StupidCoder
Re: Raspberry Pi 3 Wifi Setup
Fri Jul 01, 2016 6:46 am
I just bought a Pi 3 and am suffering from similar Wifi problems. Running the latest Jessie distribution, Wifi stops working after a few minutes of inactivity. I already tried disabling power saving, but to my surprise it didn't help.
After the Wifi connection dropped, I SSH'd to the Pi via Ethernet to investigate. Running "sudo iw dev wlan0 info" freezes all my SSH session on the Pi for a couple of minutes. Since this affects all sessions, it appears that either the CPU utilization goes through the roof or whatever's happening also affects the Ethernet connection. Eventually the command succeeds and prints some wholly unsuspicious device info.
Once I did the above, the Wifi connection is working again. Until the next time it fails, that is... :?
bazza14
Mon Aug 22, 2016 6:02 pm
jmhunter wrote:For those folks using the 'lite' Raspbian image without the GUI - can anybody share an example config file that would allow a Pi 3 to act as a wireless client to connect to an existing wireless network (or indeed an example config file to act as an AP)?
I appreciate the GUI tools probably set things up automatically, but I'd rather just edit /etc/network/interfaces or whichever file(s), instead of having to install a GUI.
I already have 'iw dev wlan0 set power_save off' in /etc/rc.local :-)
Look here viewtopic.php?f=91&t=157896&p=1027355#p1027355
LINUX convert since 2003
JamesPi123
Tue Sep 27, 2016 8:46 am
TromboneBernie wrote:Yesterday I had the same problem and I found, that my router was on channel 13. The actual Jessy release seems to support wifi only up to channel 11. I switched to channel 8 and it worked.
hth Bernie
It's Jessie, not Jessy. In case you were wondering why the name is Jessie, Raspian is a modified version of Debian and the current release of Debian was named Jessie so Raspian carries over the name from Debian!
JamesPi123
Sun Oct 02, 2016 6:31 am
I was playing about with /etc/network/interfaces and accidentally messed it up ( :? ) so only ethernet works. Can anybody help?
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow_hotplug wlan0
iface wlan0 inet dhcp
allow_hotplug wlan1
iface wlan1 inet dhcp
jbudd
Sun Oct 02, 2016 9:00 am
With Raspbian Jessie, unless you are doing something relatively unusual, /etc/network/interfaces should only contain this
auto lo
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
JamesPi123
Sun Oct 02, 2016 9:28 pm
jbudd wrote:With Raspbian Jessie, unless you are doing something relatively unusual, /etc/network/interfaces should only contain this
auto lo
allow-hotplug wlan0
allow-hotplug wlan1
Thanks! It's ll fixed 8-)
FlamingPhoenix2
Thu Mar 02, 2017 9:10 pm
When i try to connect to my network, i click on it and type my password, click ok, but the window goes away and it does not connect. Why?
TheBalvenie21yo
Fri Mar 03, 2017 8:11 am
I have a brand new Raspberry Pi 3 and I cannot get it to recognize that wlan0 should exist.
Ifconfig -a does not show it.
/etc/network/interfaces has not been modified.
I've run the Dougie-approved command in this thread for installing & updating & rebooting. Here is what I have afterward:
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.9.13-v7+ #974 SMP Wed Mar 1 20:09:48 GMT 2017 armv7l GNU/Linux
pi@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
Trying out ifup gives an error:
pi@raspberrypi:~ $ sudo ifup wlan0
wpa_supplicant: /sbin/wpa_supplicant daemon failed to start
run-parts: /etc/network/if-pre-up.d/wpasupplicant exited with return code 1
Failed to bring up wlan0.
