Page 1 of 2
RPi 3 bluetooth - cannot connect keyboard
Posted: Wed Mar 02, 2016 3:06 pm
by alexsh1
When I run 'sudo bluetoothctl' command and then try to pair the keyboard I got the following:
[CHG] Device 30:73:00:01:7D:1A Connected: yes
[CHG] Device 30:73:00:01:7D:1A Connected: no
Failed to pair: org.bluez.Error.AuthenticationFailed
Anyone can me help please to setup a bluetooth keyboard?
Re: RPi 3 bluetooth - cannot connect keyboard
Posted: Wed Mar 02, 2016 3:08 pm
by ShiftPlusOne
Not sure if this will help, but try running bluetoothctl with the -a flag.
Posted: Wed Mar 02, 2016 3:31 pm
by Douglas6
It would be helpful to know what exactly you did in bluetoothctl. Did you power on the adapter? Register a pairing agent and set it as the default? Make the keyboard discoverable? Scan for the keyboard? Run the pair command? Trust the paired device? Run the connect command?
Posted: Wed Mar 02, 2016 7:25 pm
by alexsh1
ShiftPlusOne wrote:Not sure if this will help, but try running bluetoothctl with the -a flag.
Thanks - this resolved the issue.
[CHG] Device 30:73:00:01:7D:1A Paired: yes
Pairing successful
Posted: Wed Mar 02, 2016 7:28 pm
by alexsh1
Douglas6 wrote:It would be helpful to know what exactly you did in bluetoothctl. Did you power on the adapter? Register a pairing agent and set it as the default? Make the keyboard discoverable? Scan for the keyboard? Run the pair command? Trust the paired device? Run the connect command?
Sorry - yes, I did pretty much all you mention above:
- bluetooth is powered and installed
- agent was registered and set to default
- Keyboard is discoverable
- scan on or hcitool scan performed.
- run 'pair xxxxxxxxxxxxxxxx' and got the error message
- trust was run
Posted: Mon Mar 07, 2016 9:41 pm
by evertheoptimist
can anyone give step by step guide on how to connect bluetooth keyboard to raspberry pi 3 with built in wi/fi bluetooth for a complete beginner, as I dont know where to start.
Thanks in advance.
Posted: Sun Mar 13, 2016 5:02 pm
by frankymusic
Input the following commands from a console (I'm using WinSCP and then PuTTY from my PC, but you can attach a HDMI display, an USB keyboard or so, meanwhile...)
1. bluetoothctl
2. pairable on
3. scan on
Now you have to wait, until your BT device (keyboard) is shown (don't forget to activate your keyboard now! Press the so called "pairing button" of your BT keyboard, may be a combination of two keys, see the users manual!). Don't forget to wait!!! You should see it's address as "xx:xx:xx:xx:xx:xx"
4. scan off
5. agent on
6. pair xx:xx:xx:xx:xx:xx
Now you are requested to input a number (6 digits) using your BT keyboard, and then you have to quit it by pressing the "return" button of your BT keyboard! "pairing successful" should be displayed!
7. trust xx:xx:xx:xx:xx:xx
8. connect xx:xx:xx:xx:xx:xx
"connection successful" should be displayed!
9. info xx:xx:xx:xx:xx:xx
... will show the success again (some Information are displayed).
10. exit
Reboot your RPi now.
At my "system" after any reboot (or new start at all) I have to switch on my BT keyboard not before (!) the RPi waits for the first input command, and then it takes about 2 minutes (!) until I can see the keyboard's key strokes!!! Therefore, be patiently!!!
Frank
Posted: Mon Mar 14, 2016 2:55 pm
by lmoss30
when i follow these instuctions i get
failed to connect: org.blueze.error.failed
any ideas?
Posted: Mon Mar 14, 2016 4:04 pm
by frankymusic
Hi lmoss30,
which steps can you follow without error messages?
Frank
Posted: Mon Mar 14, 2016 4:05 pm
by lmoss30
I can do right upto the connect step, it goes through
pair, trust, and when i do connect it seems to go wrong.
Posted: Mon Mar 14, 2016 4:17 pm
by frankymusic
... did you try to press the so called "pairing button" of your BT keyboard between? You should try this now...
