Power Supply Issues - Undervoltage Warning
Posted: Sun Feb 21, 2016 5:04 am
My setup:
Powered USB hub
5v 2A USB power supply
Wired USB keyboard - hub
Wired USB mouse - hub
WiFi adapter - hub
Computer monitor connected via HDMI to DVI
Powered speakers 3.5mm jack
(Everything is connected to a high quality power strip with an on/off switch)
I got a new Pi 2 Model B today after using the original Model B for quite some time. I put NOOBS onto the SD, connected all the plugs and wires and started it up. It immediately showed the low-voltage square rainbow icon and the power LED was flickering. I have a 5v .2A fan connected to the GPIO so I unplugged that and it helped a little, but not much. I never once had this issue with my original Model B. The 5v 2A power supply (name brand Belkin, cost $20 >.<) has a rotating plug that, when turned a certain way, will not work, but when turned correctly it works fine and is what I've been using. The cable came in the kit that my old Pi came in.
I switched to an Anker gold plated fancy cable and the issue went away except for when the Pi first boots up. I also tried plugging it directly into the wall instead of the power strip, but that didn't help. I have a 5.2v 1.35A power supply and when I used that the icon never showed up, but I don't want to continue using that given its specs.
So is my only option to buy a new (preferably one made specially for the Pi) power supply and cable? I know the Pi 2 uses more power, but I see no reason why it shouldn't work properly. Also, while researching this issue I saw something about a certain fuse/chip thing that can get damaged when the Pi is under-powered; is it possible that I've already damaged it?
I really don't want to have to spend more money and wait around for a new power supply to arrive. Any help would be appreciated.
Oh, and my micro SD is a SanDisk 16GB Class 10.
Thanks!
Powered USB hub
WiFi adapter - hub
Thanks!