If I run a search for the broadcom firmware, it is found:
pi@raspberrypi:~ $ apt-cache search firmware |grep Broadcom
firmware-bnx2 - Binary firmware for Broadcom NetXtremeII
firmware-bnx2x - Binary firmware for Broadcom NetXtreme II 10Gb
firmware-brcm80211 - Binary firmware for Broadcom 802.11 wireless cards
pi@raspberrypi:~ $
The iw command to turn low power mode doesn't work and gives an error about there being no wlan0.
ifconfig -a shows this:
pi@raspberrypi:~ $ ifconfig -a
eth0      Link encap:Ethernet  HWaddr b8:27:eb:c4:07:a1
          inet addr:192.168.1.12  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::175c:18f4:e55b:83a0/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:19960 errors:0 dropped:2 overruns:0 frame:0
          TX packets:14393 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:13638277 (13.0 MiB)  TX bytes:2218453 (2.1 MiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:200 errors:0 dropped:0 overruns:0 frame:0
          TX packets:200 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:16656 (16.2 KiB)  TX bytes:16656 (16.2 KiB)
pi@raspberrypi:~ $
Contents of /boot and /boot/config.txt:
pi@raspberrypi:~ $ ls -la /boot
total 21136
drwxr-xr-x  3 root root   16384 Dec 31  1969 .
drwxr-xr-x 23 root root    4096 Mar  3 01:12 ..
-rwxr-xr-x  1 root root   15028 Mar  3 01:13 bcm2708-rpi-b.dtb
-rwxr-xr-x  1 root root   15287 Mar  3 01:13 bcm2708-rpi-b-plus.dtb
-rwxr-xr-x  1 root root   14747 Mar  3 01:13 bcm2708-rpi-cm.dtb
-rwxr-xr-x  1 root root   16354 Mar  3 01:13 bcm2709-rpi-2-b.dtb
-rwxr-xr-x  1 root root   17455 Mar  3 01:13 bcm2710-rpi-3-b.dtb
-rwxr-xr-x  1 root root   16211 Mar  3 01:13 bcm2710-rpi-cm3.dtb
-rwxr-xr-x  1 root root   50268 Mar  3 01:13 bootcode.bin
-rwxr-xr-x  1 root root     136 Dec 31  1979 cmdline.txt
-rwxr-xr-x  1 root root    1745 Mar  3 00:59 config.txt
-rwxr-xr-x  1 root root   18693 Aug 21  2015 COPYING.linux
-rwxr-xr-x  1 root root      41 Mar  3 01:13 .firmware_revision
-rwxr-xr-x  1 root root    2558 Mar  3 01:13 fixup_cd.dat
-rwxr-xr-x  1 root root    6646 Mar  3 01:13 fixup.dat
-rwxr-xr-x  1 root root    9777 Mar  3 01:13 fixup_db.dat
-rwxr-xr-x  1 root root    9775 Mar  3 01:13 fixup_x.dat
-rwxr-xr-x  1 root root     103 Mar 18  2016 issue.txt
-rwxr-xr-x  1 root root 4576688 Mar  3 01:13 kernel7.img
-rwxr-xr-x  1 root root 4375736 Mar  3 01:13 kernel.img
-rwxr-xr-x  1 root root    1494 Nov 18  2015 LICENCE.broadcom
-rwxr-xr-x  1 root root   18974 Mar 18  2016 LICENSE.oracle
-rwxr-xr-x  1 root root     294 Dec 31  1979 os_config.json
drwxr-xr-x  2 root root   14336 Mar  3 01:13 overlays
-rwxr-xr-x  1 root root  654980 Mar  3 01:13 start_cd.elf
-rwxr-xr-x  1 root root 4983140 Mar  3 01:13 start_db.elf
-rwxr-xr-x  1 root root 2846692 Mar  3 01:13 start.elf
-rwxr-xr-x  1 root root 3929604 Mar  3 01:13 start_x.elf
pi@raspberrypi:~ $ less /boot/config.txt
# For more options and information see
# http://www.raspberrypi.org/documentation/configuration/config-txt.md
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# NOOBS Auto-generated Settings:
start_x=1
gpu_mem=128
enable_uart=1
dtoverlay=w1-gpio
The steps from mike632t don't work
https://mike632t.wordpress.com/2016/03/ ... etworking/
pi@raspberrypi:~ $ sudo apt-get install firmware-brcm80211
Reading package lists... Done
Building dependency tree
firmware-brcm80211 is already the newest version.