Frank
Posted: Mon Mar 14, 2016 4:27 pm
by lmoss30
Hi Frank,
I have tried that, you have to press that button to get the keyboard into its original pairing state anyway,
The keyboard must be being seen as i have to enter a 6 digit code during the pairing stage
Regards
Lee
Posted: Mon Mar 14, 2016 5:06 pm
by frankymusic
... of course, I know! But the idea behind was, that the BT keyboard isn't patiently enough, forgets its mission because of a delay from you... ;)
No idea at the moment, sorry, my keyboard connected accurately using this method...
Frank
Posted: Mon Mar 14, 2016 5:15 pm
by frankymusic
... if everything runs fine, there is an info file at
/var/lib/bluetooth/id1/id2/info
where
id1 ID-code of the RPi's BT controller
id2 ID-code of the BT keyboard
You get access only during a root session or using the "sudo command".
Could you have a look into that file (if it exists already)?
Frank
Posted: Mon Mar 14, 2016 10:31 pm
by uklightman
Thank you 'Frankymusic', after a couple of weeks of frustration, I can now use my 'Bluetooth' keyboard.
Posted: Tue Mar 15, 2016 1:29 pm
by lmoss30
I checked for that file with
sudo /var/lib/bluetooth/id1/id2/info
and says not present.
also re ran the procedure, and still no luck, have tried bluetoothctl -a and that makes no difference,
this is so fustrating, the only think i can say is if i leave pairable on, it says device not available.
Posted: Tue Mar 15, 2016 2:27 pm
by frankymusic
Hi lmoss30,
that "info" file is accessable for a super user only. Sorry for the "short form" of my hint... :?
To see it's content (while you're logged in as "pi" user for example) you should type the following command into the console window:
sudo nano /var/lib/bluetooth/id1/id2/info
to open it using the "nano" editor... (be careful NOT to edit anything!!!)
... or...:
sudo less /var/lib/bluetooth/id1/id2/info
to only have a look inside...
For id1 and id2 you must type in the BT address of your devices (RPi 3 as well as BT keyboard)
So a (working) command could be (this is only an example because of the choosen numbers...!!!)
sudo less  /var/lib/bluetooth/B8:27:EB:9A:A5:EB/20:73:AB:00:0D:C3/info
Hope this helps
Frank
Posted: Tue Mar 15, 2016 2:43 pm
by lmoss30
Hi Frank
this is the response from the info file
[General]
Name=Bluetooth Keyboard
Class=0x000540
SupportedTechnologies=BR/EDR;
Trusted=true
Blocked=false
[LinkKey]
Key=C7E8998BF31E3612EA0789C6771D8917
Type=0
PINLength=0
[DeviceID]
Source=2
Vendor=1452
Product=544
Version=1
[General]
Posted: Tue Mar 15, 2016 9:19 pm
by frankymusic
Hi lmoss30, again,
sorry that I don't have the solution for your (specific ?) problem...
Another question:
did you start from a fresh (actual) Raspbian-Jessie image? How about "sudo apt-get update / sudo apt-get upgrade" before configuring that BT connection? May be you completed all these things, but if not, please do it...
My "info" file's content - for comparison only:
[LinkKey]
Key=42E5D18C44FC023A95D06F1B9AE3394C
Type=0
PINLength=0
[General]
Name=Bluetooth V3.0 TouchPad Keyboard
Class=0x000540
Trusted=true
Blocked=false
Services=00001000-0000-1000-8000-00805f9b34fb;00001124-0000-1000-8000-00805f9b34fb;00001200-0000-1000-8000-00805f9b34fb;
[DeviceID]
Source=1
Vendor=2652
Product=34050
Version=283
It seems that the line "Services" is missed inside your "info" file! No idea why, at the moment...
This line looks very specific (... only valid for my "specific" BT keyboard...), but no!
Here I found a quite other protocol from a different user: http://askubuntu.com/questions/554053/w ... untu-14-10
(you have to scroll down almost to the bottom of that topic),
and as far as I can see, that line "Services" is exactly the same as that of my "info" file.
