zdenol
Raspberry pi2 + DS18B20 wateoof One wire temperature sensor
Thu Feb 11, 2016 7:47 pm
Hi guys
I have an issue with raspberry pi2 + DS18B20 waterproof sensor.
I followed tutorial here
http://projects.privateeyepi.com/home/t ... ng-ds18b20. Anyway, I face some issue...
I am reading data only via shell, no python script....
after some time, raspberry simply HANGS and stopps to respond to SSH commands via putty. Only one thing that helps is hard reset...It simply freezes....
I have Jessie image from 9th of February 2016...
Am I doing something wrong?
jmmec
Re: Raspberry pi2 + DS18B20 wateoof One wire temperature sen
Fri Feb 12, 2016 3:51 am
It's not clear how you're determining that the Pi is hung, so I'm wondering if it may be because your Putty ssh session does not have keep-alives configured, so the connection is dying?
Try configuring a keep-alive in Putty? The site below is the first I came across with a picture showing what to change.
http://www.nth-design.com/2010/05/10/us ... -in-putty/