The following packages were automatically installed and are no longer required:
  libasn1-8-heimdal libgssapi3-heimdal libhcrypto4-heimdal libheimbase1-heimdal libheimntlm0-heimdal libhx509-5-heimdal
  libkrb5-26-heimdal libroken18-heimdal libwind0-heimdal libxfce4ui-1-0 xfce-keyboard-shortcuts
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 18 not upgraded.
pi@raspberrypi:~ $ sudo apt-get install wireless-tools wpasupplicant
wireless-tools is already the newest version.
wpasupplicant is already the newest version.
pi@raspberrypi:~ $
pi@raspberrypi:~ $ iw dev
pi@raspberrypi:~ $
dmseg shows this:
pi@raspberrypi:~ $ dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.13-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #974 SMP Wed Mar 1 20:09:48 GMT 2017
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt:Machine model: Raspberry Pi 3 Model B Rev 1.2
[    0.000000] cma: Reserved 8 MiB at 0x36800000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 225280
[    0.000000] free_area_init_node: node 0, pgdat 80c6ed80, node_mem_map b603a000
[    0.000000]   Normal zone: 1980 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 225280 pages, LIFO batch:31
[    0.000000] percpu: Embedded 14 pages/cpu @b5ff4000 s25600 r8192 d23552 u57344
[    0.000000] pcpu-alloc: s25600 r8192 d23552 u57344 alloc=14*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 223300
[    0.000000] Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 871344K/901120K available (7168K kernel code, 483K rwdata, 2012K rodata, 1024K init, 778K bss, 21584K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xb7800000 - 0xff800000   (1152 MB)
    lowmem  : 0x80000000 - 0xb7000000   ( 880 MB)
    modules : 0x7f000000 - 0x80000000   (  16 MB)
      .text : 0x80008000 - 0x80800000   (8160 kB)
      .init : 0x80b00000 - 0x80c00000   (1024 kB)
      .data : 0x80c00000 - 0x80c78f6c   ( 484 kB)
       .bss : 0x80c7a000 - 0x80d3cb64   ( 779 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000025] Switching to timer-based delay loop, resolution 52ns
[    0.000328] Console: colour dummy device 80x30
[    0.001218] console [tty1] enabled
[    0.001276] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001346] pid_max: default: 32768 minimum: 301
[    0.001711] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001753] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002773] Disabling cpuset control group subsystem
[    0.002964] CPU: Testing write buffer coherency: ok
[    0.003033] ftrace: allocating 22388 entries in 66 pages
[    0.054648] CPU0: update cpu_capacity 1024
[    0.054712] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.054812] Setting up static identity map for 0x100000 - 0x100034
[    0.057049] CPU1: update cpu_capacity 1024
[    0.057056] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.057789] CPU2: update cpu_capacity 1024
[    0.057796] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.058471] CPU3: update cpu_capacity 1024
[    0.058478] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.058561] Brought up 4 CPUs
[    0.058735] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.058765] CPU: All CPU(s) started in HYP mode.
[    0.058791] CPU: Virtualization extensions available.
[    0.059603] devtmpfs: initialized
[    0.070937] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.071266] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.071328] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.071893] pinctrl core: initialized pinctrl subsystem
[    0.072826] NET: Registered protocol family 16
[    0.075111] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.084238] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.084286] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.084460] Serial: AMBA PL011 UART driver
[    0.088267] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.088831] uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[    0.165227] bcm2835-dma 3f007000.dma: DMA legacy API manager at b780f000, dmachans=0x1
[    0.167136] SCSI subsystem initialized
[    0.167324] usbcore: registered new interface driver usbfs
[    0.167428] usbcore: registered new interface driver hub
[    0.167545] usbcore: registered new device driver usb
[    0.174214] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-03-02 15:37
[    0.175658] clocksource: Switched to clocksource arch_sys_counter
[    0.222607] VFS: Disk quotas dquot_6.6.0
[    0.222716] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.222942] FS-Cache: Loaded
[    0.223210] CacheFiles: Loaded
[    0.235721] NET: Registered protocol family 2
[    0.236614] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.236752] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.236963] TCP: Hash tables configured (established 8192 bind 8192)
[    0.237077] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.237144] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.237380] NET: Registered protocol family 1
[    0.237815] RPC: Registered named UNIX socket transport module.
[    0.237847] RPC: Registered udp transport module.
[    0.237875] RPC: Registered tcp transport module.
