Page 2 of 3
Re: rpi3 wifi issues
Posted: Thu Mar 10, 2016 3:30 am
by w6kd
Used apt-get update and apt-get dist-upgrade on a wheezy image working on RasPi B/B+/2B. The two files in /lib/firmware/brcm were missing, so I downloaded them.
On boot I still can't see the onboard wlan0...ifconfig lists only eth0 and lo. Now I get these messages in dmesg:
brcmfmac: brcmf_sdio_drivestrengthinit: No SDIO drive strength init done for chip 43430 rev 1 pmurev 24
usbcore: registered new interface driver brcmfmac
and three of these:
brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
Regards
Bob
Posted: Fri Mar 11, 2016 10:24 am
by jaymuc
tomid88 wrote:WiFi icon was visible in the upper right corner
It is, but "no interface found" (or something like that)
tomid88 wrote:If you just want to eliminate HW issues, sometimes starting from scratch is the easiest. Have you tried this?
I did, as it is my first RPi anyway. I set up the SD a dozen times. Tried Raspberry, Raspberry lite, OSMC and Ubuntu Mate. The latter wouldn't work at all, I'm gonna try again later. Couldn't try installing Raspbian via Noobs, as my Logitech Keyboard was not recognized and I can't have LAN and Screen at the same time due to the flat I'm living in at the moment... Don't ask... :lol:
Close visual inspection for shorts, solder balls etc. would follow (and possibly carefully / lightly brush the sides of all components with a new, dry brush (e.g. a toothbrush)). But this is grasping...
I'm not sure whether I will try this. I don't like the idea of returning the product as a loyal customer, but I don't see any alternative.
Again, good luck and don't give up easily ;)
At least I will never again have to search on anything related to sudo, nano, apt-get, raspi-config, ifconfig etc. Never ever. I'm not a complete Linux-Noob anymore! ;)
Posted: Sun Mar 20, 2016 3:47 pm
by asduskun
hi can anyone tell me what does it mean the error in the picture below? i cannot connect wifi, even it connects it drops in a while. it is rasberry pi 3 and i m very new to linux. thanks
Posted: Sun Mar 20, 2016 4:20 pm
by DougieLawson
That stuff just means the device driver is sending messages that you can 100% completely ignore. Mine does the same and it's working perfectly.
You should run sudo apt-get update && sudo apt-get -y upgrade some time in the near future to make sure you've got the kernel and stuff from 18th March.
Posted: Sun Mar 20, 2016 7:22 pm
by asduskun
DougieLawson wrote:That stuff just means the device driver is sending messages that you can 100% completely ignore. Mine does the same and it's working perfectly.
Thanks a lot
Posted: Sat Apr 02, 2016 11:13 pm
by ddurdle
No wlan0 or wlan1 showing up on a new pi3. Even when swapping out SD card from another wifi-working pi3.
Tried enabling device tree (if it was ever disabled).
Any ideas. No errors in dmsg.
Posted: Sun Apr 03, 2016 6:17 am
by DougieLawson
If the same SDCard works on another RPi3 then you have to assume you've got a hardware failure so should RMA it with the folks you bought it from.
Posted: Tue May 03, 2016 2:19 am
by JimHeaton
I can consistently reproduce WiFi not working right from a fresh Raspbian Jessie image, but working fine from a fresh NOOBS install on my PI 3.
When starting by burning the latest Raspbian image directly to the SD card and booting, configuring WiFi from the desktop *appears* to work and the icon shows a connection, but no services on the machine trying to use the network (even a loopback to 127.0.0.1) will connect to a name or a specific IP. The network involved is running WPA2 Personal and AES although I don't believe encryption is the issue since the adapter is connecting.
Installing Raspbian Jessie under NOOBS instead, the WiFi configuration steps are identical, but there is IP connectivity like SSH and the browser.
Jim
Posted: Thu May 05, 2016 6:52 pm
by justinrains
I can't get mine to work either. I see the icon and it asks me my password, but never connects. No activity on the icons or anything..
Re: rpi3 wifi issues (not finding wifi)
Posted: Fri May 06, 2016 5:06 am
by ALT
I also had a problem of not finding my network on the RP3. SoI changed my radio channel on my modem from 13 to 9 (lower than 10). After that the RP3 was able to pick the signal up. I read this on another forum.
Posted: Sat May 07, 2016 9:04 pm
by Ukbajan
@alt thanks. Had this since early March. I browsed around then for the solution, too soon. My router was on 12 swapped to channel 7. Luckily that band wasn't congested.
Ukbajan.
Posted: Sun May 08, 2016 5:04 pm
by rnamdos
garlicbready wrote:First try the following
# Remove the Driver
modprobe -r brcmfmac
# Load in the Driver
modprobe brcmfmac
# Check Dmesg for any errors
dmesg
# List all network ports
ifconfig -a
If you see an error in the dmesg log like this, then your likley missing the needed firmware files
brcmfmac_sdio mmc1:0001:1: Direct firmware load for brcm/brcmfmac43430-sdio.bin failed with error -2
In that case go to https://github.com/RPi-Distro/firmware- ... 80211/brcm
and download the brcmfmac43430-sdio.bin and brcmfmac43430-sdio.txt files into the directory
/lib/firmware/brcm/ then try again
Followed this and I was able to stream spotify over my phones 4G. THANK YOU!
Posted: Tue May 17, 2016 7:56 pm
by GeertB
i have the same issue as Jaymuc earlier in this thread, no internal wifi detected and in dmesg :
mmc1: error -110 whilst initialising SDIO card
I tried all sollutions in this thread. (including a fresh raspian install on new sd card).
However my wifi was working earlier and it suddenly just died ,can i conclude that i have an hardware faillure on my Pi ?
Thanks.
Posted: Wed Jun 29, 2016 4:27 pm
by ahnjoan
I have a similar issue, no wlan0 interface on a RPi3. If I move the same SD card to other RPi3s the wlan0 interface appears just fine. I'm assuming that the board where wlan0 doesn't show up, is faulty, but I've included my results from other queries in this thread just in case. I'm hoping if anyone has any other thoughts they might share them. The one thing to note is that the dmesg between the working and non working board are slightly different even though I'm using the same SD card.
I have done the following
apt-get update
apt-get upgrade
rpi-update
I have also done the following
raspi-config and gone to the A5 options, that for me is SPI rather than "Device Tree", but I've searched and don't see a Device Tree.
For ease of reading, I've diff'd the dmesg results, full dmesg are included below. The working (wlan0 found) is on the left
diff working-rmTime.txt broken-rmTime.txt
22c22
< Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa22082 bcm2709.serial=0xf02d1d68 smsc95xx.macaddr=B8:27:EB:2D:1D:68 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,38400 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
> Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa22082 bcm2709.serial=0xf4c20a78 smsc95xx.macaddr=B8:27:EB:C2:0A:78 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,38400 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
63c63
< [bcm2709_boot_secondary] cpu:1 started (0) 17
> [bcm2709_boot_secondary] cpu:1 started (0) 18
71c71
< [bcm2709_boot_secondary] cpu:3 started (0) 16
> [bcm2709_boot_secondary] cpu:3 started (0) 18
183d182
< Indeed it is in host mode hprt0 = 00021501
186c185
< mmc0: host does not support reading read-only switch, assuming write-enable
193a193,194
> usb 1-1: new high-speed USB device number 2 using dwc_otg
> Indeed it is in host mode hprt0 = 00001101
197a199
199a202,203
> mmc0: new high speed SDHC card at address aaaa
> mmcblk0: mmc0:aaaa SL08G 7.40 GiB
203,204d206
< usb 1-1: new high-speed USB device number 2 using dwc_otg
< Indeed it is in host mode hprt0 = 00001101
209,211d210
< Waiting for root device /dev/mmcblk0p2...
