VladimirPo
Re: [RPi3] SSH not working via wifi
Mon Dec 04, 2017 6:15 pm
This solved SSH over wifi issues for me:
(SSH2_MSG_UNIMPLEMENTED)
https://www.eknori.de/2017-09-01/ssh2_m ... -rhel-7-2/
Shortly:
To solve the issue, open the configuration for the connection and navigate to SSH -> Kex. In the “Algorithm selection policy”, move the “Diffie-Hellman group 14” entry to the first position in the list.
qcha
Mon Aug 27, 2018 3:59 pm
maulapi wrote:
Thu Mar 02, 2017 4:23 pm
I have RPi3 with Raspbian Jessie
- no problem with cabled LAN
- with wifi via USB dongle TL-WN725N no problem with port 80 but not possible to connect via SSH
I search with google for months but trick in this post ( page 4 ) SOLVE!!!:
- i add this line in bottom of /etc/ssh/sshd_config:
IPQoS cs0 cs0
- restart ssh service and now SSH work also after reboot
Thank you for all
THANK
YOU
SO
MUCH
7hours that I am looking for a solution :D :D :D
pandovich
Wed Oct 03, 2018 12:14 pm
For me, after months the only way to get a working WiFi connection on boot without an eth cable plugged in is:
ifdown eth0
/etc/init.d/ssh restart
at the bottom of /etc/rc.local
So sad. :/
RafalSkolasinski
Sun Oct 28, 2018 1:25 pm
Guys, It is 2018, almost November. This issue exist since 2016.
Why this is still a problem and people have to struggle to find a solution?
If the fix is adding a single line why it is not out there by default?
MikaelGagoshidze
Sun Feb 24, 2019 9:46 pm
It's strange that after three years this issue still exists. I read the hole discussion. Unfortunately, "IPQoS cs0 cs0" solution did not work for me. I have exactly the same problem with SSH over WiFi, only difference is that my PuTTY does not even ask me to login (as if there's no such IP at all). SSH works on eth0, as well as while being connected to mobile hotspot.
Sorry for dragging you back in 2016, but do you have any suggestions?
I just added IPQoS cs0 cs0 in the bottom of /etc/ssh/sshd_config and restarted the daemon: sudo service ssh restart.
Am I missing something?
bartvalom
Sat Aug 10, 2019 8:14 pm
I had similar problems using SSH to my Raspberry pi zero w and applied the solution mentioned here (adding IPQoS cs0 cs0 at the end of /etc/ssh/sshd_config) and it worked.
Thanks,
Regards,
Bart