[    0.237903] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.238894] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    0.241277] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.257926] FS-Cache: Netfs 'nfs' registered for caching
[    0.258964] NFS: Registering the id_resolver key type
[    0.259031] Key type id_resolver registered
[    0.259059] Key type id_legacy registered
[    0.261522] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.261670] io scheduler noop registered
[    0.261700] io scheduler deadline registered (default)
[    0.261988] io scheduler cfq registered
[    0.267838] BCM2708FB: allocated DMA memory f6910000
[    0.267891] BCM2708FB: allocated DMA channel 0 @ b780f000
[    0.318394] Console: switching to colour frame buffer device 228x61
[    0.348336] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[    0.349437] console [ttyS0] disabled
[    0.349601] 3f215040.serial: ttyS0 at MMIO 0x0 (irq = 59, base_baud = 31249999) is a 16550
[    1.000319] console [ttyS0] enabled
[    1.005340] bcm2835-rng 3f104000.rng: hwrng registered
[    1.010831] vc-cma: Videocore CMA driver
[    1.014919] vc-cma: vc_cma_base      = 0x00000000
[    1.019833] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    1.025454] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    1.031290] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[    1.055551] brd: module loaded
[    1.068001] loop: module loaded
[    1.071316] Loading iSCSI transport class v2.0-870.
[    1.077066] usbcore: registered new interface driver smsc95xx
[    1.083066] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.315306] Core Release: 2.80a
[    1.318618] Setting default values for core params
[    1.323638] Finished setting default values for core params
[    1.529854] Using Buffer DMA mode
[    1.533312] Periodic Transfer Interrupt Enhancement - disabled
[    1.539404] Multiprocessor Interrupt Enhancement - disabled
[    1.545211] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.549775] Dedicated Tx FIFOs mode
[    1.553793] WARN::dwc_otg_hcd_init:1053: FIQ DMA bounce buffers: virt = 0xb6904000 dma = 0xf6904000 len=9024
[    1.564071] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[    1.614433] dwc_otg: Microframe scheduler enabled
[    1.614488] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x8058e200
[    1.627489] WARN::hcd_init_fiq:460: FIQ ASM at 0x8058e570 length 36
[    1.640774] WARN::hcd_init_fiq:486: MPHI regs_base at 0xb787e000
[    1.653737] dwc_otg 3f980000.usb: DWC OTG Controller
[    1.665602] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    1.679948] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[    1.692484] Init: Port Power? op_state=1
[    1.703247] Init: Power Port (0)
[    1.713394] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.727164] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.741477] usb usb1: Product: DWC OTG Controller
[    1.753182] usb usb1: Manufacturer: Linux 4.9.13-v7+ dwc_otg_hcd
[    1.766163] usb usb1: SerialNumber: 3f980000.usb
[    1.778601] hub 1-0:1.0: USB hub found
[    1.789201] hub 1-0:1.0: 1 port detected
[    1.800402] dwc_otg: FIQ enabled
[    1.800407] dwc_otg: NAK holdoff enabled
[    1.800411] dwc_otg: FIQ split-transaction FSM enabled
[    1.800426] Module dwc_common_port init
[    1.800696] usbcore: registered new interface driver usb-storage
[    1.813753] mousedev: PS/2 mouse device common for all mice
[    1.827193] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[    1.841358] bcm2835-cpufreq: min=600000 max=1200000
[    1.853521] sdhci: Secure Digital Host Controller Interface driver
[    1.866558] sdhci: Copyright(c) Pierre Ossman
[    1.878200] sdhost: log_buf @ b6907000 (f6907000)
[    1.965689] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    2.000521] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[    2.013350] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[    2.026360] Indeed it is in host mode hprt0 = 00021501
[    2.095803] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.115939] ledtrig-cpu: registered to indicate activity on CPUs
[    2.126012] random: fast init done
[    2.146160] hidraw: raw HID events driver (C) Jiri Kosina
[    2.158672] usbcore: registered new interface driver usbhid
[    2.171169] usbhid: USB HID core driver
[    2.182735] vchiq: vchiq_init_state: slot_zero = 0xb6980000, is_master = 0
[    2.199320] Initializing XFRM netlink socket
[    2.206849] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.211500] mmc0: new high speed SDHC card at address aaaa
[    2.212276] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[    2.233746]  mmcblk0: p1 p2 < p5 p6 p7 >
[    2.245688] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.245860] Indeed it is in host mode hprt0 = 00001101
[    2.287371] NET: Registered protocol family 17
[    2.299045] Key type dns_resolver registered
[    2.310807] Registering SWP/SWPB emulation handler
[    2.323545] registered taskstats version 1
[    2.337970] vc-sm: Videocore shared memory driver
[    2.349712] [vc_sm_connected_init]: start
[    2.361353] [vc_sm_connected_init]: end - returning 0
[    2.374702] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[    2.391138] of_cfs_init
[    2.400749] of_cfs_init: OK
[    2.432052] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[    2.447334] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
[    2.472043] devtmpfs: mounted
[    2.483893] Freeing unused kernel memory: 1024K (80b00000 - 80c00000)
[    2.485984] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    2.485993] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.486859] hub 1-1:1.0: USB hub found
[    2.486950] hub 1-1:1.0: 5 ports detected
[    2.825705] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    2.856826] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    2.878329] systemd[1]: Detected architecture 'arm'.