< mmc0: new high speed SDHC card at address aaaa
< mmcblk0: mmc0:aaaa SL08G 7.40 GiB
213,215d211
< mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
< mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
218d213
< mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
220d214
< mmc1: new high speed SDIO card at address 0001
222a217
> smsc95xx v1.0.4
225a221
> smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:c2:0a:78
230,232c226
< smsc95xx v1.0.4
< smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:2d:1d:68
< random: systemd urandom read with 80 bits of entropy available
> random: systemd urandom read with 53 bits of entropy available
279a274
> fuse init (API version 7.23)
280a276
> i2c /dev entries driver
284d279
< fuse init (API version 7.23)
289d283
< i2c /dev entries driver
305c299
< systemd-udevd[136]: starting version 215
> systemd-udevd[137]: starting version 215
309,312c303,305
< usbcore: registered new interface driver brcmfmac
< brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Dec 15 2015 18:10:45 version 7.45.41.23 (r606571) FWID 01-cc4eda9c
< brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
> systemd-journald[135]: Received request to flush runtime journal from PID 1
> uart-pl011 3f201000.uart: no DMA platform data
> Adding 102396k swap on /var/swap.  Priority:-1 extents:4 across:1658876k SSFS
324,339d316
< systemd-journald[134]: Received request to flush runtime journal from PID 1
< brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
< brcmfmac: brcmf_add_if: ignore IF event
< IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
< brcmfmac: power management disabled
< uart-pl011 3f201000.uart: no DMA platform data
< random: nonblocking pool is initialized
< Adding 102396k swap on /var/swap.  Priority:-1 extents:4 across:1658876k SSFS
< cfg80211: Regulatory domain changed to country: GB
< cfg80211:  DFS Master region: ETSI
< cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
< cfg80211:   (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
< cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
< cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
< cfg80211:   (5490000 KHz - 5710000 KHz @ 160000 KHz), (N/A, 2700 mBm), (0 s)
< cfg80211:   (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
341a319
RPi3 where wlan0 is found.
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.14-v7+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #895 SMP Sun Jun 26 13:59:02 BST 2016
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
[    0.000000] cma: Reserved 8 MiB at 0x3a800000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 241664
[    0.000000] free_area_init_node: node 0, pgdat 808c0e00, node_mem_map b9fa6000
[    0.000000]   Normal zone: 2124 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 241664 pages, LIFO batch:31
[    0.000000] [bcm2709_smp_init_cpus] enter (9520->f3003010)
[    0.000000] [bcm2709_smp_init_cpus] ncores=4
[    0.000000] PERCPU: Embedded 13 pages/cpu @b9f62000 s22592 r8192 d22464 u53248
[    0.000000] pcpu-alloc: s22592 r8192 d22464 u53248 alloc=13*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 239540
[    0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa22082 bcm2709.serial=0xf02d1d68 smsc95xx.macaddr=B8:27:EB:2D:1D:68 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,38400 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 939080K/966656K available (6344K kernel code, 432K rwdata, 1712K rodata, 476K init, 764K bss, 19384K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
    lowmem  : 0x80000000 - 0xbb000000   ( 944 MB)
    modules : 0x7f000000 - 0x80000000   (  16 MB)
      .text : 0x80008000 - 0x807e6470   (8058 kB)
      .init : 0x807e7000 - 0x8085e000   ( 476 kB)
      .data : 0x8085e000 - 0x808ca108   ( 433 kB)
       .bss : 0x808cd000 - 0x8098c1ac   ( 765 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000025] Switching to timer-based delay loop, resolution 52ns
[    0.000281] Console: colour dummy device 80x30
[    0.001334] console [tty1] enabled
[    0.001388] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001456] pid_max: default: 32768 minimum: 301
[    0.001792] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001835] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002774] Disabling cpuset control group subsystem
[    0.002829] Initializing cgroup subsys io
[    0.002879] Initializing cgroup subsys memory
[    0.002939] Initializing cgroup subsys devices
[    0.002982] Initializing cgroup subsys freezer
[    0.003025] Initializing cgroup subsys net_cls
[    0.003096] CPU: Testing write buffer coherency: ok
[    0.003184] ftrace: allocating 21209 entries in 63 pages
[    0.052946] CPU0: update cpu_capacity 1024
[    0.053015] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.053049] [bcm2709_smp_prepare_cpus] enter
[    0.053196] Setting up static identity map for 0x8240 - 0x8274
[    0.054844] [bcm2709_boot_secondary] cpu:1 started (0) 17
[    0.055173] [bcm2709_secondary_init] enter cpu:1
[    0.055214] CPU1: update cpu_capacity 1024
[    0.055220] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.055596] [bcm2709_boot_secondary] cpu:2 started (0) 17
[    0.055858] [bcm2709_secondary_init] enter cpu:2
[    0.055879] CPU2: update cpu_capacity 1024
[    0.055885] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.056241] [bcm2709_boot_secondary] cpu:3 started (0) 16
[    0.056423] [bcm2709_secondary_init] enter cpu:3
[    0.056443] CPU3: update cpu_capacity 1024
[    0.056449] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.056509] Brought up 4 CPUs
[    0.056607] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.056637] CPU: All CPU(s) started in HYP mode.
[    0.056663] CPU: Virtualization extensions available.
[    0.057297] devtmpfs: initialized
[    0.067392] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.067748] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.068491] pinctrl core: initialized pinctrl subsystem
[    0.069043] NET: Registered protocol family 16
[    0.074226] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.081237] bcm2709: Mini UART enabled
[    0.081299] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.081346] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.081526] Serial: AMBA PL011 UART driver
[    0.081679] uart-pl011 3f201000.uart: could not find pctldev for node /soc/[email protected]/uart0_pins, deferring probe
[    0.081884] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.145074] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[    0.145671] SCSI subsystem initialized
[    0.145870] usbcore: registered new interface driver usbfs
[    0.145980] usbcore: registered new interface driver hub
[    0.146098] usbcore: registered new device driver usb
[    0.152507] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-06-27 17:23
[    0.179701] clocksource: Switched to clocksource arch_sys_counter
[    0.224407] FS-Cache: Loaded
[    0.224707] CacheFiles: Loaded
[    0.236912] NET: Registered protocol family 2
[    0.237787] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.237924] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.238135] TCP: Hash tables configured (established 8192 bind 8192)
[    0.238249] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.238317] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.238562] NET: Registered protocol family 1
[    0.238896] RPC: Registered named UNIX socket transport module.
[    0.238928] RPC: Registered udp transport module.
[    0.238956] RPC: Registered tcp transport module.
[    0.238984] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.240080] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    0.241421] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.254666] VFS: Disk quotas dquot_6.6.0
[    0.254993] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.257274] FS-Cache: Netfs 'nfs' registered for caching
[    0.258188] NFS: Registering the id_resolver key type
[    0.258251] Key type id_resolver registered
[    0.258279] Key type id_legacy registered
[    0.260629] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.260792] io scheduler noop registered
[    0.260831] io scheduler deadline registered (default)
[    0.260905] io scheduler cfq registered
[    0.263426] BCM2708FB: allocated DMA memory fac00000
[    0.263473] BCM2708FB: allocated DMA channel 0 @ f3007000
[    0.268674] Console: switching to colour frame buffer device 82x26
[    0.273227] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[    0.275577] console [ttyS0] disabled
[    0.277045] 3f215040.uart: ttyS0 at MMIO 0x3f215040 (irq = 59, base_baud = 31250000) is a 16550
[    2.466824] console [ttyS0] enabled
[    3.343126] bcm2835-rng 3f104000.rng: hwrng registered
[    3.360265] vc-cma: Videocore CMA driver
[    3.373560] vc-cma: vc_cma_base      = 0x00000000
[    3.389203] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    3.406909] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    3.424776] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[    3.467371] brd: module loaded
[    3.486461] loop: module loaded
[    3.498114] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[    3.521728] Loading iSCSI transport class v2.0-870.
