Anyway, my kernel is stock Raspbian:
Linux raspberrypi3 4.4.50-v7+ #970 SMP Mon Feb 20 19:18:29 GMT 2017 armv7l GNU/Linux
I think a newer kernel is installed but isn't getting booted for some reason. I'm kind of a Linux newbie
I've compiled the 8822bu driver with a couple of warnings. Whether it will work or not I don't know as I don't have a 8822bu wifi module to test it with.cdclawson wrote:I've heard there's a way to use Windows drivers on Linux with a package called "ndiswrapper", but I've never tried it. Then again, it might fail anyway because it's ARM and not x86.
wget http://fars-robotics.net/8822bu-4.4.50-v7-970.tar.gz
tar xzf 8822bu-4.4.50-v7-970.tar.gz
./install.sh
I found the source here https://github.com/brandon-bailey/rtl8822bucdclawson wrote:Well, it mostly seems to work. I can scan, I can connect to an AP, but my packets aren't going anywhere. Guess I need to mess with the configuration some more.
BTW where did you find the driver source, and did you need to do anything special to compile it? Thanks
Edit: I had the entry in /etc/network/interfaces set to manual instead of dhcp. All seems to be working now.
country=GB
update_config=1
network={
ssid="Network-Name"
psk="Network-Password"
The 8812au driver is available for 4.9.25-v7~ #995. Did you type the file name correctly when using the tar xzf command? The error is typical if you type the name incorrectly which would essentially point to a file that doesn't exist.nix235 wrote:Greetings!
Is there a driver for:
kernel rev: 4.9.25-v7+
build: 995
I do: wget http://fars-robotics.net/8812au-4.9.25-v7-995.tar.gz
But I cannot decompress the file. Downloaded file is 699kb
tar xzf 8812au-4.9.25-v7-995.tar.gz
produces: Cannot open: No such file or directory
Child returned status 2
Any suggestions?
Thanks!
pi@raspberrypi:~ $ wget http://fars-robotics.net/8812au-4.9.25-v7-995.tar.gz
--2017-05-07 19:15:13-- http://fars-robotics.net/8812au-4.9.25-v7-995.tar.gz
Resolving fars-robotics.net (fars-robotics.net)... 212.23.8.80
Connecting to fars-robotics.net (fars-robotics.net)|212.23.8.80|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 699307 (683K) [application/x-gzip]
Saving to: ‘8812au-4.9.25-v7-995.tar.gz’
8812au-4.9.25-v7-995.tar.gz 100%[======================================================================================>] 682.92K 743KB/s in 0.9s
2017-05-07 19:15:19 (743 KB/s) - ‘8812au-4.9.25-v7-995.tar.gz’ saved [699307/699307]
pi@raspberrypi:~ $ tar xzvf 8812au-4.9.25-v7-995.tar.gz
8812au.ko
8812au.conf
install.sh
I have a script which will automatically determine the driver version you need for the Raspbian kernel version you are using and download and install it.
sudo wget http://www.fars-robotics.net/install-wifi -O /usr/bin/install-wifi
sudo chmod +x /usr/bin/install-wifi
sudo install-wifi -h
sudo install-wifi
Yes, you will whenever you update the kernel, but at least you now have a working wifi.
Hi MrEngman. All of the websites above give an 404 error. I'm trying to get my Edimax adapter working on a Rpi3 running LibreELEC.SkywalkerPD wrote: ↑Wed Oct 11, 2017 9:01 amWill this process work on a Pi3 running LibreELEC 8.1.2? I'm using the EW-7811UTC dongle, and it doesn't work with 5Ghz AC.
At the moment I use this configuration:
echo "options 8812au rtw_power_mgnt=0 rtw_enusbss=0 rtw_ips_mode=1 rtw_vht_enable=0 rtw_ht_enable=1" > /storage/.config/modprobe.d/8812au.conf
And now it is stable but only on wifi N. If there is a way to enable working and stable 5Ghz AC, I really like to try that!
Thanks!
The drivers I compile are specifically for Raspbian OS so I don't expect them to work with LibreELEC. However, as far as I'm aware there is an 8812au driver included in LibreELEC.SkywalkerPD wrote: ↑Sat Jan 06, 2018 6:47 pmHi MrEngman. All of the websites above give an 404 error. I'm trying to get my Edimax adapter working on a Rpi3 running LibreELEC.SkywalkerPD wrote: ↑Wed Oct 11, 2017 9:01 amWill this process work on a Pi3 running LibreELEC 8.1.2? I'm using the EW-7811UTC dongle, and it doesn't work with 5Ghz AC.
Thanks!
uname -a gives: Linux LibreELEC 4.9.59 #1 SMP Fri Dec 15 23:48:41 GMT 2017 armv7l GNU/Linux
Is it possible to update the driver for this configuration?
Thank you very much!
My wifi is working but on 5Ghz it is very unstable. So I used the options in de .conf to try to get it more stable. This works most of the time, but I experience a lot of disconnects. And after a reboot the wifi will not connect.MrEngman wrote: ↑Sat Jan 06, 2018 7:56 pmThe drivers I compile are specifically for Raspbian OS so I don't expect them to work with LibreELEC. However, as far as I'm aware there is an 8812au driver included in LibreELEC.SkywalkerPD wrote: ↑Sat Jan 06, 2018 6:47 pmHi MrEngman. All of the websites above give an 404 error. I'm trying to get my Edimax adapter working on a Rpi3 running LibreELEC.SkywalkerPD wrote: ↑Wed Oct 11, 2017 9:01 amWill this process work on a Pi3 running LibreELEC 8.1.2? I'm using the EW-7811UTC dongle, and it doesn't work with 5Ghz AC.
Thanks!
Quite sometime ago when I first added the EW-7811UTC to one of my Pis it only connect to the 2.4 GHz access point until I changed the wifi set up and disabled access to the 2.4GHz access point and then it connected to the 5GHz access point. After that I was able to re-enable access to the 2.4GHz access point and the EW-7811UTC still connected to the 5GHz access point. My 2.4GHz and 5GHz access points have different ssids.
You can access the drivers on my new web site at http://downloads.fars-robotics.net using a PC with internet access. Select the link Directory of available wifi drivers and then the link 8812au-drivers and then look for the file 8812au-4.9.59-1047.tar.gz.xyboox wrote: ↑Sat Jan 13, 2018 11:15 am@MrEngman could you please help me once more with this WiFi adapter? I don't have internet access from my Raspi ( is a Zero so no UTP port ) so I can't use your script to determine the build and automatic download of drivers. So I have to download them and copy them to the card and install locally.
My build is 4.9.59+ #1047 ( from uname -a ).
Thank you!
tar xzf 8812au-4.9.59-1047.tar.gz
./install.sh
You do not need to uninstall the old driver, just install the new one.
./install-wifi -h
I compile drivers for the Raspbian OS but your kernel/build indicates your OS is not Raspbian.SkywalkerPD wrote: ↑Mon Apr 23, 2018 10:00 pm@MrEngman
Are you planning to create driver files for the RTL8812AU on kernel 4.9.95?
That would be very much appreciated!!
Wifi install script now tells me:
*** Raspberry Pi wifi driver installer by MrEngman.
Your current kernel revision = 4.9.95+
Your current kernel build = #1
I don't know if it will.SkywalkerPD wrote: ↑Tue Apr 24, 2018 7:37 amOS is Xbian which is also based on debian. Wouldn't that work?