[    2.986049] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    3.000798] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.016320] NET: Registered protocol family 10
[    3.028749] smsc95xx v1.0.5
[    3.040049] systemd[1]: Inserted module 'ipv6'
[    3.056927] systemd[1]: Set hostname to <raspberrypi>.
[    3.139907] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:c4:07:a1
[    3.265713] usb 1-1.3: new low-speed USB device number 4 using dwc_otg
[    3.423729] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c31c
[    3.438623] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.453903] usb 1-1.3: Product: USB Keyboard
[    3.464559] systemd[1]: Expecting device dev-ttyS0.device...
[    3.479597] usb 1-1.3: Manufacturer: Logitech
[    3.501180] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    3.517171] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.532935] systemd[1]: Starting Remote File Systems (Pre).
[    3.554261] input: Logitech USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C31C.0001/input/input0
[    3.576641] systemd[1]: Reached target Remote File Systems (Pre).
[    3.591371] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    3.616738] hid-generic 0003:046D:C31C.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-3f980000.usb-1.3/input0
[    3.665995] input: Logitech USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0002/input/input1
[    3.735979] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-3f980000.usb-1.3/input1
[    3.962550] fuse init (API version 7.26)
[    4.015712] i2c /dev entries driver
[    4.035742] usb 1-1.5: new low-speed USB device number 5 using dwc_otg
[    4.202698] usb 1-1.5: New USB device found, idVendor=045e, idProduct=077d
[    4.202709] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.202715] usb 1-1.5: Product: Comfort Mouse 6000
[    4.202721] usb 1-1.5: Manufacturer: Microsoft
[    4.321972] input: Microsoft Comfort Mouse 6000 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:045E:077D.0003/input/input2
[    4.406328] hid-generic 0003:045E:077D.0003: input,hidraw2: USB HID v1.11 Mouse [Microsoft Comfort Mouse 6000] on usb-3f980000.usb-1.5/input0
[    4.648386] systemd-udevd[145]: starting version 215
[    4.971140] Driver for 1-wire Dallas network protocol.
[    4.989846] w1-gpio onewire@0: gpio pin 4, external pullup pin -1, parasitic power 0
[    4.989884] w1_add_master_device: set_pullup requires write_byte or touch_bit, disabling
[    4.996892] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    5.308975] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
[    5.895344] systemd-journald[143]: Received request to flush runtime journal from PID 1
[    7.800714] Adding 102396k swap on /var/swap.  Priority:-1 extents:2 across:110588k SSFS
[    8.097762] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[    9.717442] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[   11.707328] random: crng init done
[   13.648135] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 3430.934509] TCP: eth0: Driver has suspect GRO implementation, TCP performance may be compromised.
pi@raspberrypi:~ $
Looking at the menus in sudo raspi-config per this post viewtopic.php?p=923216#p923216, I do not have the option for Device Tree in Advanced Options.
pi@raspberrypi:~ $ sudo iwlist wlan0 scan
wlan0 Interface doesn't support scanning.
pi@raspberrypi:~ $ iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
pi@raspberrypi:~ $
Looked around and found this, but it is t1ts-on-bull useful:
https://www.element14.com/community/mes ... x=6#201417
It's 3AM, the last time I tried to post, the browser crashed. I'm mentally drained, I feel like there is something I'm missing other than a recognized wireless nic. I have tried every single suggestion in this thread. None of the suggestions work, just like the wireless nic. I will check back tomorrow.