[    3.538503] usbcore: registered new interface driver smsc95xx
[    3.557357] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    3.776413] Core Release: 2.80a
[    3.787317] Setting default values for core params
[    3.803260] Finished setting default values for core params
[    4.021916] Using Buffer DMA mode
[    4.033311] Periodic Transfer Interrupt Enhancement - disabled
[    4.052381] Multiprocessor Interrupt Enhancement - disabled
[    4.070623] OTG VER PARAM: 0, OTG VER FLAG: 0
[    4.085171] Dedicated Tx FIFOs mode
[    4.097354] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[    4.129965] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[    4.204794] dwc_otg: Microframe scheduler enabled
[    4.204842] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x80446a9c
[    4.224230] WARN::hcd_init_fiq:414: FIQ ASM at 0x80446e0c length 36
[    4.244641] WARN::hcd_init_fiq:439: MPHI regs_base at 0xbb922000
[    4.264291] dwc_otg 3f980000.usb: DWC OTG Controller
[    4.280738] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    4.304341] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[    4.322651] Init: Port Power? op_state=1
[    4.335882] Init: Power Port (0)
[    4.347149] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.369122] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.392410] usb usb1: Product: DWC OTG Controller
[    4.408011] usb usb1: Manufacturer: Linux 4.4.14-v7+ dwc_otg_hcd
[    4.427587] usb usb1: SerialNumber: 3f980000.usb
[    4.443707] hub 1-0:1.0: USB hub found
[    4.456399] hub 1-0:1.0: 1 port detected
[    4.470139] dwc_otg: FIQ enabled
[    4.470149] dwc_otg: NAK holdoff enabled
[    4.470157] dwc_otg: FIQ split-transaction FSM enabled
[    4.470194] Module dwc_common_port init
[    4.470443] usbcore: registered new interface driver usb-storage
[    4.490188] mousedev: PS/2 mouse device common for all mice
[    4.509101] bcm2835-cpufreq: min=600000 max=1200000
[    4.525486] sdhci: Secure Digital Host Controller Interface driver
[    4.545595] sdhci: Copyright(c) Pierre Ossman
[    4.560432] sdhost: log_buf @ bac13000 (fac13000)
[    4.649730] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    4.669898] Indeed it is in host mode hprt0 = 00021501
[    4.699937] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[    4.719007] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[    4.758570] mmc0: host does not support reading read-only switch, assuming write-enable
[    4.769820] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.770254] ledtrig-cpu: registered to indicate activity on CPUs
[    4.770373] hidraw: raw HID events driver (C) Jiri Kosina
[    4.770567] usbcore: registered new interface driver usbhid
[    4.770570] usbhid: USB HID core driver
[    4.771144] Initializing XFRM netlink socket
[    4.771169] NET: Registered protocol family 17
[    4.771306] Key type dns_resolver registered
[    4.771833] Registering SWP/SWPB emulation handler
[    4.772703] registered taskstats version 1
[    4.772905] vc-sm: Videocore shared memory driver
[    4.772913] [vc_sm_connected_init]: start
[    4.773433] [vc_sm_connected_init]: end - returning 0
[    4.774818] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[    4.775202] of_cfs_init
[    4.775285] of_cfs_init: OK
[    4.859733] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    4.859856] Indeed it is in host mode hprt0 = 00001101
[    5.059977] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    5.059986] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    5.060667] hub 1-1:1.0: USB hub found
[    5.060750] hub 1-1:1.0: 5 ports detected
[    5.147763] Waiting for root device /dev/mmcblk0p2...
[    5.164724] mmc0: new high speed SDHC card at address aaaa
[    5.183246] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
[    5.199280]  mmcblk0: p1 p2
[    5.226930] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    5.246422] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    5.265892] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    5.271728] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[    5.271733] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[    5.332960] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    5.409735] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    5.442787] mmc1: new high speed SDIO card at address 0001
[    5.530011] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    5.552282] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    5.573370] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[    5.573671] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
[    5.573676] EXT4-fs (mmcblk0p2): recovery complete
[    5.597601] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    5.597650] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    5.598473] devtmpfs: mounted
[    5.599208] Freeing unused kernel memory: 476K (807e7000 - 8085e000)
[    5.711235] smsc95xx v1.0.4
[    5.783126] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:2d:1d:68
[    5.847817] random: systemd urandom read with 80 bits of entropy available
[    5.874142] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    5.918297] systemd[1]: Detected architecture 'arm'.
[    6.040871] NET: Registered protocol family 10
[    6.057359] systemd[1]: Inserted module 'ipv6'
[    6.075250] systemd[1]: Set hostname to <raspberrypi>.
[    6.462751] systemd[1]: Expecting device dev-ttyS0.device...
[    6.483712] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    6.510354] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    6.536652] systemd[1]: Starting Remote File Systems (Pre).
[    6.557159] systemd[1]: Reached target Remote File Systems (Pre).
[    6.577403] systemd[1]: Starting Encrypted Volumes.
[    6.595672] systemd[1]: Reached target Encrypted Volumes.
[    6.613759] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    6.645525] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    6.677405] systemd[1]: Starting Swap.
[    6.692362] systemd[1]: Reached target Swap.
[    6.707050] systemd[1]: Expecting device dev-mmcblk0p1.device...
[    6.728940] systemd[1]: Starting Root Slice.
[    6.745489] systemd[1]: Created slice Root Slice.
[    6.761394] systemd[1]: Starting User and Session Slice.
[    6.781038] systemd[1]: Created slice User and Session Slice.
[    6.800081] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    6.823682] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    6.846474] systemd[1]: Starting Delayed Shutdown Socket.
[    6.866376] systemd[1]: Listening on Delayed Shutdown Socket.
[    6.885429] systemd[1]: Starting Journal Socket (/dev/log).
[    6.905739] systemd[1]: Listening on Journal Socket (/dev/log).
[    6.925267] systemd[1]: Starting udev Control Socket.
[    6.943906] systemd[1]: Listening on udev Control Socket.
[    6.961866] systemd[1]: Starting udev Kernel Socket.
[    6.980253] systemd[1]: Listening on udev Kernel Socket.
[    6.997958] systemd[1]: Starting Journal Socket.
[    7.015375] systemd[1]: Listening on Journal Socket.
[    7.032080] systemd[1]: Starting System Slice.
[    7.048942] systemd[1]: Created slice System Slice.
[    7.065312] systemd[1]: Starting File System Check on Root Device...
[    7.110273] systemd[1]: Starting system-systemd\x2dfsck.slice.
[    7.131738] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    7.152400] systemd[1]: Starting system-autologin.slice.
[    7.172070] systemd[1]: Created slice system-autologin.slice.
[    7.191130] systemd[1]: Starting system-serial\x2dgetty.slice.
[    7.212513] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    7.233432] systemd[1]: Starting Increase datagram queue length...
[    7.258157] systemd[1]: Starting Restore / save the current clock...
[    7.295837] systemd[1]: Starting Load Kernel Modules...
[    7.321170] systemd[1]: Starting udev Coldplug all Devices...
[    7.345631] systemd[1]: Mounted Huge Pages File System.
[    7.363919] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    7.420827] systemd[1]: Started Set Up Additional Binary Formats.
[    7.443141] systemd[1]: Mounting POSIX Message Queue File System...
[    7.469963] systemd[1]: Mounting Debug File System...
[    7.491793] fuse init (API version 7.23)
[    7.493481] systemd[1]: Starting Slices.
[    7.521808] systemd[1]: Reached target Slices.
[    7.541354] systemd[1]: Mounted Debug File System.
[    7.559725] systemd[1]: Mounted POSIX Message Queue File System.
[    7.560453] i2c /dev entries driver
[    7.594637] systemd[1]: Started File System Check on Root Device.
[    7.625910] systemd[1]: Started Increase datagram queue length.
[    7.648463] systemd[1]: Started Restore / save the current clock.
[    7.671244] systemd[1]: Started Load Kernel Modules.
[    7.723703] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    7.759604] systemd[1]: Time has been changed
[    7.777444] systemd[1]: Started udev Coldplug all Devices.
[    7.939311] systemd[1]: Starting Create Static Device Nodes in /dev...
[    7.990396] systemd[1]: Starting Apply Kernel Variables...
[    8.013671] systemd[1]: Mounting FUSE Control File System...
[    8.038299] systemd[1]: Mounting Configuration File System...
[    8.062470] systemd[1]: Starting Syslog Socket.
[    8.080632] systemd[1]: Listening on Syslog Socket.
[    8.097224] systemd[1]: Starting Journal Service...
[    8.120979] systemd[1]: Started Journal Service.
