Raspberry Pi 3 Bluetooth Setup
How do i setup bluetooth on RPi 3.
Re: Raspberry Pi 3 Bluetooth Setup
sudo apt-get install pi-bluetooth
Just a quick 'hello world' that may be helpful!
- the first release of Raspbian Jessie for the Pi3 (26th Feb 2016) has pi-bluetooth pre-loaded and working 'out of the box';
- so if you type 'sudo service bluetooth status' and return, it should show 'active (running)';
- and if you have an adjacent *active* BLE device and type 'sudo hcitool lescan' and return ...
... you should see the callsign of the active BLE devices that it spotted;
Followed the following:
sudo apt-get install bluetooth bluez blueman
sudo reboot
wait for reboot - The current raspian image does not have native support for the inbuilt bluetooth on the RPi 3. However if you run hciconfig - It will shows the BD address of the Pi. Run hcitool scan to get the BD address of the pairable devices in range.
Then follow:
sudo bluetoothctl
in the [bluetooth]# type agent on followed by default-agent
To pair type pair xx:xx:xx:xx:xx:xx where xx:xx:xx:xx:xx:xx is your BD address of the device you want to pair
Next type trust xx:xx:xx:xx:xx:xx
I am using bluetooth to connect to serial on python so I simply run sudo rfcomm bind 0 xx:xx:xx:xx:xx:xx via subprocess.call to created a serial port.
Make sure to run sudo rfcomm release 0 at the end of the script to release the serial port
sudo reboot
Then follow:
sudo bluetoothctl
Tried to execute your commands. After "sudo bluetoothctl" I get the command-line "[bluetooth]#"
So far so good, however at that point my usb-keyboard does'nt respond anymore. I can only get back with the command "Ctrl C" to the previous (standard) command-line.
Any suggestions on this?
That probably means that the Bluetooth daemon is not running (bluetoothctl is somewhat lacking in error handling). The daemon should start automatically after a reboot. Check the status from a command-line with or you can start it manually with
systemctl status bluetooth
sudo systemctl start bluetooth
Hi all,
I received my Rpi 3 today, together with a BT keyboard "ultron"...
hcitool scan delivers the BT address of my keyboard (20:73:AB:00:0D:C3).
Until "agent on" and "default-agent" everything runs as expected, but...
... the "pair" (together with the address of that keyboard) always says:
20:73:AB:00:0D:C3 not available...
Does anybody get an idea?
Thanks in advance
Frank
Thanks in advance
Frank
Thanks for the tip, works fine!Douglas6 wrote:That probably means that the Bluetooth daemon is not running (bluetoothctl is somewhat lacking in error handling). The daemon should start automatically after a reboot. Check the status from a command-line withor you can start it manually withCode: Select all
Do try the following:frankymusic wrote:Hi all,
Thanks in advance
Frank
• sudo bluetoothctl
• agent on
• default-agent
• scan on
• pair xx:xx:xx:xx:xx (device id)
(if asked for a "PIN code" -> enter that "PIN code" on your bluetooth keyboard and press ENTER on the bluetooth keyboard)
• trust xx:xx:xx:xx:xx (if not asked for a pin code this may work too)
• connect xx:xx:xx:xx:xx
That's how I got my bluetooth keyboard with integrated mousepad running. (This one: http://www.amazon.de/gp/product/B00GHO9DJW (not available for sale anymore.))
Any other ideas?
I have confirmed BT is running in my Pi3.
I have done a complete system update.
I did a firmware update.
I do an hcitools scan and I get an address of my BT speaker
I do exactly what Frank did and I get the same message.
Device A0:E9:D8:00:3B:98 is not available.
I followed up with:
and I have tried many times.
I followed up with:
What type of device is it? Are you sure it's in discoverable mode when you try to pair with it?
Absolutely. Not my first rodeo with bluetooth devicesDouglas6 wrote:What type of device is it? Are you sure it's in discoverable mode when you try to pair with it?
There seems to be be multiple generations of bluetooth stacks in the RP community in general. Some of the information is probably old.
Sorry, I'm straw-clutching here; no offense intended. I've not run into that error. Did you turn 'scan on' in bluetoothctl and wait for the device to appear?
I have paired my Raspberry Pi 3 to my Hardman Kardon bluetooth soundstick. The status is OK but i receive no sound on the speakers.
Hamdy Abou El Anein
https://wiki.debian.org/BluetoothUser/a2dphamdy.aea wrote:I have paired my Raspberry Pi 3 to my Hardman Kardon bluetooth soundstick. The status is OK but i receive no sound on the speakers.
My other Linux machine is a ChromeBox
Now I have another problem. The bluetooth adapter is not found.