TheBalvenie21yo
Fri Mar 03, 2017 9:26 pm
Updated software to the March 2nd 2017 release.
Still not working.
lsmod shows this:
pi@raspberrypi:~ $ lsmod
Module Size Used by
bnep 10340 2
bluetooth 326105 5 bnep
cfg80211 428871 0
rfkill 16037 3 cfg80211,bluetooth
snd_bcm2835 20447 1
snd_pcm 75762 1 snd_bcm2835
snd_timer 19288 1 snd_pcm
snd 51908 5 snd_bcm2835,snd_timer,snd_pcm
i2c_bcm2708 4834 0
bcm2835_gpiomem 2976 0
spi_bcm2835 6678 0
bcm2835_wdt 3225 0
evdev 11396 6
joydev 9024 0
w1_gpio 3657 0
wire 25219 1 w1_gpio
cn 4374 1 wire
uio_pdrv_genirq 3164 0
uio 8000 1 uio_pdrv_genirq
i2c_dev 5859 0
fuse 84037 3
ipv6 347620 50
pi@raspberrypi:~ $
I have restarted the networking, did ifdown and ifup, manually added the network settings to wpa_supplicant.conf (and restarted the networking).
pi@raspberrypi:~ $ sudo /etc/init.d/networking restart
[ ok ] Restarting networking (via systemctl): networking.service.
pi@raspberrypi:~ $ sudo ifdown wlan0
ifdown: interface wlan0 not configured
pi@raspberrypi:~ $
pi@raspberrypi:~ $ sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
pi@raspberrypi:~ $ tail /var/log/daemon.log
Mar 3 16:20:16 raspberrypi systemd[1]: Starting LSB: Raise network interfaces....
Mar 3 16:20:17 raspberrypi networking[2072]: Configuring network interfaces...done.
Mar 3 16:20:17 raspberrypi systemd[1]: Started LSB: Raise network interfaces..
Mar 3 16:20:28 raspberrypi wpa_supplicant[2155]: Successfully initialized wpa_supplicant
Mar 3 16:20:28 raspberrypi wpa_supplicant[2155]: Could not read interface wlan0 flags: No such device
Mar 3 16:20:28 raspberrypi wpa_supplicant[2155]: nl80211: Driver does not support authentication/association or connect commands
Mar 3 16:20:28 raspberrypi wpa_supplicant[2155]: WEXT: Could not set interface 'wlan0' UP
Mar 3 16:20:28 raspberrypi wpa_supplicant[2155]: wlan0: Failed to initialize driver interface
pi@raspberrypi:~ $
Still nothing.
What am I doing wrong or where am I not looking?
donniebrasco
Sat Apr 01, 2017 5:34 pm
Whats the secret to get wifi working on the Pi3. I have upgraded and installed to latest versions. Wifi is on wlan0 but I am unable to scan for networks. How do I setup the wifi?
Sat Apr 01, 2017 5:38 pm
1. Don't use WEP security.
2. Write your /etc/wpa_supplicant/wpa_supplicant.conf file by hand using sudo nano to edit it.
Reboot after you think the supplicant file is correct. There's a gazillion examples on here.
donniebrasco
Sat Apr 01, 2017 6:04 pm
There is no wpa-supplicant file
Sun Apr 02, 2017 5:19 pm
donniebrasco wrote:There is no wpa-supplicant file
Then you are not running Raspbian. What OS distro is it?
Maskofdarkness22
Sun Apr 16, 2017 1:09 am
ok I had this problem before with many operating system, when this problem accurs it usually means your OS is set to detect the wrong region. I was able to fix this easily, all had to do was check the Pi's settings and it was right there. The Country Wifi was set to the UK but I live in the US after changing this setting the PI will reboot to make it permanent once it finished it connected directly to the Internet no problems what so ever. So before you go spending an hour or so reinstalling the Raspberry PI OS or waiting for an unnecessary update just check your settings and what region the PI has its settings on. :D
SimonSimon
Wifi dongle?