[    8.277250] systemd-udevd[136]: starting version 215
[    8.631542] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[    8.643869] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    8.898460] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    8.943621] usbcore: registered new interface driver brcmfmac
[    9.067880] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Dec 15 2015 18:10:45 version 7.45.41.23 (r606571) FWID 01-cc4eda9c
[    9.088477] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[    9.273732] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[    9.273761] cfg80211: World regulatory domain updated:
[    9.273770] cfg80211:  DFS Master region: unset
[    9.273779] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    9.273793] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    9.273805] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    9.273817] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[    9.273832] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    9.273846] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[    9.273858] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[    9.273870] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[    9.273882] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[    9.566714] systemd-journald[134]: Received request to flush runtime journal from PID 1
[   10.304020] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[   10.304046] brcmfmac: brcmf_add_if: ignore IF event
[   10.308748] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   10.308800] brcmfmac: power management disabled
[   10.435404] uart-pl011 3f201000.uart: no DMA platform data
[   10.451317] random: nonblocking pool is initialized
[   10.758227] Adding 102396k swap on /var/swap.  Priority:-1 extents:4 across:1658876k SSFS
[   10.792851] cfg80211: Regulatory domain changed to country: GB
[   10.792872] cfg80211:  DFS Master region: ETSI
[   10.792881] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   10.792895] cfg80211:   (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   10.792910] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   10.792925] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[   10.792938] cfg80211:   (5490000 KHz - 5710000 KHz @ 160000 KHz), (N/A, 2700 mBm), (0 s)
[   10.792951] cfg80211:   (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[   11.371906] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[   11.372145] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   13.000819] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   13.001639] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x43E1
[   14.858258] Bluetooth: Core ver 2.21
[   14.858347] NET: Registered protocol family 31
[   14.858357] Bluetooth: HCI device and connection manager initialized
[   14.859260] Bluetooth: HCI socket layer initialized
[   14.859302] Bluetooth: L2CAP socket layer initialized
[   14.859340] Bluetooth: SCO socket layer initialized
[   14.876005] Bluetooth: HCI UART driver ver 2.3
[   14.876027] Bluetooth: HCI UART protocol H4 registered
[   14.876037] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   14.876217] Bluetooth: HCI UART protocol BCM registered
[   15.120484] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   15.120515] Bluetooth: BNEP filters: protocol multicast
[   15.123704] Bluetooth: BNEP socket layer initialized
RPi3 where wlan0 is NOT found
[    0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa22082 bcm2709.serial=0xf4c20a78 smsc95xx.macaddr=B8:27:EB:C2:0A:78 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,38400 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000282] Console: colour dummy device 80x30
[    0.001336] console [tty1] enabled
[    0.001391] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001457] pid_max: default: 32768 minimum: 301
[    0.002780] Disabling cpuset control group subsystem
[    0.002837] Initializing cgroup subsys io
[    0.002887] Initializing cgroup subsys memory
[    0.002947] Initializing cgroup subsys devices
[    0.002989] Initializing cgroup subsys freezer
[    0.003032] Initializing cgroup subsys net_cls
[    0.003103] CPU: Testing write buffer coherency: ok
[    0.003189] ftrace: allocating 21209 entries in 63 pages
[    0.052935] CPU0: update cpu_capacity 1024
[    0.053004] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.053037] [bcm2709_smp_prepare_cpus] enter
[    0.053189] Setting up static identity map for 0x8240 - 0x8274
[    0.054837] [bcm2709_boot_secondary] cpu:1 started (0) 18
[    0.055169] [bcm2709_secondary_init] enter cpu:1
[    0.055211] CPU1: update cpu_capacity 1024
[    0.055217] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.055588] [bcm2709_boot_secondary] cpu:2 started (0) 17
[    0.055850] [bcm2709_secondary_init] enter cpu:2
[    0.055871] CPU2: update cpu_capacity 1024
[    0.055877] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.056232] [bcm2709_boot_secondary] cpu:3 started (0) 18
[    0.056414] [bcm2709_secondary_init] enter cpu:3
[    0.056434] CPU3: update cpu_capacity 1024
[    0.056440] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.056500] Brought up 4 CPUs
[    0.056599] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.056628] CPU: All CPU(s) started in HYP mode.
[    0.056654] CPU: Virtualization extensions available.
[    0.057295] devtmpfs: initialized
[    0.067374] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.067732] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.068474] pinctrl core: initialized pinctrl subsystem
[    0.069027] NET: Registered protocol family 16
[    0.074209] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.081218] bcm2709: Mini UART enabled
[    0.081281] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.081329] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.081509] Serial: AMBA PL011 UART driver
[    0.081662] uart-pl011 3f201000.uart: could not find pctldev for node /soc/[email protected]/uart0_pins, deferring probe
[    0.081866] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.145067] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[    0.145669] SCSI subsystem initialized
[    0.145868] usbcore: registered new interface driver usbfs
[    0.145978] usbcore: registered new interface driver hub
[    0.146095] usbcore: registered new device driver usb
[    0.152499] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-06-27 17:23
[    0.179694] clocksource: Switched to clocksource arch_sys_counter
[    0.224480] FS-Cache: Loaded
[    0.224779] CacheFiles: Loaded
[    0.237036] NET: Registered protocol family 2
[    0.237908] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.238046] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.238257] TCP: Hash tables configured (established 8192 bind 8192)
[    0.238370] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.238438] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.238683] NET: Registered protocol family 1
[    0.239019] RPC: Registered named UNIX socket transport module.
[    0.239051] RPC: Registered udp transport module.
[    0.239079] RPC: Registered tcp transport module.
[    0.239107] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.240205] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    0.241546] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.254786] VFS: Disk quotas dquot_6.6.0
[    0.255112] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.257388] FS-Cache: Netfs 'nfs' registered for caching
[    0.258306] NFS: Registering the id_resolver key type
[    0.258373] Key type id_resolver registered
[    0.258402] Key type id_legacy registered
[    0.260739] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.260901] io scheduler noop registered
[    0.260940] io scheduler deadline registered (default)
[    0.261015] io scheduler cfq registered
[    0.263536] BCM2708FB: allocated DMA memory fac00000
[    0.263583] BCM2708FB: allocated DMA channel 0 @ f3007000
[    0.268783] Console: switching to colour frame buffer device 82x26
[    0.273329] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[    0.275683] console [ttyS0] disabled
[    0.277152] 3f215040.uart: ttyS0 at MMIO 0x3f215040 (irq = 59, base_baud = 31250000) is a 16550
[    2.466954] console [ttyS0] enabled
[    3.251976] bcm2835-rng 3f104000.rng: hwrng registered
[    3.269125] vc-cma: Videocore CMA driver
[    3.282415] vc-cma: vc_cma_base      = 0x00000000
[    3.298048] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    3.315742] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    3.333623] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[    3.376208] brd: module loaded
[    3.395409] loop: module loaded
[    3.407113] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[    3.430784] Loading iSCSI transport class v2.0-870.