Hamdy Abou El Anein
I get "Device is not available: No such device" when I try to scan, what am I missing?
pi@raspberrypi-3-drivecam:~ $ hcitool scan
pi@raspberrypi-3-drivecam:~ $ sudo bluetoothctl
[bluetooth]# agent on
Agent registered
[bluetooth]# default-agent
Default agent request successful
[bluetooth]# list
[bluetooth]# devices
[bluetooth]# scan
Missing on/off argument
[bluetooth]# scan on
No default controller available
[bluetooth]# list
[bluetooth]# power on
[bluetooth]# quit
Agent unregistered
pi@raspberrypi-3-drivecam:~ $ systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled)
Active: active (running) since Sat 2016-03-12 20:35:25 UTC; 2min 46s ago
Docs: man:bluetoothd(8)
Main PID: 2689 (bluetoothd)
Status: "Running"
CGroup: /system.slice/bluetooth.service
└─2689 /usr/lib/bluetooth/bluetoothd
pi@raspberrypi-3-drivecam:~ $ sudo hcitool scan
pi@raspberrypi-3-drivecam:~ $ hcitool dev
Devices:
Pauly: you are missing either the latest firmware on a Pi3, or a recognized Bluetooth dongle on a Pi1-2.
thanks, I have a pi3, thought everything was as up to date as could be. Have updated with rpi-update and still the same result. Anything else I can try?
Hi All.
New member & also new to RPi
so please be gentle with me
Just got RPi 3 for Kodi use
managed to install from noobs without keyboard ( had to borrow a wired mouse but no keyboard ) Installed openelec , checked zeroconf , enabled Bluetooth etc ( as directed by yatse app ) but it won't find my mini keyboard ( the type you get with an m8 android box from eBay )
Have connected yatse ( eventually ) but really would like my keyboard !!!
I can't follow the prompts above as I don't know where or if I can put them in as it boots straight into Kodi ??
Any help would be much appreciated
I have the same problem as Pauly. Devices are not listed in , yet when I run , shows the driver is loaded correctly (I think). Should I see more in this output?:
I run OSMC; I tried in case the firmware is out of date but the rpi-update package is not in the repo. Manually getting and running rpi-update gives the following errors, so I did not proceed.
Any other ideas?
hcitool dev
dmesg | grep Blue
[ 1486.123815] Bluetooth: Core ver 2.21
[ 1486.123898] Bluetooth: HCI device and connection manager initialized
[ 1486.123916] Bluetooth: HCI socket layer initialized
[ 1486.123928] Bluetooth: L2CAP socket layer initialized
[ 1486.123957] Bluetooth: SCO socket layer initialized
[ 1486.164113] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1486.164133] Bluetooth: BNEP filters: protocol multicast
[ 1486.164152] Bluetooth: BNEP socket layer initialized
sudo apt-get install rpi-update
osmc@osmc:~$ sudo rpi-update
You appear to be trying to update firmware on an incompatible distribution. To force update, run the following:
sudo -E RPI_UPDATE_UNSUPPORTED=0 rpi-update
Any other ideas?
Ok, I risked it and updated firmware, which OSMC normally blocks until it is tested with the distribution. Same issue:
*** Downloading specific firmware revision (this will take a few minutes)
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 168 0 168 0 0 902 0 --:--:-- --:--:-- --:--:-- 908
100 49.3M 100 49.3M 0 0 1232k 0 0:00:40 0:00:40 --:--:-- 130k
*** Updating firmware
*** Updating kernel modules
*** depmod 4.1.19+
*** depmod 4.1.19-v7+
*** Updating VideoCore libraries
*** Using HardFP libraries
*** Updating SDK
*** Running ldconfig
*** Storing current firmware revision
*** Deleting downloaded files
*** Syncing changes to disk
*** If no errors appeared, your firmware was successfully updated to 2a7eb4fc4cef07906c36e9adcf76f053daabe371
*** A reboot is needed to activate the new firmware
osmc@osmc:~$ dmesg | grep Blue
osmc@osmc:~$ hcitool dev
Devices:
osmc@osmc:~$ systemctl status bluetooth
* bluetooth.service - Bluetooth service
Drop-In: /etc/systemd/system/bluetooth.service.d
`-local.conf
Active: active (running) since Sat 2016-03-12 20:05:09 EST; 11h ago
Main PID: 844 (bluetoothd)
Status: "Running"
`-844 /usr/lib/bluetooth/bluetoothd
The bluetoothctl shows no device even though the agent seems to work:
[bluetooth]# agent-on
Invalid command
Agent registered
[bluetooth]# list
[bluetooth]# list
[bluetooth]#
If you are running the latest Raspbian image, or using NOOBS 1.8, it will just work. If you are trying to upgrade a Wheezy image, see various threads on this forum. If you're using NOOBS < 1.8, you may be out of luck, and will have to flash a new card. If you are running OSMC, or other OS, it's best to ask on their forum.