Mon May 01, 2017 8:49 am
Do I need a wifi dongle for the Raspberry pi 3 B? Do I need a cable for wifi, or is the model B version wireless?
Re: Wifi dongle?
Mon May 01, 2017 8:58 am
SimonSimon wrote:Do I need a wifi dongle for the Raspberry pi 3 B? Do I need a cable for wifi, or is the model B version wireless?
The Raspberry Pi 3b and has both WiFi and Bluetooth, details as per the Raspberry Pi Foundations website:
https://www.raspberrypi.org/products/ra ... 3-model-b/
The information is out there....you just have to let it in.
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
NormanDunbar
Fri May 05, 2017 7:36 pm
donniebrasco wrote:Whats the secret to get wifi working on the Pi3. I have upgraded and installed to latest versions. Wifi is on wlan0 but I am unable to scan for networks. How do I setup the wifi?
Blowing my own trumpet, but theses might help, although I find it strange that you don't have an wpa_supplicant.conf file. You were root (aka sudo) when you checked? As far as I recall, only root can see that file due to there potentially being passwords in it.
sudo -i
Will get you into root and into a shell session. Be. Very. Careful!
Anyway, links:
http://qdosmsq.dunbar-it.co.uk/blog/201 ... ifi-setup/
http://qdosmsq.dunbar-it.co.uk/blog/201 ... r-a-while/
I've set up 7 different pi computers, including a Pi3, pi zero, pi zero w, 2 pi 2b and a pi 2 all with Jessie and all exactly as per the links above. Take note of any caveats and pay attention to spaces around = signs etc. They are going to get in the way!
The second link is Pi3 only. Maybe pi zero w too, and is useful when the power save kicks in and shuts down the wifi. Making it almost impossible to restart it if running headless, as I do!
HTH
Cheers,
Norm.
Author of Arduino Software Internals. Learn how your hardware and software work together.
Why do they put lightning conductors on churches?
Why did Tarzan never have a beard?
teerna
Sat Jul 01, 2017 7:18 pm
Thank you everyone for the answers! This helped me connect to Wi-Fi on my RPi 3B!
udenjoe
Fri Feb 23, 2018 6:11 pm
jamesh wrote:
Tue Mar 01, 2016 11:25 am
It should 'just work'.
Click on the wireless icon top right on desktop, should give a list of access points, log in.
This answer is wrong and not true. I'm using a stretch desktop and wifi shows "No wireless interfaces found"
I've tried changing network/interfaces, wpa_supplicant, dhcpcd.conf. Name resolution fails when I try to connect. The interfaces are up and running but no way to update or connect to websites. There are too many ways to configure and none are clearly defined.
The documentation and tutorials are useless. Many answers are very bad. This is a terrible learning system if you are trying to learn.
Is there a place where I can get default config files?
Muntic0re
Fri Mar 09, 2018 10:45 am
I used this guide 192-168-1-1.one to adjust the wifi settings. It has the detailed step-by-step instruction. Anyway just follow these steps and you will manage to configure the settings. Good luck.
Fri Mar 09, 2018 11:00 am
Er, no. The answer is correct. What the system SHOULD do is exactly what I wrote.
If its not doing that then something is wrong. Either with the Pi itself or with your local network or a combination of the two.
The default config files are the ones installed, by default. They SHOULD just work.
ShiftPlusOne
Fri Mar 09, 2018 1:09 pm
What modifications have you made to thoe files and where did you see that you should make them?
BtflHmstr
Tue Jun 16, 2020 2:02 pm
It might be a slicker way to make the power saving options persistent to create a udev rule for the wlan interface, like so:
sudo bash
cat > /etc/udev/rules.d/01-disable-wlan-powersave.rules << "EOF"
# Whenever a device named wl* is added to the system, disable its power saving features.
ACTION=="add", SUBSYSTEM=="net", KERNEL=="wl*", RUN+="/sbin/iw dev $name set power_save off"
EOF
(This has been taken from https://wiki.archlinux.org/index.php/Po ... interfaces)