[    3.447542] usbcore: registered new interface driver smsc95xx
[    3.466405] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    3.685472] Core Release: 2.80a
[    3.696383] Setting default values for core params
[    3.712324] Finished setting default values for core params
[    3.930979] Using Buffer DMA mode
[    3.942374] Periodic Transfer Interrupt Enhancement - disabled
[    3.961441] Multiprocessor Interrupt Enhancement - disabled
[    3.979692] OTG VER PARAM: 0, OTG VER FLAG: 0
[    3.994236] Dedicated Tx FIFOs mode
[    4.006394] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[    4.039011] FIQ FSM acceleration enabled for :
[    4.113878] dwc_otg: Microframe scheduler enabled
[    4.113933] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x80446a9c
[    4.133331] WARN::hcd_init_fiq:414: FIQ ASM at 0x80446e0c length 36
[    4.153746] WARN::hcd_init_fiq:439: MPHI regs_base at 0xbb922000
[    4.173382] dwc_otg 3f980000.usb: DWC OTG Controller
[    4.189833] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    4.213439] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[    4.231759] Init: Port Power? op_state=1
[    4.244996] Init: Power Port (0)
[    4.256265] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.278250] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.301544] usb usb1: Product: DWC OTG Controller
[    4.317150] usb usb1: Manufacturer: Linux 4.4.14-v7+ dwc_otg_hcd
[    4.336730] usb usb1: SerialNumber: 3f980000.usb
[    4.352877] hub 1-0:1.0: USB hub found
[    4.365565] hub 1-0:1.0: 1 port detected
[    4.379263] dwc_otg: FIQ enabled
[    4.379273] dwc_otg: NAK holdoff enabled
[    4.379281] dwc_otg: FIQ split-transaction FSM enabled
[    4.379319] Module dwc_common_port init
[    4.379584] usbcore: registered new interface driver usb-storage
[    4.399337] mousedev: PS/2 mouse device common for all mice
[    4.418251] bcm2835-cpufreq: min=600000 max=1200000
[    4.434636] sdhci: Secure Digital Host Controller Interface driver
[    4.454740] sdhci: Copyright(c) Pierre Ossman
[    4.469584] sdhost: log_buf @ bac13000 (fac13000)
[    4.559720] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    4.561961] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[    4.561968] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[    4.579790] Indeed it is in host mode hprt0 = 00021501
[    4.652380] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.671324] ledtrig-cpu: registered to indicate activity on CPUs
[    4.691028] hidraw: raw HID events driver (C) Jiri Kosina
[    4.708964] usbcore: registered new interface driver usbhid
[    4.727227] usbhid: USB HID core driver
[    4.740747] Initializing XFRM netlink socket
[    4.755034] NET: Registered protocol family 17
[    4.759713] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    4.790820] Indeed it is in host mode hprt0 = 00001101
[    4.807938] Key type dns_resolver registered
[    4.822760] Registering SWP/SWPB emulation handler
[    4.839699] registered taskstats version 1
[    4.853880] vc-sm: Videocore shared memory driver
[    4.869506] mmc0: host does not support reading read-only switch, assuming write-enable
[    4.869518] [vc_sm_connected_init]: start
[    4.910107] [vc_sm_connected_init]: end - returning 0
[    4.913599] mmc0: new high speed SDHC card at address aaaa
[    4.945102] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
[    4.946183] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[    4.959919] of_cfs_init
[    4.959993] of_cfs_init: OK
[    4.989985] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    4.989995] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    4.990672] hub 1-1:1.0: USB hub found
[    4.990761] hub 1-1:1.0: 5 ports detected
[    5.080132]  mmcblk0: p1 p2
[    5.094906] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[    5.118494] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[    5.269726] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    5.390004] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    5.412323] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    5.438756] smsc95xx v1.0.4
[    5.453875] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[    5.473273] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
[    5.490500] EXT4-fs (mmcblk0p2): recovery complete
[    5.513008] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:c2:0a:78
[    5.530635] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    5.530684] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    5.531504] devtmpfs: mounted
[    5.532240] Freeing unused kernel memory: 476K (807e7000 - 8085e000)
[    5.765297] random: systemd urandom read with 53 bits of entropy available
[    5.791660] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    5.835760] systemd[1]: Detected architecture 'arm'.
[    5.958783] NET: Registered protocol family 10
[    5.975391] systemd[1]: Inserted module 'ipv6'
[    5.993347] systemd[1]: Set hostname to <raspberrypi>.
[    6.367148] systemd[1]: Expecting device dev-ttyS0.device...
[    6.388220] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    6.414915] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    6.441267] systemd[1]: Starting Remote File Systems (Pre).
[    6.461747] systemd[1]: Reached target Remote File Systems (Pre).
[    6.481967] systemd[1]: Starting Encrypted Volumes.
[    6.500253] systemd[1]: Reached target Encrypted Volumes.
[    6.518345] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    6.550144] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    6.582028] systemd[1]: Starting Swap.
[    6.596984] systemd[1]: Reached target Swap.
[    6.611671] systemd[1]: Expecting device dev-mmcblk0p1.device...
[    6.633559] systemd[1]: Starting Root Slice.
[    6.650132] systemd[1]: Created slice Root Slice.
[    6.666039] systemd[1]: Starting User and Session Slice.
[    6.685666] systemd[1]: Created slice User and Session Slice.
[    6.704707] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    6.728333] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    6.751133] systemd[1]: Starting Delayed Shutdown Socket.
[    6.771060] systemd[1]: Listening on Delayed Shutdown Socket.
[    6.790111] systemd[1]: Starting Journal Socket (/dev/log).
[    6.810439] systemd[1]: Listening on Journal Socket (/dev/log).
[    6.829969] systemd[1]: Starting udev Control Socket.
[    6.848612] systemd[1]: Listening on udev Control Socket.
[    6.866575] systemd[1]: Starting udev Kernel Socket.
[    6.884934] systemd[1]: Listening on udev Kernel Socket.
[    6.902650] systemd[1]: Starting Journal Socket.
[    6.920040] systemd[1]: Listening on Journal Socket.
[    6.936742] systemd[1]: Starting System Slice.
[    6.953606] systemd[1]: Created slice System Slice.
[    6.969980] systemd[1]: Starting File System Check on Root Device...
[    7.030261] systemd[1]: Starting system-systemd\x2dfsck.slice.
[    7.051743] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    7.072406] systemd[1]: Starting system-autologin.slice.
[    7.092076] systemd[1]: Created slice system-autologin.slice.
[    7.111142] systemd[1]: Starting system-serial\x2dgetty.slice.
[    7.132567] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    7.153505] systemd[1]: Starting Increase datagram queue length...
[    7.178139] systemd[1]: Starting Restore / save the current clock...
[    7.212821] systemd[1]: Starting Load Kernel Modules...
[    7.239172] systemd[1]: Starting udev Coldplug all Devices...
[    7.263867] systemd[1]: Mounted Huge Pages File System.
[    7.275201] fuse init (API version 7.23)
[    7.295683] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    7.302102] i2c /dev entries driver
[    7.346531] systemd[1]: Started Set Up Additional Binary Formats.
[    7.366990] systemd[1]: Mounting POSIX Message Queue File System...
[    7.392857] systemd[1]: Mounting Debug File System...
[    7.414837] systemd[1]: Starting Slices.
[    7.430910] systemd[1]: Reached target Slices.
[    7.449995] systemd[1]: Mounted Debug File System.
[    7.467974] systemd[1]: Mounted POSIX Message Queue File System.
[    7.490631] systemd[1]: Started File System Check on Root Device.
[    7.522169] systemd[1]: Started Increase datagram queue length.
[    7.544604] systemd[1]: Started Restore / save the current clock.
[    7.567535] systemd[1]: Started Load Kernel Modules.
[    7.614041] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    7.650057] systemd[1]: Time has been changed
[    7.667944] systemd[1]: Started udev Coldplug all Devices.
[    7.829081] systemd[1]: Starting Create Static Device Nodes in /dev...
[    7.890348] systemd[1]: Starting Apply Kernel Variables...
[    7.913519] systemd[1]: Mounting FUSE Control File System...
[    7.937618] systemd[1]: Mounting Configuration File System...
[    7.942431] systemd[1]: Starting Syslog Socket.
[    7.945078] systemd[1]: Listening on Syslog Socket.
[    7.945278] systemd[1]: Starting Journal Service...
[    7.953039] systemd[1]: Started Journal Service.
[    8.055967] systemd-udevd[137]: starting version 215
[    8.374227] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[    8.413360] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    8.670093] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    9.069157] systemd-journald[135]: Received request to flush runtime journal from PID 1
[   10.071905] uart-pl011 3f201000.uart: no DMA platform data
[   10.374649] Adding 102396k swap on /var/swap.  Priority:-1 extents:4 across:1658876k SSFS
[   10.386790] cfg80211: World regulatory domain updated:
[   10.386810] cfg80211:  DFS Master region: unset
[   10.386819] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   10.386834] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   10.386847] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   10.386859] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[   10.386874] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   10.386888] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[   10.386900] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   10.386913] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[   10.386925] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[   10.902092] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[   10.902547] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   12.009762] random: nonblocking pool is initialized
[   12.521350] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   12.524008] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x43E1
[   14.528579] Bluetooth: Core ver 2.21
[   14.528700] NET: Registered protocol family 31
[   14.528715] Bluetooth: HCI device and connection manager initialized
[   14.528753] Bluetooth: HCI socket layer initialized
[   14.528775] Bluetooth: L2CAP socket layer initialized
[   14.528821] Bluetooth: SCO socket layer initialized
[   14.556103] Bluetooth: HCI UART driver ver 2.3
[   14.556125] Bluetooth: HCI UART protocol H4 registered
[   14.556135] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   14.556317] Bluetooth: HCI UART protocol BCM registered
[   14.794505] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   14.794524] Bluetooth: BNEP filters: protocol multicast
[   14.794547] Bluetooth: BNEP socket layer initialized
Posted: Tue Jul 12, 2016 5:49 pm
by nbeathoven
After getting latest updates and firmware revisions Wlan0 still does not show up. However I noticed now after running commands below:
# Remove the Driver
modprobe brcmfmac
Wlan0 would show up after ifconfig -a.
