lmoss30
Re: RPi 3 bluetooth - cannot connect keyboard
Thu Mar 17, 2016 12:16 pm
Cheers Frank,
I now have a clean install re imaged from noobs, and just done the update and upgrade so will follow your steps above and see how it goes
Lee
frankymusic
Thu Mar 17, 2016 12:53 pm
Hi Lee,
fine! Let's hope the best... :roll:
Frank
lmoss30
Thu Mar 17, 2016 1:30 pm
Hi guys,
well i am honest i not sure which bit sorted the problem but is is finally paired,
i followed the procedure above and, initailly it wouldnt connect again as before,
I then checked the file /var/lib/bluetooth/id1/id2/info and the services bit was missing again.
so i added it manaully based on the file listed above. rebooted and it wouldnt connect again.
Then i tried the bluetoothctl -a command, connect and bingo it seemes to now be connecting everytime.
Thanks all to the help given much appriacted.
Lee
frankymusic
Thu Mar 17, 2016 1:50 pm
Hi Lee,
thank you for reporting the "whole story"... :oops:
So it was "a good idea" to tell you that specific "Services" line... 8-)
It's a little bit of mystic, of course, and I don't know if anyone else is encouraged now to try it out.
Nevertheless you are satisfied now.... :?
What is the "starting procedure" at your RPi? As I described above, I have to wait before switching on my BT keyboard until the first input is requested from the RPi (... and then it takes about 2 minutes until the first keystroke is accepted...).
Frank
lmoss30
Thu Mar 17, 2016 1:58 pm
Hi Frank
Keyboard on at power up, the connect light flashes, once in desktop press any key and it stops the flashing and it seems to connect straight away.
Now to try and get bluetooth audio working on my sound sq :) that is a job for this evening.
Lee
frankymusic
Thu Mar 17, 2016 2:07 pm
Hi Lee,
okay, every BT keyboard seems to have ist own behavior :lol:
Thank you for reporting this.
Frank
lmoss30
Thu Mar 17, 2016 9:49 pm
Just in case anyone wants to try I managed to get the Bluetooth audio working with the guide
https://wiki.debian.org/BluetoothUser/a2dp
Himbeer Torte
Tue Mar 29, 2016 10:27 pm
I'm really struggling with this.
I'm completely new to the RPi and new to all this jargon but keen to learn and keen to learn about the capabilities of this fascinating little device. Wisely or unwisely I decided I want to connect to the device using a bluetooth keyboard.
I'm a complete beginner and I'm struggling to connect my BT keyboard.
I've followed frankymusic's step by step instructions and can connect the keyboard manually (I'm using it now!) but I don't know how to reconnect it automatically after a reboot.
Can somebody advise me with some idiot proof step-by-step instructions?......remember I'm a complete beginner!
hibdude
Thu Apr 07, 2016 11:29 pm
I'm having a similar issue with my keyboard, but I'm not finding any resolution so far. I'm using the Rpi3 and have run update, upgrade.
When I follow the instructions, I get the following results. I have followed that up with my info file contents. Can anyone give me some direction to make my bluetooth keyboard finally connect? Mouse works fine, but keyboard doesn't...
Thanks in advance...
Brian
[email protected]:~ $ bluetoothctl -a
[NEW] Controller B8:27:EB:FA:09:53 raspberrypi [default]
[NEW] Device 00:1F:20:E9:55:C9 Bluetooth Mouse M557
[NEW] Device 20:43:00:21:25:42 Dual-Mode Keyboard
Agent registered
[bluetooth]# pairable on
Changing pairable on succeeded
[bluetooth]# scan on
Discovery started
[CHG] Controller B8:27:EB:FA:09:53 Discovering: yes
[CHG] Device 20:43:00:21:25:42 RSSI: -74
[bluetooth]# scan off
[CHG] Device 20:43:00:21:25:42 RSSI is nil
Discovery stopped
[CHG] Controller B8:27:EB:FA:09:53 Discovering: no
[bluetooth]# agent on
Agent is already registered
[bluetooth]# pair 20:43:00:21:25:42
Attempting to pair with 20:43:00:21:25:42
Failed to pair: org.bluez.Error.AlreadyExists
[bluetooth]# trust 20:43:00:21:25:42
Changing 20:43:00:21:25:42 trust succeeded
[bluetooth]# connect 20:43:00:21:25:42
Attempting to connect to 20:43:00:21:25:42
[CHG] Device 20:43:00:21:25:42 Connected: yes
Failed to connect: org.bluez.Error.Failed
[CHG] Device 20:43:00:21:25:42 Connected: no
[bluetooth]# exit
Agent unregistered
[DEL] Controller B8:27:EB:FA:09:53 raspberrypi [default]
info file contents:
[LinkKey]
Key=759112EB08D46CABCA6A01F8F8E201F0
Type=4
PINLength=0
[General]
Name=Dual-Mode Keyboard
Class=0x002540
SupportedTechnologies=BR/EDR;
Trusted=true
Blocked=false
Services=00001000-0000-1000-8000-00805f9b34fb;00001124-0000-1000-8000-00805f9b34fb;00001200-0000-$
[DeviceID]
Source=2
Vendor=1256
Product=28705
Version=1
Douglas6
Thu Apr 07, 2016 11:49 pm
Did you use a PIN code when you paired? I would unpair and do the pairing process over. Record the steps.
Himbeer Torte
Fri Apr 08, 2016 8:22 am
After many hours of searching and testing on the Pi3 without success, I eventually came across this.
http://www.techradar.com/how-to/computi ... -3-1316938
Because I'm a complete newbie to all of this and the Pi3, I can't be certain if following the instructions in the link made everything work or if it was a combination of everything I'd tried in the past + something I did whilst working through link's instructions.
Anyway, I now have a Bluetooth keyboard that connects to my Pi on boot up. After a Pi boot-up, on my particular B/T keyboard, all I have to do is "wake the keyboard up" by pressing and holding a key for three seconds and then it automatically connects to the Pi.
I hope everybody else gets their keyboards working too.
mikehenville
Fri Apr 08, 2016 1:38 pm
Hi
I have been using a Logitech (K380) and also a Kano keyboard on my Rp 3 however cannot get to print the "@" symbol by pressing shift and "2". Both return ("). Is there a way to get the ampersand symbol as I would like to use the machine for email.
Thanks,
mikehenville
Himbeer Torte
Fri Apr 08, 2016 4:53 pm
I had a similar problem. You need to go to your Pi settings or preferences (whatever it's called) and change the keyboard settings to different region until you get the results you want.
I ended up doing a google image search on Qwerty keyboards. Turns out my B/T keyboard is a USA layout, all my other keyboards are UK layout
mikehenville
Fri Apr 08, 2016 7:03 pm
Thanks Himber; that was the issue.
mikehenville
aviron
Wed May 11, 2016 6:20 am
I'm also facing the same problem.
I also installed the blueman applet (graphical application) but still I have the same problem).
it is not only with bluetooth keyboard but with any bluetooth device.
Please advice if your last efforts help to solve the problem.
Avi
