Setting up Raspberry Pi 2 as a HiFi music player using:
- Raspberry Pi 2 - MODB - 1GB - Quad core
- TP-Link TL-WN725N 150Mbps Wireless N Nano USB Adapter
- Audioquest Dragonfly 1.2 DAC
1. Setup Raspbian
Using either of the NOOBS (Offline and network install or Network install only)
https://www.raspberrypi.org/downloads/noobs/
2. Setup WiFi
TP-Link TL-WN725N is a plug and play. The drivers were already available, only required me editing the config /etc/wpa_supplicant/wpa_supplicant.conf to add network details. Refer: http://www.fars-robotics.net/
sudo nano /etc/wpa_supplicant/wpa_supplicant.confCode: Select all
network={
ssid="Your-Network-Name"
psk="Your-Network-Password"
}Update - 2017 May 11
Recently I found the TPLINK connectivity to be very choppy. I reinstalled the driver from the above link and it started working really fine. Another tip about bad connectivity is to check the power saver option on it
sudo iwconfig [/color]
Reboot RPi
sudo rebootAfter plugging in my DAC, Alsamixer did not work for me. I was able to see the two options (on board sound and Dragonfly) in alsamixer, but choosing the DAC did not have any effect. So I went ahead and installed MPD. Instructions can be found: http://lesbonscomptes.com/pages/raspmpd.html (Refer MPD Installation section).
sudo apt-get update
sudo apt-get install mpdIn order to maintain bit transparency, I had to ensure the mpd.conf inhibits all auto conversions
sudo nano /etc/mpd.conf
audio_output {
device "hw:1,0" # This is need to redirect sound to USB DAC output. Keep 0,0 if using the Pi audio
auto_resample "no"
auto_channels "no"
auto_format "no"
}Code: Select all
sudo service mpd restartInstall the upmpdcli as per : http://lesbonscomptes.com/pages/raspmpd ... l#upmpdcli
Edit or create and add upmdpcli.list and add the following lines:
sudo nano /etc/apt/sources.list.d/upmpdcli.list
deb http://www.lesbonscomptes.com/upmpdcli/downloads/debian/ unstable main
deb-src http://www.lesbonscomptes.com/upmpdcli/downloads/debian/ unstable mainCode: Select all
sudo apt-get update
sudo apt-get install upmpdcliCode: Select all
sudo rebootNow you can play music from your UPNP / DLNA server on to RPi and on to Audioquest Dragonfly 1.2 DAC. I tested have tested this setup for bit transparency and it works fine. If you have any issue, it might be at the UPNP server end.