What do I need to do to make it permanent. What could be the issue that driver is not loaded at boot time? Tried several reboots and shutdown -h already.
Posted: Fri Jul 15, 2016 7:09 am
by alexandru.bau
Hi guys,
Did anyone come up with a solution? I have exactly the same problem. The wlan0 interface is not showing.
I've tried to install the latest version of Raspbian directly and with Noobs without any results.
I've tried enabling from raspi-config -> Advanced -> A5 -> Yes and Reboot. Still nothing.
From the GUI it displayes: No wireless interfaces. Also the bluetooth is not working.
I have a Raspberry Pi 3 with integrated Wi-Fi and Bluetooth and I suppose that this things should work out of the box, I Didn't do anything extra (like modifying any config files).
What am I doing wrong?
Thank you for your help.
Posted: Mon Jul 18, 2016 3:48 am
by nbeathoven
I still have same exact issue
Posted: Sun Jul 24, 2016 10:20 pm
by thorst
I have the same issue as well. Please help us
Posted: Wed Jul 27, 2016 6:24 pm
by ahnjoan
Does anyone know of any other places to post that might get more exposure or some better way I could outline the issue I'm seeing? It has been a month since my last post and I'm just looking for suggestions what I might do differently to get help.
Posted: Wed Jul 27, 2016 9:35 pm
by thorst
Posted: Mon Aug 01, 2016 4:20 pm
by nbeathoven
WOW! looks like no one is taking on this subject any more, i would wonder how many RPI3 users have same problem?
I just wait for new release of driver @
Last one is :
brcmfmac43430-sdio.bin Updated brcmfmac43430-sdio.bin - version 7.45.41.26 2 months ago
Posted: Mon Aug 15, 2016 3:48 pm
by SkyeCarins
I have a rpi3. The Wifi works fine when its near router takes twice as long to download when its downstairs. My question is if I add a USB wifi do I need to turn off the onboard WIFI?
Posted: Thu Aug 25, 2016 4:54 pm
by billwild
I'm having a similar issue. ifconfig shows the wlan entry and selecting the network shows me nearby wireless networks, but when I pick mine & provide the wep key, I can't even ping the router. Is WEP deprecated on the Pi?
Posted: Sun Sep 04, 2016 1:48 am
by gundown34
dmesg
[ 0.000000] Linux version 4.4.19-v7+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #906 SMP Tue Aug 23 15:53:06 BST 2016
[ 0.000000] cma: Reserved 8 MiB at 0x2e400000
[ 0.000000] On node 0 totalpages: 192512
[ 0.000000] free_area_init_node: node 0, pgdat 808c2f40, node_mem_map add64000
[ 0.000000] Normal zone: 1692 pages used for memmap
[ 0.000000] Normal zone: 192512 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 13 pages/cpu @aefaa000 s22592 r8192 d22464 u53248
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 190820
[ 0.000000] Kernel command line: 8250.nr_uarts=0 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2709.boardrev=0xa22082 bcm2709.serial=0xfc184c59 smsc95xx.macaddr=B8:27:EB:18:4C:59 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Memory: 744196K/770048K available (6348K kernel code, 432K rwdata, 1716K rodata, 476K init, 764K bss, 17660K reserved, 8192K cma-reserved)
vmalloc : 0xaf800000 - 0xff800000 (1280 MB)
lowmem : 0x80000000 - 0xaf000000 ( 752 MB)
.text : 0x80008000 - 0x807e8510 (8066 kB)
.init : 0x807e9000 - 0x80860000 ( 476 kB)
.data : 0x80860000 - 0x808cc250 ( 433 kB)
.bss : 0x808cf000 - 0x8098e1ec ( 765 kB)
[ 0.000283] Console: colour dummy device 80x30
[ 0.001338] console [tty1] enabled
[ 0.001383] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001450] pid_max: default: 32768 minimum: 301
[ 0.001783] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001826] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002779] Disabling cpuset control group subsystem
[ 0.002836] Initializing cgroup subsys io
[ 0.002886] Initializing cgroup subsys memory
[ 0.002952] Initializing cgroup subsys devices
[ 0.002994] Initializing cgroup subsys freezer
[ 0.003036] Initializing cgroup subsys net_cls
[ 0.003108] CPU: Testing write buffer coherency: ok
[ 0.003193] ftrace: allocating 21217 entries in 63 pages
[ 0.052395] CPU0: update cpu_capacity 1024
[ 0.052463] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.052497] [bcm2709_smp_prepare_cpus] enter
[ 0.052654] Setting up static identity map for 0x8240 - 0x8274
[ 0.054292] [bcm2709_boot_secondary] cpu:1 started (0) 17
[ 0.054486] [bcm2709_secondary_init] enter cpu:1
[ 0.054526] CPU1: update cpu_capacity 1024
[ 0.054532] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.054907] [bcm2709_boot_secondary] cpu:2 started (0) 16
[ 0.055072] [bcm2709_secondary_init] enter cpu:2
[ 0.055093] CPU2: update cpu_capacity 1024
[ 0.055099] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.055456] [bcm2709_boot_secondary] cpu:3 started (0) 17
[ 0.055587] [bcm2709_secondary_init] enter cpu:3
[ 0.055607] CPU3: update cpu_capacity 1024
[ 0.055613] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.055673] Brought up 4 CPUs
[ 0.055772] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.055801] CPU: All CPU(s) started in HYP mode.
[ 0.055828] CPU: Virtualization extensions available.
[ 0.056462] devtmpfs: initialized
[ 0.067352] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.067728] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.068492] pinctrl core: initialized pinctrl subsystem
[ 0.069037] NET: Registered protocol family 16
[ 0.074215] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.081364] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.081412] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.081585] Serial: AMBA PL011 UART driver
[ 0.081737] uart-pl011 3f201000.uart: could not find pctldev for node /soc/[email protected]/uart0_pins, deferring probe
[ 0.081970] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.144543] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[ 0.145142] SCSI subsystem initialized
[ 0.145349] usbcore: registered new interface driver usbfs
[ 0.145463] usbcore: registered new interface driver hub
[ 0.145582] usbcore: registered new device driver usb
[ 0.151944] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-09-02 11:49
[ 0.179120] clocksource: Switched to clocksource arch_sys_counter
[ 0.224274] FS-Cache: Loaded
[ 0.224568] CacheFiles: Loaded
[ 0.236917] NET: Registered protocol family 2
[ 0.237782] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.237920] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.238131] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.238246] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.238314] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.238569] NET: Registered protocol family 1
[ 0.238912] RPC: Registered named UNIX socket transport module.
[ 0.238945] RPC: Registered udp transport module.
[ 0.238972] RPC: Registered tcp transport module.
[ 0.239000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.240061] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.241402] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.254963] VFS: Disk quotas dquot_6.6.0
[ 0.255300] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.257587] FS-Cache: Netfs 'nfs' registered for caching
[ 0.258516] NFS: Registering the id_resolver key type
[ 0.258579] Key type id_resolver registered
[ 0.258607] Key type id_legacy registered
[ 0.261027] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.261196] io scheduler noop registered
[ 0.261236] io scheduler deadline registered (default)
[ 0.261311] io scheduler cfq registered
[ 0.263869] BCM2708FB: allocated DMA memory ee800000
[ 0.263916] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.314049] Console: switching to colour frame buffer device 228x61
[ 1.294281] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.294628] vc-cma: Videocore CMA driver
[ 1.294761] vc-cma: vc_cma_base = 0x00000000
[ 1.294900] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.295057] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.295466] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.310562] brd: module loaded
[ 1.319484] loop: module loaded
[ 1.320589] vchiq: vchiq_init_state: slot_zero = 0xae880000, is_master = 0
[ 1.322385] Loading iSCSI transport class v2.0-870.
