13, 2016 8:53 am
@Douglas6: thanks a lot. That link worked for me :-)
