KappinToad
LEDs are both solid?
Sun Feb 28, 2016 11:06 pm
Hey, it's me again. This time I brought a compatible microSD card this time, it's a Lexar 16GB microSD. I checked the list and saw that it was compatible with it.
But anyways, I'm still having issues with my rpi. I formatted the card, extracted raspbian on it using the disk imager, hooked it up via phone charging cord and hdmi cord for my TV.
Help?
pema
Re: LEDs are both solid?
Mon Feb 29, 2016 6:27 am
Hej.
Had kind of same issue. All of a sudden everything stopped working and I had to delete all partitions with gparted in puppy Linux, reformat sd and burn image again. There is probably nothing bad with your sd it is all due to bad software that craps up to easy.
brekee12
Mon Feb 29, 2016 7:41 am
Please check if the phone charger is able to provide 2A; becasue, during boot process the system takes much more power than normal. This can cause also reboot.
Brekee12
on a Raspberry B+ with whezzy, two Zero with Jessie Light