[ 1.323178] usbcore: registered new interface driver smsc95xx
[ 1.323392] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.523810] Core Release: 2.80a
[ 1.523920] Setting default values for core params
[ 1.524090] Finished setting default values for core params
[ 1.724620] Using Buffer DMA mode
[ 1.724727] Periodic Transfer Interrupt Enhancement - disabled
[ 1.724894] Multiprocessor Interrupt Enhancement - disabled
[ 1.725056] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.725191] Dedicated Tx FIFOs mode
[ 1.725623] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xae814000 dma = 0xee814000 len=9024
[ 1.725924] FIQ FSM acceleration enabled for :
[ 1.733228] dwc_otg: Microframe scheduler enabled
[ 1.733288] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x80446f3c
[ 1.740235] WARN::hcd_init_fiq:414: FIQ ASM at 0x804472ac length 36
[ 1.747178] WARN::hcd_init_fiq:439: MPHI regs_base at 0xaff7a000
[ 1.754047] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.760945] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.767789] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 1.774655] Init: Port Power? op_state=1
[ 1.781401] Init: Power Port (0)
[ 1.788219] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.795055] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.801859] usb usb1: Product: DWC OTG Controller
[ 1.808760] usb usb1: Manufacturer: Linux 4.4.19-v7+ dwc_otg_hcd
[ 1.815672] usb usb1: SerialNumber: 3f980000.usb
[ 1.823356] hub 1-0:1.0: USB hub found
[ 1.830165] hub 1-0:1.0: 1 port detected
[ 1.837387] dwc_otg: FIQ enabled
[ 1.837396] dwc_otg: NAK holdoff enabled
[ 1.837404] dwc_otg: FIQ split-transaction FSM enabled
[ 1.837448] Module dwc_common_port init
[ 1.837730] usbcore: registered new interface driver usb-storage
[ 1.844772] mousedev: PS/2 mouse device common for all mice
[ 1.852180] bcm2835-cpufreq: min=600000 max=1200000
[ 1.859146] sdhci: Secure Digital Host Controller Interface driver
[ 1.865790] sdhci: Copyright(c) Pierre Ossman
[ 1.872819] sdhost: log_buf @ ae813000 (ee813000)
[ 1.959149] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.968092] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 1.974805] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 2.016453] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.019242] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.019648] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.019765] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.019955] usbcore: registered new interface driver usbhid
[ 2.019958] usbhid: USB HID core driver
[ 2.020515] Initializing XFRM netlink socket
[ 2.020548] NET: Registered protocol family 17
[ 2.020684] Key type dns_resolver registered
[ 2.021197] Registering SWP/SWPB emulation handler
[ 2.022029] registered taskstats version 1
[ 2.022230] vc-sm: Videocore shared memory driver
[ 2.022238] [vc_sm_connected_init]: start
[ 2.023691] [vc_sm_connected_init]: end - returning 0
[ 2.025098] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 2.025501] of_cfs_init
[ 2.025585] of_cfs_init: OK
[ 2.029275] Indeed it is in host mode hprt0 = 00021501
[ 2.139450] Waiting for root device /dev/mmcblk0p2...
[ 2.141396] mmc0: new high speed SDHC card at address 0007
[ 2.142098] mmcblk0: mmc0:0007 SD16G 14.6 GiB
[ 2.147307] mmcblk0: p1 p2
[ 2.185305] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.192233] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.200294] devtmpfs: mounted
[ 2.207904] Freeing unused kernel memory: 476K (807e9000 - 80860000)
[ 2.219159] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.226126] Indeed it is in host mode hprt0 = 00001101
[ 2.429486] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.436484] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.444394] hub 1-1:1.0: USB hub found
[ 2.451394] hub 1-1:1.0: 5 ports detected
[ 2.517560] random: systemd: uninitialized urandom read (16 bytes read, 43 bits of entropy available)
[ 2.529080] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 2.536946] systemd[1]: Detected architecture 'arm'.
[ 2.689026] NET: Registered protocol family 10
[ 2.697930] systemd[1]: Inserted module 'ipv6'
[ 2.708669] systemd[1]: Set hostname to <raspberrypi>.
[ 2.739178] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.858561] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 60 bits of entropy available)
[ 2.866607] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.874195] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.885624] smsc95xx v1.0.4
[ 2.952774] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:18:4c:59
[ 2.988560] random: systemd: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[ 2.997962] random: systemd: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[ 3.007156] random: systemd: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[ 3.033298] random: systemd: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[ 3.039184] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[ 3.049753] random: systemd: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[ 3.057744] random: systemd: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[ 3.101970] random: systemd: uninitialized urandom read (16 bytes read, 67 bits of entropy available)
[ 3.114589] random: systemd: uninitialized urandom read (16 bytes read, 67 bits of entropy available)
[ 3.156475] usb 1-1.3: New USB device found, idVendor=148f, idProduct=3070
[ 3.164154] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.171706] usb 1-1.3: Product: 802.11 n WLAN
[ 3.179259] usb 1-1.3: Manufacturer: Ralink
[ 3.186665] usb 1-1.3: SerialNumber: 1.0
[ 3.239504] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 3.247470] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.255161] systemd[1]: Starting Remote File Systems (Pre).
[ 3.271270] systemd[1]: Reached target Remote File Systems (Pre).
[ 3.279226] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 3.289171] usb 1-1.4: new low-speed USB device number 5 using dwc_otg
[ 3.304354] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.312651] systemd[1]: Starting Encrypted Volumes.
[ 3.329535] systemd[1]: Reached target Encrypted Volumes.
[ 3.337662] systemd[1]: Starting Swap.
[ 3.354577] systemd[1]: Reached target Swap.
[ 3.362723] systemd[1]: Expecting device dev-mmcblk0p1.device...
[ 3.379704] systemd[1]: Starting Root Slice.
[ 3.396834] systemd[1]: Created slice Root Slice.
[ 3.404800] systemd[1]: Starting User and Session Slice.
[ 3.420842] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c31c
[ 3.420850] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.420859] usb 1-1.4: Product: USB Keyboard
[ 3.420868] usb 1-1.4: Manufacturer: Logitech
[ 3.453758] systemd[1]: Created slice User and Session Slice.
[ 3.461735] systemd[1]: Starting Delayed Shutdown Socket.
[ 3.478178] systemd[1]: Listening on Delayed Shutdown Socket.
[ 3.485785] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 3.497542] input: Logitech USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:046D:C31C.0001/input/input0
[ 3.510461] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 3.518545] systemd[1]: Starting Journal Socket (/dev/log).
[ 3.535764] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.543890] systemd[1]: Starting udev Control Socket.
[ 3.550123] hid-generic 0003:046D:C31C.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-3f980000.usb-1.4/input0
[ 3.569506] systemd[1]: Listening on udev Control Socket.
[ 3.577672] systemd[1]: Starting udev Kernel Socket.
[ 3.594795] systemd[1]: Listening on udev Kernel Socket.
[ 3.602987] systemd[1]: Starting Journal Socket.
[ 3.613158] input: Logitech USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C31C.0002/input/input1
[ 3.628929] systemd[1]: Listening on Journal Socket.
[ 3.637546] systemd[1]: Starting System Slice.
[ 3.655683] systemd[1]: Created slice System Slice.
[ 3.664345] systemd[1]: Starting File System Check on Root Device...
[ 3.669461] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-3f980000.usb-1.4/input1
[ 3.729766] systemd[1]: Starting system-systemd\x2dfsck.slice.
[ 3.749682] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.758956] systemd[1]: Starting system-autologin.slice.
[ 3.759179] usb 1-1.5: new low-speed USB device number 6 using dwc_otg
[ 3.788117] systemd[1]: Created slice system-autologin.slice.
[ 3.797454] systemd[1]: Starting Increase datagram queue length...
[ 3.819864] systemd[1]: Starting Restore / save the current clock...
[ 3.844725] systemd[1]: Mounted Huge Pages File System.
[ 3.854441] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 3.906873] systemd[1]: Starting Load Kernel Modules...
