r100gspd
RPI3 Wifi powersaving deactivate
Sat Mar 05, 2016 5:36 am
Hey guys,
Wifi is working fine on my pi3 but after a while it turns off
How can I deavtivate the powersaving mode?
Any ideas?
THX,
Stefan
A350XWB
Re: RPI3 Wifi powersaving deactivate
Sat Mar 05, 2016 11:11 am
For me, adding the following code to the /etc/network/interfaces file below the wlan0 section solved the problem
pre-up iw dev wlan0 set power_save off
post-down iw dev wlan0 set power_save on
See also this thread, viewtopic.php?p=919552#p919552
jaynew
Sat Mar 05, 2016 2:44 pm
I followed the older common solution:
modify your /etc/network/interfaces file by adding
wireless-power off
in the wlan0 section.
Confirmed setting stays through multiple reboots with both
iwconfig
and
iw wlan0 get power_save
r100gspd
Sun Mar 06, 2016 8:41 am
THX! Seems to work.
Stefan
CrAzYLuKe
Fri Jun 24, 2016 1:12 pm
I would like to do write in the code, but I have an issue. Maybe somone can help me out with it? :-)
Can't find /network in /etc and therefore "interfaces", too.
Best
Luke
login as: root
[email protected]'s password:
#                  OpenELEC                  #
#             http://openelec.tv             #
OpenELEC (official) Version: 6.0.3
OpenELEC-Schlafzimmer:~ # cd /etc
OpenELEC-Schlafzimmer:/etc # cd /network
-sh: cd: can't cd to /network
Fri Jun 24, 2016 3:30 pm
/network wouldn't be in /etc.
network would be in /etc though.
Putting the "/" in front means "start at the root of the tree" (absolute path). Leaving it out means "start from where you are at the moment" (relative path).
cd /etc <- changes to /etc
cd /etc/network <- changes to /etc/network
cd /network <- tries to change to /network, which doesn't exist.
CrAzYLuKe
Sun Jun 26, 2016 7:55 pm
Thank you very much, but it didn't brought me a step forward to the goal :-(
OpenELEC-Schlafzimmer:/ # cd /
OpenELEC-Schlafzimmer:/ # cd /etc/network
-sh: cd: can't cd to /etc/network
OpenELEC-Schlafzimmer:/etc # cd /etc/network
SonOfAMotherlessGoat
Sun Jun 26, 2016 8:41 pm
You don't have an /etc/network directory.
ls -lah /etc/network
ls -lah /etc
Account Inactive
broe23
Mon Jun 27, 2016 1:39 am
This is the proper way to shut of Power Management in Linux Distro's based on Debian.
In a Command Window do the following first: sudo iwconfig wlan0 power off
Second do: cd /etc/pm/power.d and press Enter
Third: sudo nano /etc/pm/power.d/wireless
Fourth: #!/bin/sh
/sbin/iwconfig wlan0 power off
Fifth: Ctrl X to save it. Press Y, then Enter and then Nano will close.
Sixth: Reboot and Wireless Power Management is permanently shutdown.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good.
