Onira
how to run a keyboard on RPi Zero via OTG cable ??
Tue Feb 16, 2016 11:05 am
Hello
I am trying to run a keyboard on RaspberryPi zero via OTG cable (bought Raspberry Pi zero + essentials kit)
I have fresh jessie image on my SD card and I connect to my pi via enc28j60
Can I ask for some help?
Cogito ergo sum
RaTTuS
Re: how to run a keyboard on RPi Zero via OTG cable ??
Tue Feb 16, 2016 11:08 am
plug in keyboard and type - ?
what keyboard
have you got a micro usb shim ?
Covfefe
Onira
Tue Feb 16, 2016 11:41 am
standard keyboard like Logitech K-120 or K-250
I have USB - microUSB cable delivered with the Essential Kit
Cogito ergo sum
RaTTuS
Tue Feb 16, 2016 12:36 pm
if you are ssh'ing in via the enc28j60
then type tail -f /var/log/syslog
and plug your keyboard in [plug it in the right socket]
does it recognize it ?
Covfefe
Onira
Thu Feb 18, 2016 6:19 pm
[email protected]:~ $ tail -f /var/log/syslog
Feb 18 19:18:16 raspberrypi0 systemd[650]: Starting Timers.
Feb 18 19:18:16 raspberrypi0 systemd[650]: Reached target Timers.
Feb 18 19:18:16 raspberrypi0 systemd[650]: Starting Sockets.
Feb 18 19:18:16 raspberrypi0 systemd[650]: Reached target Sockets.
Feb 18 19:18:16 raspberrypi0 systemd[650]: Starting Basic System.
Feb 18 19:18:16 raspberrypi0 systemd[650]: Reached target Basic System.
Feb 18 19:18:16 raspberrypi0 systemd[650]: Starting Default.
Feb 18 19:18:16 raspberrypi0 systemd[650]: Reached target Default.
Feb 18 19:18:16 raspberrypi0 systemd[650]: Startup finished in 61ms.
Feb 18 19:18:16 raspberrypi0 systemd[1]: Started User Manager for UID 1000.
Feb 18 19:18:47 raspberrypi0 kernel: [  206.959939] Indeed it is in host mode hp        rt0 = 00041901
Feb 18 19:18:47 raspberrypi0 kernel: [  207.139851] usb 1-1: new low-speed USB d        evice number 6 using dwc_otg
Feb 18 19:18:47 raspberrypi0 kernel: [  207.141407] Indeed it is in host mode hp        rt0 = 00041901
Feb 18 19:18:47 raspberrypi0 kernel: [  207.319793] usb 1-1: device descriptor r        ead/64, error -71
Feb 18 19:18:47 raspberrypi0 kernel: [  207.431269] Indeed it is in host mode hp        rt0 = 00041901
Feb 18 19:18:47 raspberrypi0 kernel: [  207.609794] usb 1-1: device descriptor r        ead/64, error -71
Feb 18 19:18:48 raspberrypi0 kernel: [  207.719909] Indeed it is in host mode hp        rt0 = 00041901
Feb 18 19:18:48 raspberrypi0 kernel: [  207.899798] usb 1-1: new low-speed USB d        evice number 7 using dwc_otg
Feb 18 19:18:48 raspberrypi0 kernel: [  207.901293] Indeed it is in host mode hp        rt0 = 00041901
Feb 18 19:18:48 raspberrypi0 kernel: [  208.079786] usb 1-1: device descriptor r        ead/64, error -71
Feb 18 19:18:48 raspberrypi0 kernel: [  208.191470] Indeed it is in host mode hp        rt0 = 00041901
Feb 18 19:18:48 raspberrypi0 kernel: [  208.369797] usb 1-1: device descriptor r        ead/64, error -71
Feb 18 19:18:48 raspberrypi0 kernel: [  208.479914] Indeed it is in host mode hp        rt0 = 00041901
Feb 18 19:18:49 raspberrypi0 kernel: [  208.659808] usb 1-1: new low-speed USB d        evice number 8 using dwc_otg
Feb 18 19:18:49 raspberrypi0 kernel: [  209.079789] usb 1-1: device not acceptin        g address 8, error -71
Feb 18 19:18:49 raspberrypi0 kernel: [  209.079932] Indeed it is in host mode hp        rt0 = 00041901
Feb 18 19:18:49 raspberrypi0 kernel: [  209.259798] usb 1-1: new low-speed USB d        evice number 9 using dwc_otg
Feb 18 19:18:50 raspberrypi0 kernel: [  209.679804] usb 1-1: device not acceptin        g address 9, error -71
Feb 18 19:18:50 raspberrypi0 kernel: [  209.679928] usb usb1-port1: unable to en        umerate USB device
Cogito ergo sum