[ 3.916294] usb 1-1.5: New USB device found, idVendor=046d, idProduct=c044
[ 3.925398] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.934738] usb 1-1.5: Product: USB-PS/2 Optical Mouse
[ 3.934747] usb 1-1.5: Manufacturer: Logitech
[ 3.968713] input: Logitech USB-PS/2 Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:046D:C044.0003/input/input2
[ 3.979275] hid-generic 0003:046D:C044.0003: input,hidraw2: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-3f980000.usb-1.5/input0
[ 4.029095] systemd[1]: Started Set Up Additional Binary Formats.
[ 4.039453] systemd[1]: Mounting Debug File System...
[ 4.063037] systemd[1]: Starting udev Coldplug all Devices...
[ 4.086722] fuse init (API version 7.23)
[ 4.087210] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.122426] systemd[1]: Starting Slices.
[ 4.139929] i2c /dev entries driver
[ 4.154667] systemd[1]: Reached target Slices.
[ 4.176375] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.195640] systemd[1]: Mounted Debug File System.
[ 4.215821] systemd[1]: Started File System Check on Root Device.
[ 4.245544] systemd[1]: Started Increase datagram queue length.
[ 4.249164] usb 1-1.2: new high-speed USB device number 7 using dwc_otg
[ 4.274331] systemd[1]: Started Restore / save the current clock.
[ 4.294746] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 4.315007] systemd[1]: Started Load Kernel Modules.
[ 4.376089] systemd[1]: Time has been changed
[ 4.391042] usb 1-1.2: New USB device found, idVendor=1058, idProduct=1230
[ 4.400152] usb 1-1.2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 4.409291] usb 1-1.2: Product: My Book 1230
[ 4.418322] usb 1-1.2: Manufacturer: Western Digital
[ 4.427537] usb 1-1.2: SerialNumber: 5743433445324A4C3334434B
[ 4.436462] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[ 4.436802] scsi host0: usb-storage 1-1.2:1.0
[ 4.463260] systemd[1]: Started udev Coldplug all Devices.
[ 4.583695] systemd[1]: Mounting Configuration File System...
[ 4.629566] systemd[1]: Starting Apply Kernel Variables...
[ 4.651537] systemd[1]: Mounting FUSE Control File System...
[ 4.674286] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 4.687831] systemd[1]: Starting Syslog Socket.
[ 4.698352] systemd[1]: Listening on Syslog Socket.
[ 4.698521] systemd[1]: Starting Journal Service...
[ 4.721745] systemd[1]: Started Journal Service.
[ 4.900044] systemd-udevd[141]: starting version 215
[ 5.430523] scsi 0:0:0:0: Direct-Access WD My Book 1230 1065 PQ: 0 ANSI: 6
[ 5.433185] sd 0:0:0:0: [sda] Spinning up disk...
[ 5.438619] scsi 0:0:0:1: Enclosure WD SES Device 1065 PQ: 0 ANSI: 6
[ 5.513332] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 5.522026] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 5.584864] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 5.684003] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 5.685061] scsi 0:0:0:1: Attached scsi generic sg1 type 13
[ 6.415353] systemd-journald[139]: Received request to flush runtime journal from PID 1
[ 6.439254] .
[ 7.065444] cfg80211: World regulatory domain updated:
[ 7.065467] cfg80211: DFS Master region: unset
[ 7.065476] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 7.065491] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.065503] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.065515] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.065530] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 7.065544] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 7.065557] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 7.065569] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.065581] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 7.089175] usb 1-1.3: reset high-speed USB device number 4 using dwc_otg
[ 7.199677] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 3070, rev 0201 detected
[ 7.216675] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 0005 detected
[ 7.230951] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 7.233053] usbcore: registered new interface driver rt2800usb
[ 7.449195] .
[ 7.693226] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
[ 7.695669] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.29
[ 7.764571] random: nonblocking pool is initialized
[ 8.116015] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.313938] uart-pl011 3f201000.uart: no DMA platform data
[ 8.459169] .
[ 8.627700] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
[ 8.662199] cfg80211: Regulatory domain changed to country: US
[ 8.662223] cfg80211: DFS Master region: FCC
[ 8.662228] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 8.662237] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 8.662246] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 1700 mBm), (N/A)
[ 8.662253] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[ 8.662260] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[ 8.662267] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 9.261570] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 9.261712] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.469135] .
[ 9.800515] wlan0: authenticate with 00:08:2f:1f:21:41
[ 9.892715] wlan0: send auth to 00:08:2f:1f:21:41 (try 1/3)
[ 9.894182] wlan0: authenticated
[ 9.894494] rt2800usb 1-1.3:1.0 wlan0: disabling HT/VHT due to WEP/TKIP use
[ 9.899189] wlan0: associate with 00:08:2f:1f:21:41 (try 1/3)
[ 9.901580] wlan0: RX AssocResp from 00:08:2f:1f:21:41 (capab=0x411 status=0 aid=3)
[ 9.906150] wlan0: associated
[ 9.906270] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 9.915047] cfg80211: Regulatory domain changed to country: US
[ 9.915060] cfg80211: DFS Master region: FCC
[ 9.915065] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 9.915073] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 9.915081] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 1700 mBm), (N/A)
[ 9.915088] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[ 9.915094] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[ 9.915100] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 9.960341] wlan0: Limiting TX power to 23 dBm as advertised by 00:08:2f:1f:21:41
[ 10.479158] ..ready
[ 11.683326] sd 0:0:0:0: [sda] 976746240 4096-byte logical blocks: (4.00 TB/3.64 TiB)
[ 11.683939] sd 0:0:0:0: [sda] Write Protect is off
[ 11.683948] sd 0:0:0:0: [sda] Mode Sense: 53 00 10 08
[ 11.684560] sd 0:0:0:0: [sda] No Caching mode page found
[ 11.684568] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 11.785289] sda: sda1
[ 11.789721] sd 0:0:0:0: [sda] Attached SCSI disk
[ 13.038663] Bluetooth: Core ver 2.21
[ 13.038768] NET: Registered protocol family 31
[ 13.038775] Bluetooth: HCI device and connection manager initialized
[ 13.040173] Bluetooth: HCI socket layer initialized
[ 13.040191] Bluetooth: L2CAP socket layer initialized
[ 13.040224] Bluetooth: SCO socket layer initialized
[ 13.048012] Bluetooth: HCI UART driver ver 2.3
[ 13.048026] Bluetooth: HCI UART protocol H4 registered
[ 13.048031] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 13.048145] Bluetooth: HCI UART protocol BCM registered
[ 13.229973] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.229987] Bluetooth: BNEP filters: protocol multicast
[ 13.230002] Bluetooth: BNEP socket layer initialized
[ 28.915742] Bluetooth: RFCOMM TTY layer initialized
[ 28.915790] Bluetooth: RFCOMM socket layer initialized
[ 28.915807] Bluetooth: RFCOMM ver 1.11
[ 435.934196] usb 1-1.3: USB disconnect, device number 4
[ 435.980726] wlan0: deauthenticating from 00:08:2f:1f:21:41 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 436.047612] cfg80211: World regulatory domain updated:
[ 436.047625] cfg80211: DFS Master region: unset
[ 436.047630] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 436.047637] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 436.047644] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 436.047650] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 436.047657] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 436.047664] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 436.047671] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 436.047677] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 436.047683] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 436.061441] cfg80211: Regulatory domain changed to country: US
[ 436.061458] cfg80211: DFS Master region: FCC
[ 436.061465] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 436.061473] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 436.061482] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 1700 mBm), (N/A)
[ 436.061490] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[ 436.061498] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[ 436.061505] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 438.237199] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 438.301885] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 438.302049] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
please guys, i need help...i cannot figure it out what the problem is on the wifi...have been reading and trying but nothing..i have to use a usb ralink antenna to connect wireless, it really sucks.
Re: rpi3 wifi issues
Posted: Fri Sep 09, 2016 7:37 am
by bbfra
Hi all,
i have the same issue. The Wifi Interface don't work. Only the eth0 and lo is showing up with the ifconfig -a command.
i update the pi3 with:
sudo apt-get update
sudo apt-get upgrade
sudo rpi-update
i activated in the sudo raspi-config the Point 9 -> A5.
But the A5 isn't called Device Tree, it's called SPI Kernel Modul. I can't find the Device Tree Item in the Menu.
if i run dmesg, i get an error:
mmc1: error -110 whilst initialising SDIO card
I have no idea, what i can try next. I hope it is not a Hardware problem.
