External HDD not powering up?
Posted: Fri Feb 26, 2016 8:55 pm
by jason118
I've got a 1TB Toshiba 2.5" canivo basics external HDD which works fine with my laptop and Xbox One, but when I plug it into my pi 2 the HDD sounds like it's powering up but cutting out after a second or so. Is there a way around this? All I want to use the HDD for is viewing videos/music etc.. thanks
Re: External HDD not powering up?
Posted: Fri Feb 26, 2016 8:57 pm
by GTR2Fan
Try adding the line...
...anywhere in your
config.txt file.
If you need talking through how to do this, just ask.
Posted: Mon Feb 29, 2016 8:21 pm
by jason118
GTR2Fan wrote:Try adding the line...
...anywhere in your
config.txt file.
Worked perfectly thanks man. Should I get something like a powered USB hub or anything for future use?
Posted: Mon Feb 29, 2016 8:26 pm
by GTR2Fan
jason118 wrote:Worked perfectly thanks man. Should I get something like a powered USB hub or anything for future use?
You're welcome. I wouldn't bother unless you have a specific need for one for something else. Just check that the Pi PSU isn't getting too warm running the HDD and you should be fine.