No idea at the moment why yours doesn't work, but please report if you did all the initialisation steps mentioned above (sudo apt get ...).
Frank
PS: May be some BT experts can give "us" an advice to help getting your BT keyboard connected...? :idea:
Posted: Wed Mar 16, 2016 10:28 am
by lmoss30
Hi Frank,
thank you for all you help, it is very furstrating, althought in the process learning quite abit about bluetooth in the process,
i initially did a clean install, i will try again on a fresh card and see how that goes, i think we all take for granted windows/phones that do this in the background without any modification. Might even see if i can find a different keyboard to use.
Regards
Lee
Posted: Wed Mar 16, 2016 10:51 am
by frankymusic
Hi Lee,
... and don't forget to update/upgrade the whole system before trying the BT connection to be sure you're using the latest drivers and so...
BT on RPi 3 is very new (as the RPi 3 by itself) and so it could take some time to solve all the "starting" problems...
Did you try to connect your BT keyboard to an android smartphone for example? I did so and therefore I was hopefully to get it connected to the RPi 3... and therefore I didn't gave up until it was working. ;)
Don't forget to report your final insights, please.
Frank
Posted: Wed Mar 16, 2016 1:24 pm
by lmoss30
Hi Frank,
yeah it pairs to my smart phone and laptop no problems so it seems to an issue with my install,
i will report back once i do a clean install and try again.
Lee
Posted: Thu Mar 17, 2016 11:24 am
by lmoss30
Hi Frank,
Could you check if possible this report on yours i did a
sudo service bluetooth status and i get the following, does look right
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled)
Active: active (running) since Fri 2016-02-26 02:21:08 UTC; 2 weeks 6 days ag o
Docs: man:bluetoothd(8)
Main PID: 567 (bluetoothd)
Status: "Running"
CGroup: /system.slice/bluetooth.service
└─567 /usr/lib/bluetooth/bluetoothd
Feb 26 02:21:08 raspberrypi bluetoothd[567]: Bluetooth daemon 5.23
Feb 26 02:21:08 raspberrypi systemd[1]: Started Bluetooth service.
Feb 26 02:21:08 raspberrypi bluetoothd[567]: Starting SDP server
Feb 26 02:21:08 raspberrypi bluetoothd[567]: Bluetooth management interface ...d
Feb 26 02:21:08 raspberrypi bluetoothd[567]: Sap driver initialization failed.
Feb 26 02:21:08 raspberrypi bluetoothd[567]: sap-server: Operation not permi...)
Hint: Some lines were ellipsized, use -l to show in full.
Posted: Thu Mar 17, 2016 11:47 am
by Massi
frankymusic wrote:BT on RPi 3 is very new (as the RPi 3 by itself) and so it could take some time to solve all the "starting" problems...
well, in my opinion the problem is not the new BT on rpi3, but that maleficent BlueZ 5 :lol: :lol:
i'm hating it so much ant it's impossibility to get a rfcomm paired and created on startup..
btw, i'm also seeing these 2 errors:
i don't think where these come from, but i think they are not breaking BT at all..
Posted: Thu Mar 17, 2016 11:56 am
by frankymusic
Hi Lee,
I tested it for your comparision. While my BT keyboard is working well, it seems to be the same output of that status request...
[email protected]:~ $ sudo service bluetooth status
bluetooth.service - Bluetooth Service
Active: active (running) since Di 2016-03-15 22:17:08 CET; 1 day 14h ago
Main PID: 687 (bluetoothd)
Status: "Running"
└─687 /usr/lib/bluetooth/bluetoothd
Mär 15 22:17:08 raspberrypi bluetoothd[687]: Bluetooth daemon 5.23
Mär 15 22:17:08 raspberrypi systemd[1]: Started Bluetooth service.
Mär 15 22:17:08 raspberrypi bluetoothd[687]: Starting SDP server
Mär 15 22:17:08 raspberrypi bluetoothd[687]: Bluetooth management interface 1.9 initialized
Mär 15 22:17:08 raspberrypi bluetoothd[687]: Sap driver initialization failed.
Mär 15 22:17:08 raspberrypi bluetoothd[687]: sap-server: Operation not permitted (1)
Frank
